Mushkin PC12800 6GB Ridgeback Review
Bask in its Redness
Search Reviews
Bask in its Redness
The Ridgeback Redline comes in the standard RAM packaging we're all used to now. Certainy there is no doubt about its colour.
Mushkin PC12800 6GB Ridgeback Review     Mushkin PC12800 6GB Ridgeback Review
Redline is a very apt name. It's good to see with so many boards being the red and black combination that there is the option to go red on your memory rather than the standard black.
And here is the Ridgeback heatsink in all its glory. It's a very distinctive one and the Redline logo looks very cool. It has one trick up its sleeve which we'll get to on the next page.
Although DIMMs, but their very nature, don't give us much to talk about, these look so different, and so gorgeous, that it's tough not to just keep saying "look at them!".
«Prev 1 2 3 4 5 6 7 Next»
05-10-2010, 20:54:55
tinytomlogan
We have got our sticky mitts on the first sample of Red Mushkin Ridgeback outside of the Mushkin factory. We just had to put it to the test.
Continue Reading
06-10-2010, 07:47:16
Taurus
The kit in stock on the Aria web site is black line. Do you know if Muskin are going release the red line with the ridgeback cooler as its not mentioned on the Muskin web site either only the Black line with the ridgeback cooler.
06-10-2010, 09:18:29
SnW
Nice review (as always) and "Mushkin Redline Ridgeback 998826" That must be Folding memory
06-10-2010, 09:18:55
tinytomlogan
As said in the review the Redline is a world exclusive we are the first people to have ever seen it. Its basically just a different heatsink but you might be in for a little wait before the Redline heatsinks actually start to appear dude
06-10-2010, 10:23:51
Warzone
"putting your cup of tea on it" xD
Oh and its always on the bottom for youtube videos descriptions however it did use to be the right of the video which is why they changed it to the bottom...people would always confused their left and right relative to the viewer:P
06-10-2010, 12:51:04
Th3rmal K1ng
I wish I could afford RAM that looks that cool.
See what I did there?
06-10-2010, 13:08:34
SnW
To be perfectly honest, No not at all
06-10-2010, 14:20:26
AMDFTW
me nither fella
06-10-2010, 14:32:54
Mr. Strawberry
+1 on that aswell
06-10-2010, 14:51:30
Th3rmal K1ng
Runs cool, looks cool.
Wow, I'm lame.
06-10-2010, 15:51:53
silenthill
nice to see Mushkin coming back hard, I always was a fan of them back in the old days
10-10-2010, 05:29:14
Toxteth O'Grady
Interesting that your review shows [url=
DDR3 Mushkin Blackline
DDR3 Mushkin Essentials
DDR3 Mushkin Proline
DDR3 Mushkin Redline
DDR3 Mushkin Ridgeback
DDR3 Mushkin Silverline
05-11-2010, 12:00:40
Taurus
Just took delivery of some of this lovely stuff (super special at Aria Pc £135)whipped it in and its great running at 1600mhz with I7 920@4000ghz will try at 2000mhz and provide update.
05-11-2010, 12:02:00
tinytomlogan
Make sure you watch the video for this then dude so you get the timings and sub timings correct.
05-11-2010, 12:06:43
Taurus
Tom,
Thanks for the reminder have already looked at the video and taken a print screen of the settings so i get the numbers right!!
05-11-2010, 13:07:09
Taurus
tried to run at 2000mhz but system would'nt boot at very similar settings as review. Cant get cycletime of 98 neither 88 nor 100 works, and cant select zero for back to back CAS# delay so left at auto. I will try loosening the timings to 8-10-8-27 or 9-10-9-24, and provide further update.
M/B ASUS P6TD Deluxe
05-11-2010, 13:36:54
tinytomlogan
leave it on auto apart from the one I said specifically about setting to 8 matey cant remember what one exactly now but its in the review and the video.
05-11-2010, 16:56:52
Taurus
Tom,
Tried that at 2000mhz and windows started then crashed.
Looks like I have a problem with this set of ram as it crashes to blue screen if you play games (MOH online) I also run prime95 for anything from 2 to 4 mins either on all setting at auto, or 8.8.8.24 or 6.8.6.24, at 1600mhz tried 1.64v as my standard setting and also 1.66v (MB does not have 1.65v) and the same happens. Looks like i'll be sending it back to Aria PC????
05-11-2010, 17:19:42
tinytomlogan
Tom,
It will be YOUR overclock dude Im affraid not the ram. The fact its crashing is because your OC is unstable and needs work.
You just need to put the time in Im affraid. deffo NOT the ram.
05-11-2010, 18:16:32
Taurus
I went back to my previous cpu oc of 3.7ghz and OCZ ram at 1866mhz, and stable as any thing prime95's ok and plays MOH ok!! I'll have another go over the weekend. Think I may need to up the cpu voltage from 1.275v to a higher figure. I will give it a go in small increments. I'll check out some of the other posts in the overclocking section for some more tips.
05-11-2010, 18:23:01
MushkinSean
Taurus,
The setting you were looking for is DRAM Read to Pre Time(TRTP) it should be manually set to 8 for memory frequencies over DDR3-1800.
From what you are describing I don't believe that is the issue however, sounds more likely that the Uncore is unstable.
05-11-2010, 18:27:17
lasher
Now thats service
05-11-2010, 18:35:53
tinytomlogan
What CPU do you have?
quick one - if the ram is at 1600 the uclk needs to be 3200 (twice the value) same with mem at 2000 the uclk needs to be 4000
ALSO make sure your tRTP is set to 8 as I said before, thats the crucial thing if you want to go to 2000.
If the ram is running at 1866 thats above the 1600 rated anyways so as we said its fine
You just need to fine tune now your overclocking.
05-11-2010, 20:56:15
Taurus
Thanks guys
CPU is an I7 920 Do stepping (OEM), stable at 3.7ghz with OCZ PC3-15000 running at 1866mhz so no OC on the memory
I'll re-install the Mushkin and give the settings above ago and let you know what happens.
06-11-2010, 05:38:56
Taurus
Guys,
Was working on this to stupid O'clock this morning and think I'm making head way so far have got CPU to 4ghz and ram at 1600mhx 6.8.6.24 stable. Will do some more work on this later today, as I want to get it really stable then try 2000mhz. Was a bit confused over uncore then found out that ASUS calls that QPI/DRAM, have set this to 1.35v at present with Ram at 1.64v.
Would like to say thanks again for help/pointers, its great to be able to get feed back so quick and from peple who know what they are talking about.
06-11-2010, 07:29:12
tinytomlogan
Guys,
Right mate. One more time.
QPI - 1.5 to 1.55v
Uncore = UCLK that needs to be set to twice the ram speed. its a frequency.
In the ram timings the tRTP needs to be set to 8 (its a little bit down the list of timings)
Ram set to 1.66v.
If you do what we say it will work you are not setting everything correctly
PLEASE read what we are posting fella.
06-11-2010, 08:02:49
Taurus
Thanks got it now sorry for the confusion
06-11-2010, 08:30:35
Taurus
ta da!
[attach][/attach]
06-11-2010, 08:36:44
tinytomlogan
ta da!
[attach][/attach]
Awesome dude, easy when you listen isnt it!
Now you just need to get it 100% stable at the lowest possible volts and you are done
06-11-2010, 08:42:13
Taurus
Thanks again
08-11-2010, 11:41:56
cZm
Sorry for starting up an old thread.
I have just hooked up this kit.
Could I just check that a QPI voltage should be around 1.5v for anything over the rated 1600Mhz?
08-11-2010, 12:24:46
tinytomlogan
If you read the thread dude you may need over 1.5v for 2000mhz.
But please read all the posts as there is a lot of other information you will need.
08-11-2010, 14:17:14
cZm
Yep Read that and viewed you Vid review. Very helpful, thanks m8.
12-11-2010, 07:24:51
cZm
Really enjoying this kit.
I am sorry to be going over old ground YET again but I just wanted to double check beofre I go for 2000Mhz.
Manually set tRTP to 8
QPI 1.5-1.55v
Timings/Sub Timings as per Video
Ram Volatge 1.64 - 1.66v
and see how I go?
Again sorry for asking thigns that seem to have been answered before, just wanna make sure before I get started.
Thanks
12-11-2010, 07:28:38
tinytomlogan
Deffo need the 1.66v rather than under the rated 1.65.
Deffo try the timings I had but remember you are overclocking and your set may be different. If anything you may just have to loosen the times off a smidge.
I still use these in the bench rig and they are rock solid @ 2000 8-9-8-24
13-11-2010, 14:24:56
cZm
Dont seem to be able to get stable at those settings/voltages.
Whats the max RAM voltage you would recommmend?
I will halt at 1.66v but will try 9-9-8-24
13-11-2010, 15:29:36
cZm
Man this stuff is just amazing..
Just dropped to 8-10-8-24 and stable.
Really really happy with RAM. Recommended to anybody.
http://i154.photobucket.com/albums/s..._01/Nice-4.jpg
16-11-2010, 21:44:12
rhomp2002
Good to see you with the Mushkin. I got my first Mushkin on the advice of a friend who builds computers and have stuck with them ever since. Never had a problem at all and they just keep working and doing exactly what I want them to do. Great company to deal with and they are really good when you have questions. Put a question on their forum and you will almost surely have an answer from Mushkin within 12 hours at most and the people there know what they are talking about. Never steered me wrong.
06-12-2010, 23:24:06
CLB
Has anyone tested this exact ram from the review, on the ASUS Sabertooth? If so how did it work out?
07-12-2010, 01:34:12
tinytomlogan
Mobos make next to no difference but Mushkin was used in the Saber Review if you go look
07-12-2010, 08:47:49
CLB
I thought that was them. I watched the saber review before I did the ram. Thanks for the insight man.....I must thank you for this website though tbh. Ive learned so much already since joining not long ago!!!
20-12-2010, 18:19:34
SpriteAlpha
I thought these were compatible with the Silver Arrow (according to Tom's post on the Aria forums)? I have just tried and the heatsink won't fit with this RAM Have I done something wrong?
20-12-2010, 18:49:15
tinytomlogan
I used them with mine dude, and the Radioactive sticks.
20-12-2010, 20:47:04
SpriteAlpha
Very weird. I'm not sure then... the fan on the RAM side was definitely raised due to coming into contact with the fins of the Mushkin. Maybe your case allowed for more height?
20-12-2010, 21:02:50
tinytomlogan
The fan will be its a 140mm mate. As long as the ram fits under the main body thats what I meant.
The 2nd 140mm is one of the bigger downfalls of the SA and why the Noctua is a much better cooler.
21-12-2010, 09:23:40
SpriteAlpha
Ah, I see. In any case, I've put the fans in the middle and rear, so now there's no interference with the RAM. I have an FT02 case, so I'm pushing (and pulling with the "rear" fan) everything upwards. It should work well, and I'll find out later today!
25-06-2011, 21:48:57
BillUp
Tom,
I've got the Redline Ridgeback 2x4GB 1600MHz (7-8-7-24) kit. I'm using the Asus P8 Z68 V-Pro and an i7 2600K. Do you think I will be able to hit the 2000MHz holy grail with the slightly looser timings, over the kit you reviewed?
I know you probably haven't tested these modules, but can you spare a wild guess?
PS, sorry for bumping thread.
