Mushkin HP2-5300 DDR2 1GB Kit
Appearance
Search Reviews
Appearance
The HP2-5300 is equipped with the same aluminium heatspreaders as found on the XP2 series. However, unlike the XP2 that is coloured Black, the HP2 series of memory is coloured in a visually attractive Blue.
Mushkin HP2-5300 Front Mushkin HP2-5300 Back
Mushkin HP2-5300 Side Mushkin HP2-5300 Side
Under some light it is hard to see the purple part of the Mushkin logo against the blue heatspreaders, but then let's face it - once they are inside you're PC it will be hard to notice.
Mushkin HP2-5300 Pads
By looking through the top of the heatspreaders we can see that these memory modules are single sided. I did have a go at removing the heatspreaders but Mushkin have used very high quality thermal pads that proved impossible to remove without potentially damaging the memory.
Mushkin HP2-5300 PCB
The PCB of the HP2 series memory is manufactured by Brainpower, who are well know by overclockers for producing high quality PCB's which assist in getting the best results out of the memory chips.
«Prev 1 2 3 4 5 Next»
16-06-2006, 10:12:59
Jim
Strapped for cash but want some overclockable DDR2? Check out the only review i've ever given 10/10 HERE
16-06-2006, 10:29:52
Raging
wow that is some sriously good value ddr2
mushkin doesnt fail to impress once again
good reveiw mate
16-06-2006, 10:33:43
Jim
good reveiw mate
Cheers
its a shame that the Mushkin stuff is quite hard to get hold of in the UK. Some sites have it, but nowhere near the full range
