Kingston Value PC3-10600 DDR3 1333MHz CL9 12GB (6x2GB) kit
Gaming Benchmarks
Published: 23rd June 2009 | Source: Kingston | Price: TBC |
Crysis is without doubt one of the most visually stunning and hardware-challenging games to date. By using CrysisBench - a tool developed independently of Crysis - we performed a total of 5 timedemo benchmarks using a GPU-intensive pre-recorded demo. To ensure the most accurate results, the highest and lowest benchmark scores were then removed and an average calculated from the remaining three.
Call of Duty 4 is a stunning DirectX 9.0c based game that really looks awesome and has a very full feature set. With lots of advanced lighting, smoke and water effects, the game has excellent explosions along with fast game play. Using the in-built Call Of Duty features, a 10-minute long game play demo was recorded and replayed on each of the GPU's using the /timedemo command a total of 5 times. The highest and lowest FPS results were then removed, with an average being calculated from the remaining 3 results.
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning "world", "earth" or "living" in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results Analysis
Both Crysis and Far Cry 2 failed to show any meaning full advantage of overclocking the 12GB kit with only a very minor increase in frames per second. Call of Duty four however was a different kettle of fish showing a decent improvement over the 5 runs I tested.
Let's head over to the conclusion....
That pink text on the test setup page is unreadable! >_>
Only reason I can see people needing 12GB is virtualization really.
Dan
Dan
Nice review, do they do a 6gb kit aswell? < in the uk btw
Only reason I can see people needing 12GB is virtualization really. Dan |
Continue Reading
