Kingston Hyper-X 2133MHz Dual Channel Review
Hyper-X Photos
Published: 8th September 2010 | Source: Kingston | Price: £133.93 |
Packaging and Heat-Spreader
Unlike many of the products that pass through our offices here at OC3D, RAM is always a bit short on things to discuss. It's blatantly obvious what it looks like and without any dip-switches or cooling to talk about it's more for the fun of looking.
Thankfully the Kingston Hyper-X T1 is definitely fun to look at. It's just gorgeous. The quality of the milling on the heat-spreader is exceptional. The whole thing is anodised in a lovely electric blue with a clear and crisp Kingston logo and Hyper-X branding underneath the main fins.
At 55mm high these are very tall and so if you've got an absolute beast of a cooler that's also strangely designed, you might need to double check. We've tested with the truly enormous Noctua NH-D14 and only needed to mount the front fan higher than normal. Standard 120mm tower coolers present no problem at all.
It helps to read every page and not just the conclusion
Can you show us a picture of the NH-D14 with the fan mounted higher because it seems to me to be a shabby job and I think thats why you didnt show us a photo in the first place. |
You wont get the tripple channel version of this to work with a D14 because it will over hand the first ram slot.
thks once again. excellent review as all ways.
Continue Reading
