G.Skill Trident X 2400MHz 8GB Review
Test Setup and Overclocking
Published: 29th June 2012 | Source: G.Skill | Price: ������&Ati |
Test Setup
8GB G.Skill Trident 2400 @ 10-12-12-31
Gigabyte Z77 G1.Sniper 3
Intel Core i7-3770K @ 4GHz
Sapphire HD7950
Catalyst 12.4
Cougar CM1000 PSU
Corsair F80 SSD
Thermalright Silver Arrow
Windows 7 x64
Overclocking
Sure enough, as we feared in our intro, these are the chips that are incapable of running at 2600MHz. No amount of tweaking or prodding, even slackening timings to ridiculous levels, would get the Trident X to run faster than its rated 2400MHz speed. We could lower the timings from CAS10 to CAS9, but this would only pass half of our benchmark tests, so the default speeds will be the ones we're running at.
PC Mark
As the new test setup has moved from Spinpoint F1's to SSDs, a couple of the PC Mark Memory tests are no longer comparable, so until we've tested a range on the current system the graph is slightly smaller. However, despite having a hyperthreaded CPU behind it, and the faster speed, the Trident X is only in second place behind the G.Skill Ripjaws X. It's close, but in PC Mark at least the extra bandwidth doesn't give a performance boost.
He says...with his overpriced 2133MHz RAM -.-
Idk if its just me but Id like to see some 1600mhz kit with tight timings rather than just high clocked with loose timings. I guess its possible to underclock and get lower latencies but perhaps companies could sell the 1600mhz at a cheaper price because big numbers = bigger price a lot of the time.
Tight timings makes SFA difference to 1155, its all about the bandwidth aka - MHz when it comes to good performance with these.
Today we take a look at a blazing 2400MHz kit from G.Skill. Does the extra speed pay dividends?
Continue Reading
