G.Skill ECO Low-Volt DDR3 Review
Intro and Tech Specs
Published: 8th April 2010 | Source: G.Skill | Price: £97.75 |
If there is one thing we're all very aware of it is the need to look after our planet. However as overclockers we all know that the faster we make our hardware go, and the more volts we give to make that happen, the more we take our toll on the planet. That is before we take into consideration the effect it has on our electricity bill. Anyone who has run a high-end overclocked system or a folding rig will attest to how quickly you need to start selling kidneys to pay the piper.
Wouldn't it be great if we could get some high performing memory that doesn't require enough power to light the Blackpool Illuminations? G.Skill think they have the answer.
Technical Specifications
Memory can be a tricky beast. We've all had experience of motherboards that can be very tricky about which memory they accept so it's great to see the G.Skill compatible with so many boards. The official compatibility list is :
Manufacturer | Model Name |
| ASUS | Maximus III Extreme Maximus III Formula Maximus III Gene SABERTOOTH 55i P7P55D-E Premium P7P55D-E Deluxe P7P55D-E EVO P7P55D-E Pro P7P55D-E P7P55D Premium P7P55D Deluxe P7P55D EVO P7P55D Pro P7P55D |
| EVGA | P55 Classified 200 P55 FTW 200 P55 FTW P55 P55 Micro P55 LE |
| MSI | P55M-GD45 P55-GD65 P55-GD80 P55-GD85 |
| Gigabyte | GA-P55A UD3 GA-P55A UD3P GA-P55A UD3R GA-P55A UD4 GA-P55A UD4P GA-P55A UD5 GA-P55A UD6 GA-P55 UD3 GA-P55 UD3P GA-P55 UD3R GA-P55 UD4 GA-P55 UD4P GA-P55 UD5 GA-P55 UD6 |
As you can see that's an impressive list covering almost every P55 motherboard around.
If there is one thing that's exceptional about these modules it is the timings available considering the voltage used. The ECO ships with four profiles by default, and even the full-fat one still has some exceptionally low latency.
| Clock Speed | Timings (CL RCD RP RAS) |
| 457MHz | 6-6-6-17 |
| 533MHz | 7-7-7-20 |
| 609MHz | 8-8-8-22 |
| 800MHz | 7-8-7-24 |
In anyones book those are so excellent timings considering we're running at 1.35v. To get DDR3-1600 at 7-8-7-24 is very impressive and should give us some nice results.
Before we pop off to see how well it does fair, let's get a look at the DIMMs themselves.
No overclocking? I'm disappointed... I've seen some real nice results with these sticks over at XS
We were having some CPU problems at the time of testing, so couldnt do the sticks justice so decided to leave that part of the review on this one and concentrate on the low power aspect instead.
Continue Reading
