Crucial Ballistix PC3-10600 (DDR3-1333) 4GB Kit
Search Reviews
LogoIf you've been near, in or around the PC enthusiast scene in the last 10 years then chances are you will have heard of Crucial. This company is known for making some of the best memory around, capable of achieving some fantastic overclocks. Today we take a glimpse at one of their latest kits in the form of the (rather harshly named) BL2KIT25664BA1336. This is a 4GB kit that, at stock settings runs in at 1333mhz at timings of  6-6-6-20. We've been impressed by numerous kits from Crucial before. From the first set of DDR2 PC2-6400 reviewed here, to the last set we looked at - DDR3 PC3-16000. I had high hopes for this kit.
On with the blurb from Crucial's own site:
What is Ballistix memory?
The Ballistix line is specifically built for performance enthusiasts who want to push the performance envelope without worrying about data loss or corruption, mysterious intermittent errors and display problems, or worse — the dreaded BSOD! The Ballistix line of high-performance memory modules features advanced speed grades, low latencies, and integrated aluminum heat spreaders.
What is a Ballistix DDR3 240-pin DIMM?
Ballistix 240-pin DIMMs are found in DDR3 memory. DDR3 — the next generation of memory — boasts an improved architecture allowing very fast data transmission. Ballistix 240-pin DIMMs are available in DDR3 PC3-12800 SDRAM (DDR3-1600).
A Ballistix dual inline memory module (DIMM) consists of a number of memory components attached to a black printed circuit board. Gold pins, found on the bottom of the DIMM, provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
To use DDR3, your system motherboard must have 240-pin DIMM slots and a chipset that supports DDR3 — which is a different technology than that of than its predecessors, DDR2 and DDR. DDR3 incorporates different sockets; they are not interchangeable or backward-compatible. (Information about which memory technology your system uses is included in the Crucial Memory Advisor™ tool.)
The number of black components on a Ballistix 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. Ballistix 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. These 240-pin DDR3 DIMMs have only one notch within the row of pins, and each technology has the notch in a slightly different location on the module.
And the specifications, once again hijacked for Curcials site:
  • DDR3 PC3-10600
  • 6-6-6-20
  • Unbuffered
  • NON-ECC
  • DDR3-1333
  • 1.8V
  • 256Meg x 64
    On the next page we take a look at the packaging and the modules themselves...
    «Prev 1 2 3 4 5 Next»
    18-09-2008, 10:24:01
    Ham
    Looking for a capable 4GB kit of DDR3? Today we take a look at Crucial's DDR3-1333 Ballistix kit, take a look inside to see how it fairs.
    http://www.overclock3d.net/gfx/artic...145551193s.jpg
    Review
    18-09-2008, 12:13:33
    Deshman
    Edit: Never mind.
    18-09-2008, 12:14:50
    Ham
    Originally Posted by name='Deshman'
    Any chance you can put the actual values of the results on the graphs as it's a little difficult to extract correct information for comparative purposes, especially so as the results are not compared against other memories in the review.
    Just hover the mouse over the bar/line and the value is displayed .
    18-09-2008, 12:16:01
    Deshman
    I noticed, thanks
    18-09-2008, 16:00:41
    Luigi
    Ooh nice, looks like a good kit, although there is faster out there
    Nice review Ham
