Crucial Ballistix 1600mhz & MOD Review
Benchmarks
Crucial Ballistix  MOD review
Benchmarks
As this is a kit designed to run at 1600 we thought we'd put it up against the Kingston LoVo we recently tested to see if the extra voltage makes a difference.
Everest Ultimate
Despite both the Kingston and the Crucial being both 1600MHz and CAS8, the Crucial takes a fairly healthy lead here, and even though our overclock was only mild we still see the benefits that fast RAM can have.
SiSoft Sandra
Our Sandra bandwidth test shows the Kingston and Crucial pretty neck and neck. Naturally the overclock on the Crucial gives us a nice little hike. Roughly a 10% increase for our 10% clockspeed. Proving what I said at the beginning about people not giving RAM enough priority in their PCs.
CineBench R11.5
The CPU test here follows the results we've seen above. However the OpenGL test is pretty conclusive that, for whatever reason, the Kingston LoVo spanks the Crucial fairly comprehensively. As this is our first real "system-wide" test, it doesn't bode well for the next page.
POV-Ray
Rendering requires enormous chunks of data to be swapped to the CPU and back and once again we find that the Crucial is found somewhat lacking.
«Prev 1 2 3 4 5 6 Next»
05-07-2010, 03:18:47
tinytomlogan
Today we take a look at the latest in the long Ballistix range of RAM from Crucial.
Continue ReadingQuote
05-07-2010, 09:28:01
silenthill
The On-board I2C temperature sensor is really a cool feature and now we will be able to know when our RAM is cooking, wonder if HWMonitor utility will detect it too.Quote
05-07-2010, 09:39:05
tinytomlogan
HWmonitor didnt with the latest version available. I have heard corsair have sneaked out a lot of ram with thermal probes built in.Quote
