CellShock PC2-9200 (DDR2-1150) 2GB Kit
Test Setup & Overclocking
Published: 8th August 2007 | Source: CellShock | Price: |
To ensure that all reviews on Overclock3D are fair, consistent and unbiased, a standard set of hardware and software is used whenever possible during the comparative testing of two or more products. The configuration and software used in this review can be seen below:
| OCZ FlexXLC PC2-9200 | CellShock PC2-9200 | Kingston HyperX PC2-9600* | |
| Processor | Intel Core2Duo E4300 | ||
| Motherboard | Asus P5K Deluxe | ||
| Graphics Card | XpertVision ATI X1950Pro PCI-E 512mb (Stock) | ||
| Hard Disk | Hitachi Deskstar 80GB 7K80 SATA2 7200RPM 8mb | ||
| CPU Cooling | Stock Intel Aluminium Cooler | ||
| Operating System | Microsoft Windows XP (SP2) 32bit - Latest Patches | ||
| Memory Frequency* | 575mhz (DDR2-1150) | ||
| Memory Latency* | 5-5-5-18 | ||
• Sisoft Sandra XI SP2 (CPU, Memory & HDD tests)
• Everest Memory Benchmarks
• SuperPI Mod v1.4 (1m and 16m)
• Quake 4
• Counter-Strike:Source
• F.E.A.R
• 3DMark05
• 3DMark06
Overclocking
With all three kits set to 5-5-5-18 timings and a voltage of 2.35v, I set out to find their maximum stable overclock. After a little tweaking and several hours of ORTHOS and 32m SuperPI stability testing, the following results were acheived:
No doubt it was going to be pretty hard for the CellShock PC2-9200 to beat the monsterous 660mhz overclock obtained by the OCZ FlexXLC in a recent review. However, the CellShock still managed to give the higher stock-clocked PC2-9600 Kingston modules a run for their money, beating them by a reasonable 10mhz to sit comfortably in the middle of the leaderboard with a top overclock of 620mhz (DDR-1240).
Reducing the speed of the CellShock to DDR2-800 allowed the memory timings to be tightened all the way down to a very impressive 3-3-3-6. This brings the CellShock PC2-9200 kit directly in line with the other kits tested from Kingston and OCZ.
Those sticks did well there Jimbo, nice review too.
Personally, I'd buy 4gb of the cellshock 6400 stuff over this.You get 4gb of 6400 for almost the same price of 2gb of this 9200 ram. The 6400 sticks OC to near 9200 speeds...
Still nice sticks mind
heh heh really nice review, my favourite part is:
The Bad:
-Not a sausage
The Bad:
-Not a sausage
http://www.overclock3d.net/gfx/artic...210713118s.jpg
CellShock PC2-9200 Review
