SteelSeries SRW-S1 Review
Up Close
Published: 10th February 2012 | Source: SteelSeries | Price: £99 |
Up Close
As always with SteelSeries we have packaging designed to allow you to look at the majority of the product before purchase. Given that this is something far more likely to be brought by someone with an average interest in racing, rather than the pro-only Hyperstim and Fanatec type affairs, then showing off its flash and flair is a wise move.
As you can see it's positively bristling with buttons and dials and switches. If you ever wanted to know what it would feel like to be Jenson Button for the day, then this is certainly the wheel for you. On the reverse we have four paddles with the top two being for gear changes, and the bottom two are fully-analogue accelerator and brake.
Every button has a nice reassuring click to it when depressed, and yes the lights at the top do replicate your F1 gear change indicator.
Thanks to a sensible bit of design the SRW-S1 doesn't require any drivers, and is purely plug and play, similar to using a wired 360 pad on your PC. Before you ask, no it isn't compatible with any consoles. PC only here.
The dials at the bottom adjust the amount of angle needed to go from lock to lock, then the other two control driver aids in SimRaceWay only, and can't be configured in any other title.
Speaking of SimRaceWay..
Go to Options > Controls, click on the sensitivity tab and change X Axis Sensitivity to 40 (leave the rest at their default value of 50).
Next, click on the Rates tab and set the sliders to the following values:
Steering rate: 50
Throttle rate: 50
Brake rate: 50
Clutch rate: 20
Speed sensitivity: 0
Look ahead: 0
Head movement: 0
Exaggerate yaw: 0
All that is left to do after this is find your own sweet spot with the steering sensitivity dial on the front of the wheel, the admin recommended 360 but I prefer it closer to the 200 mark.
Hope this helps someone
I love sim racing and use a lot of my time playing Iracing, Richard burns rally and all the simbin titels but to get the best experience then you need a proper wheel with realictic force feedback so you know what the car is doing and not just a fancy controller with lots of buttons and a rumble function.
I get the point of it being a step in the right direction towards getting a real wheel but why not get the real deal the first time?
Good review but I do not understand these new motion steering wheels. I love sim racing and use a lot of my time playing Iracing, Richard burns rally and all the simbin titels but to get the best experience then you need a proper wheel with realictic force feedback so you know what the car is doing and not just a fancy controller with lots of buttons and a rumble function. I get the point of it being a step in the right direction towards getting a real wheel but why not get the real deal the first time? |
Good review but I do not understand these new motion steering wheels. I get the point of it being a step in the right direction towards getting a real wheel but why not get the real deal the first time? |
This is a bloody good wheel when you mount it, it is so accurate and easy to use. (I have mine mounted on my tripod)
Not everyone can afford the real deal or maybe they don't have the room for a full setup. This is a bloody good wheel when you mount it, it is so accurate and easy to use. (I have mine mounted on my tripod) |
But i can see some people would buy it because like you said it takes up very little room compared to a complete rig with pedal and everything.
My rig takes up quite a lot of space but i would never get rid of it and buy a motion controller
I am totally not bothered about force feedback because I get that from the seat I sit on. I use an Aura vibration cushion with an additional speaker low pass filter I bought on ebay. Thus I get the engine and road vibration through my body!
I think that camera tripod mod is an excellent idea and that is something I actually would have room for just below my desk.
Returning it for Logitech G27.
EDIT:
Not getting G27 now.
http://www.fanatec.de/html/index.php?id=230&lang=en
Going for this german made wheel and pedals.
The broken SRW-S1 is on it's way back to the shop for refund.
I spent several days trying to post a support ticket for the SRW-S1 on Steelseries website. The support ticket posting is also dead most of the time. Finally got a support ticket posted last night but it's too late now. No more floaty wheel for me.
If you're thinking maybe I'm a noob who broke his wheel? I still have my logitech formula force GT bought second-hand 12 years ago and it still works.
Changed my mind about the Logitech G27. Have heard lot of complaints about a built in deadzone. http://www.fanatec.d...?id=230&lang=en Going for this german made wheel and pedals. The broken SRW-S1 is on it's way back to the shop for refund. I spent several days trying to post a support ticket for the SRW-S1 on Steelseries website. The support ticket posting is also dead most of the time. Finally got a support ticket posted last night but it's too late now. No more floaty wheel for me. If you're thinking maybe I'm a noob who broke his wheel? I still have my logitech formula force GT bought second-hand 12 years ago and it still works. |
Yes I am negative about it. Should I be positive about a wheel that stops working 2 days after purchase?
The final nail in the coffin was the Steel website ticket page failing to load when I tried to raise a support ticket.
If you have an SRW-S1 that works then that's great. If you don't then this really is none of your business.
"you are quite negative towards tech in general on your facebook page too. " - really? Not a steelseries employee are you? Perhaps you could send me one that doesn't fail after approx 4 hours total use.
While the wheel was working I found it to be quite responsive. In F1 2011 it was excellent. No lag. Shift 2 was hard to control due to the steering lag the game is known to have. For anyone who doesn't have the desk space the SRW-S1 is very good. However, since it is my first Steelseries product and since it failed within 2 days and since I had trouble posting a support ticket because that section of their website kept returning "failed to load", well I am not so impressed with them now.
Dealing with them can only be done by e-mail; and only first names are provided, with no indications of title in their organization. The first contact person, Brendan, referred my claim ticket to Mike, who then referred me to Brendan. Within these referrals, were periods where neither would respond for periods of days. In some very insinuating ways, their e-mails would further refer to the need for me to rearrange my mailing address format, to ensure that no further delays would be encountered. Also, Brendan claimed that my mailing address (which is a rural mail box on a dirt road) was not appropriate for return delivery as it was a Post Office box (which I assured him it was not). My address is of the format: RR2 box ####, some town, some state, zip. This is obviously NOT a P.O. Box at a post office. I assured him that the U.S.P.S. , U.P.S., and Fed-ex all deliver to my address. NO REPLY!
So, I next e-mailed their Netherlands (I presume) office, and I await some action.
I am a 61 year old retired electrical engineer. I was very nice to this equipment. I know enough about these things to know that it failed to communicate with my pc, and since have discovered others' reports of similar failures with the SRW-S1 wheel. The wheel was great fun to use within that one month, and my other reason for buying it was to avoid the mechanical failures associated with many other wheels. I believe that SteelSeries knows that there is an inherent electrical design problem with this wheel, and that they are stalling for some reason which is not clear to me right now.
My advice would be to STEER CLEAR of this SRW-S! wheel. I have no other conflicts with them and am not associated with any of their rivals. Their customer service is a misnomer! It remains to be seen how they will follow up with my warranty claim, but I can assure you that they are NOT very nice to deal with.
Looks really good this and not bad for the price too. But i reckon i'd still go for g27 for the reason that i just feel that much more immersed in the game than i would be with this and the g27 with the force feedback and stickshit, its more real to me. I do see this selling well though, could be a great addition for a living room gaming pc or in a small box room where space is an issue. Good product overall though. |
Today we look at the SRW-S1 from SteelSeries, a wheel designed around motion controls.
Continue Reading
