Roccat Kone XTD Gaming Mouse Review
Software
Published: 10th November 2012 | Source: Roccat | Price: |
Software
You definitely aren't short of options when it comes to tailoring the XTD to your needs. With five profiles, each with up to five DPI settings, you have full control over the Kone XTD and how sensitive it is.
The buttons on the Roccat are fully customisable too. Not only have you got the regular buttons to assign, but with the combination of the Easy-Shift[+] modifier you have another full range of potential assignments.
Under the advanced control tab are the finer controls to tune the XTD within an inch of its life. As well as lift-off distance and surface analysis you can tweak the sensitivity on both axes. The oddest tab belongs to a trophy section depending on how many times you've clicked and scrolled.
Finally, before the colours on the next page, we have the macro editor. Whilst not quite at the very zenith of macro software it is certainly as easy to use as you could wish and offers enormous customisation options.
Gamers often lift the mouse from the surface to reposition the mouse back to center or start point on the mousepad, but this mouse isn't great grip and lift. A bit of headache when this mouse is directed towards gamers.
Today we're taking a look at the third iteration of the Roccat Kone gaming mouse, the XTD.
Continue Reading
