Razer Deathadder 1800dpi Gaming Mouse
Test Setup & Performance
Published: 11th May 2007 | Source: Razer | Price: |
When testing a mouse, a lot of the conditions that would affect other hardware tested on OC3D does not really factor in, such as the rig used. However, in order to maintain consistency, I will be using the following to test the Deathadder:
• All of the mice were tested on a Razer eXactmat using its speed setting.
• Games tested include one FPS (Counter-Strike Source) and one RTS game (Command & Conquer 3). This is to enable us to see how the Deathadder faired under different gaming environments.
• The drivers used were downloaded from the Razer site and were the Vista Beta Drivers v1.05b.
Mouse Performance
According to the marketing blurb, the Deathadder is aimed at low sensitivity gamers, commonly found when playing FPS games such as Counter-Strike Source. In actual fact, the Deathadder’s box notes this game as one of the markets the mouse is aimed for.
Low sensitivity gamers tend to sweep the mouse across the gaming surface more often, so Razer have addressed this by using a new, third generation infra-red optical sensor. It is claimed that this eliminates any form of skipping and negative acceleration. But the question is, “does it work”?
Well, yes it does! Previous mice I have used do have a tendency to skip and react unpredictably when used on a low sensitivity and when dragged quickly across the gaming surface. The Deathadder does not do this! In fact, even though the DPI on this mouse is lower than the Habu and Copperhead (1800dpi vs 2000dpi), it feels the smoother, more accurate mouse!
I would put this down to a number of factors. Firstly the technology plays a massive part in this, which is a given. However, the feel of the mouse, its body, the weight, all add to the overall performance making it very capable indeed.
When testing in Counter-Strike Source, I found the tracking to be extremely accurate indeed. I personally play with a very low sensitivity but the tracking remained accurate even when dragging the mouse quickly across the eXactmat! So the burning question is, did this improve my “fragging” ability? Well it certainly made me more consistent. I found the smooth movement (due to the excellent Teflon feet) allowed the mouse to glide around very well indeed. It was a smooth “buttery” and silky feel which really impressed me!
The on-the-fly sensitivity, which seems to be implemented in all gaming mice these days, didn’t offer anything new, but worked as expected. Personally I don’t find on-the-fly that useful in games such as Counter-Strike Source as changing the sensitivity whilst playing does tend to “mess up” my aim. However as stated, it works effectively and some gamers will benefit from it.
I did however find that the one-the-fly worked very well in Command & Conquer 3. Scrolling around the map quickly, I found that switching between the various speed settings enabled me to move more quickly, then when I needed more precision (i.e. selecting troops), the lower sensitivity worked well.
Overall I found the performance in both games to be of the highest standard. The Deathadder felt much smoother and more accurate than the Copperhead and Habu and did not show any signs of its lower DPI rating.
Nice job there by Ins. Looks like a good mouse, i just hope the fact its lower don't irritate people who have big hands.
Nice Review Chris, been after one of these for ages but im still too keen on my MS3.0
spot on review!
Been using a Deathadder for two weeks now, from using a Diamondback, was surprised that there was zero time required to adapt.
For me the Deathadder feels so much better than the Diamondback - and I thought the Diamondback was brilliant!
I've got fairly big hands and I would say that the DA suits me better than the DB.
Thanks guys!
Yes this mouse really did impress me. I always thought things couldn't get any better after the Copperhead because there is only so many DPI you can go to before it's hard to tell the difference.
However the Deathadder did feel a lot smoother overall. Plus the buttons have a nice "click" to them and the side buttons are easy to locate. Combine this with the fact that it sits perfectly in your hand (assuming you're right handed) and it's a very accomplished mouse!
Nice review
I think I'll stick with my diamondback as I prefer ths shape compared to the deathadder.
No lanbag included
lol
edit: I also think it depends on how you hold a mouse. Like do you have 1 finger over each button (all 3) or do you only have 2. Do you rest your hand/wrist on the mat and move the mouse mainly using your fingers, or do you have your hand off of the mat and totally elevated from causing any friction. etc etc
No lanbag included
loledit: I also think it depends on how you hold a mouse. Like do you have 1 finger over each button (all 3) or do you only have 2. Do you rest your hand/wrist on the mat and move the mouse mainly using your fingers, or do you have your hand off of the mat and totally elevated from causing any friction. etc etc
I own one of these and its slick
Originally Posted by name='equk'
Nice review
![]() I think I'll stick with my diamondback as I prefer ths shape compared to the deathadder. No lanbag included loledit: I also think it depends on how you hold a mouse. Like do you have 1 finger over each button (all 3) or do you only have 2. Do you rest your hand/wrist on the mat and move the mouse mainly using your fingers, or do you have your hand off of the mat and totally elevated from causing any friction. etc etc ![]() |
Good review Ins
id get one if a. I had the money, and b. if i didnt have such an attachment to my Logitech MX518 :P
id get one if a. I had the money, and b. if i didnt have such an attachment to my Logitech MX518 :Pits a good mouse but in ergonomics logitech are never beaten ,
i had an mx 510 and i just got and G5 and my god they are so comfortable , the razer mice kinda have the traditional shape but the death adder has changed and is kinda similar to logitech models
I use my old Logitech MX510 as my work mouse and yes I agree they are very comfortable. But this Razer mouse is even more comfortable!
The Copperhead and Diamondback weren't the most ergonomic mice, but that's because they are ambidextrous mice whereas the Deathadder is Right-handed only, which makes it the most comfortable mouse I've ever used
they sit there, staring at me when I pop down to the warehouse and I sit there looking at them cursing the fact I'm left handed....
Sweet review though and thanks for picking up on the fact us lefties will be knackered if trying to use one
yea i have had one for a bit now its sutch a good mouse that i would consider buying another for my shelf
I'd love to have a go at that mouse, as I've had my diamondback for some time and I agree that the side buttons are a bit of an afterthought. Nice review INSey
Nice review Chris.
Looks like you have pursuaded me to buy one of these and see if I prefer it over my Logitech G5 which I have never been able to get along with tbh.
It's awesome mate! You won't be disappointed! The best gaming mouse I've ever used (and I've had a lot haha)
If a green one comes out I may have to buy it
lol u and ur green
the blueness very well matches G15 keyboards.
I did have a red: case; keyboard and mouse - now it's just a red case - I've given up on PC "interior design".
Hey! Had a good idea for a TV programme rip off of changing rooms - "changing rigs" where 2 people go off and mod each others PC setup.
I use a Razer Diamondback for my main rig, its really good for gaming, the only thing is the way it curves down at the front buttons... not good for extended gaming, fingers get tired and cramped. I like the way my hand feels on Logitech mice, the more rounded from front to back feel, but overall my MX-518 is only okay and for backup, and my MX-1000 is at work (cordless isn't so good for gaming, a slight lag time and batteries run dry... so uncool). May go after the DeathAdder since it looks more rounded from front to back, and the higher front looks like a very good idea.
TJS
TJS
To sum it up, the Deathadder takes all of the great ergonomic qualities of mice such as the Logitech range and combines them with the smoothness and accuracy associated with previous Razer mice.
Add to that the smoothest, most crisp feeling response all covered in a lovely grippy "smooth to touch" rubber feel and you've got a winner!
I still can't get enough of it if I'm honest!
Well Chris you just cost me £54 !!!
Just ordered the Razer Deathadder and a Razer ExactMat from SpecialTech.
Sold my Logitech G5 so I hope I get along with this mouse a little more.
you will love it its a great mouse
Just ordered the Razer Deathadder and a Razer ExactMat from SpecialTech. Sold my Logitech G5 so I hope I get along with this mouse a little more. |
Great combo and you'll love it!
I'll be grabbing the DeathAdder, but can't get rid of my 'Hooters' mouse pad... my wrist rests comfortably in the cleavage!
(the mouse is happy, too
http://upload.overclock3d.net/get.php?id=2746&view=1
TJS
)http://upload.overclock3d.net/get.php?id=2746&view=1
TJS
Ummmm Hooters mouse mat review ftw?
:rotfl:
:rotfl:Received my DeathAdder a few days ago, fits in my hand alot better than the G5 and slides smoothly across this eXactMat.
I am now starting to get used to it and I am impressed, a huge improvement over my G5
I am now starting to get used to it and I am impressed, a huge improvement over my G5 ![]() |
Get one Jimbo
It's the best mouse I've ever used!!
Me too lol
Im still on the G5, caint complain i got given it, still good though.
Rob
Rob
Welllllll, it feels good in the hand and moves like butter (even on a mousepad that isn't super-smooth), BUT the old fault is apparent... can't use the thumb buttons in Halo!
I've tried the newest drivers, all configurations, and still leaves me dry. This particularly sucks because I used to use the scroll wheel button for melee but wanted to switch to a thumb button... and now neither works.
I know I'm using Vista and Razer may not have it down pat yet, but 4-5 months should be plenty of time to have this problem fixed.
EDIT: just uninstalled the drivers and now the buttons work. ...wth... but whos arguin', now I can lay the smackdown once more. ja rly ;}
TJS
I know I'm using Vista and Razer may not have it down pat yet, but 4-5 months should be plenty of time to have this problem fixed.EDIT: just uninstalled the drivers and now the buttons work. ...wth... but whos arguin', now I can lay the smackdown once more. ja rly ;}
TJS
You do know that you can assign a macro to the buttons don't you.
When I've had problems in the past with Razer drivers, I've just assigned used a bind to assign a key to the side button. For example if I was doing it in CS:S....
1. Assign "x" to mouse4 or mouse5 (can't remember what no. the side buttons are) in the Razer control panel.
2. In CS:S - Bind "x" "Mouse4" and hey presto, it works!
I did try the macro using the 'j' or 'u' buttons when the drivers were installed, but it was a no-go. I also assigned the 4 button (front of the two thumb buttons) as another 'advanced scrolling' button and that worked once, but upon restart didn't work again. But if it works with no drivers I guess thats a bonus.
Will try the drivers again though since I want to be able to fine tune my meese's speed...
TJS
Will try the drivers again though since I want to be able to fine tune my meese's speed...TJS
Linky
