Evoluent Vertical Mouse 3 (Rev 2)
Testing - results
Published: 2nd July 2007 | Source: Evoluent | Price: |
I used Evoluent's own software for button assignment. "Evoluent Mouse Manager" was very good and worked fine with Windows Vista, which is more than many companies can say about their software.
Adobe Photoshop detailed photo-editing
Using the mouse in Adobe Photoshop was very smooth and precise. Turning up the DPI to 1300 helped, but I found 1800 and 2600DPI far too sensitive for this work.
The mouse was comfortable to use and being able to assign buttons to different tasks in the Evoluent software was handy.
Macromedia Fireworks banner making
Fireworks was much like photoshop. The mouse performed very well and was very smooth. Again the higher DPI adjustment was not needed.
Microsoft Office work (general including Outlook, Excel, Access, Word and Powerpoint)
Using Office for general spreadsheet/word processing was again a pleasant experience. I really noticed that using the mouse made it more comfortable when entering data in tables and editing spreadsheets for a long period of time.
General web browsing/article writing
Again general web browsing was made more comfortable by the Vertical Mouse 3, with one exception. I found that quite often I found myself pressing the silver thumb button on the mouse - specified as back (as I do on all my mice). This button is too easy to push in and so a couple of times I went backwards when I didn't mean to.
This aside, the third finger button at the bottom is very useful once you get used to it and this further enhanced my browsing experience.
Gaming: FPS - Counter Strike: Source
Gaming on the Evoluent Vertical Mouse was pretty hard to get used to at first, but some perseverance eventually paid off and I was fragging away as normal (albeit my normal poor standard!). The mouse glides pretty smoothly over the surface and I found that 1800DPI was the best point for my fast-twitch gaming. 2600DPI saw me over-shooting the mark and it was basically impossible to play the game.
Although the Vertical Mouse isn't specifically designed for FPS, if you're a bit of a part time player the mouse certainly shouldn't affect your game after you've gotten used to it. I would even say that the button assigning helps you out as that third finger button is right where you need it.
Gaming: RTS - Command and Conquer 3
Gaming in Command and Conquer was also pretty nice, but the one thing I really missed was having on-the-fly DPI switching. It's very useful in CNC3 to have this as it allows you to scroll the whole screen in one movement. This aside, the mouse was smooth and responsive and a pleasure to play for long periods...without arm-ache.
Surface testing
Icemat v1
The Icemat v1 was a good choice to use with the Vertical mouse and it glided up the smooth surface with ease, even without teflon mouse pads. At higher DPI's, however, the hard surface meant that the mouse was far too twitchy.
Free hard surface mousemat
The free hard mousemat I have is a good indicator of whether a mouse can work on all surfaces. The Vertical Mouse took it in it's stride and tracked well across the surface once again.
Office type cloth mousemat
To simulate office use I borrowed a cloth mousemat from the office. The Evoluent mouse again was comfortable and the higher-DPI settings seemed easier to use on this surface. It's a bit of a shame that I didn't have a gaming grade cloth surface as I feel this would be perfectly suited to the Evoluent Vertical Mouse 3.
Testing Summary
The Vertical Mouse stood up to all of our testing very well and I was impressed with it's versatility. Perhaps not the very first choice of mouse if you are a hardcore gamer, the Vertical Mouse misses on-the-fly sensitivity changing and perhaps suffers from a little over-zealous thumb button.
These points aside I the mouse performed well in testing.
I looked at getting a vertical mouse some time ago but though it might be a bit of a novelty... Seems to work pretty well.
Decent review
Decent review
Cool mouse.. Don't think i'd want one though.. As much as the normal mouse is the same and boring, well, i'm the same and boring so it suits me well
Also good review.. I think i'd find it quite hard to come up with 5 pages on a mouse.
1 typo though
The mouse was comfortable so use and being able to assign buttons to different tasks in the Evoluent software was handy.
Edit: Page 4 just incase ya feel like changing..
1 typo though
You would think the hand model would cut his nails before getting the picture taken. It may look silly, but kemp you planning to use it full time?
Also good review.. I think i'd find it quite hard to come up with 5 pages on a mouse. 1 typo though ![]() The mouse was comfortable so use and being able to assign buttons to different tasks in the Evoluent software was handy. Edit: Page 4 just incase ya feel like changing.. |
Once UT3 comes about I may switch back to the G5
already wanted to get one of these and now after reading this good review I want one more so - but price is so steep.
Found out of stock for £57, but even that is too much really.
Check out the Evoluent mouse friendly keyboard - with the numeric keypad on the LHS.
Thanks for the review Matt, that's interesting as I was just looking into getting one of these. I've had rsi problems on and off for a few years now, my old ball mouse (yes!) is getting really ropey, but everything else I try seems to make the problem worse.
From the screenshot it looks like you can customise the buttons for different apps. If that could include the dpi setting then that'd solve your res changing issue.
Has anyone found a Uk supplier of these at reasonable cost? They're available from the States on Ebay for around £45, but i'm not sure I want to risk the tax lottery on this one.
Hmm, at those prices it's probably worth importing one.
Incidentally, the VerticalMouse's developer is suing Microsoft over the design of their Wireless Laser Mouse 6000. See here.
Perhaps if he wins the price will come down a bit!
Find out who, and what and indeed why inside...
click
