Zotac GTX680 AMP! Edition Review
Up Close
Published: 8th May 2012 | Source: Zotac | Price: |
Up Close
The packaging leaves no doubt as to which version of the card you're picking up. The AMP! is writ large and proud, dominating the front of the box, which is resplendent in the usual Zotac black and yellow.
Opening up the box we find the card safely contained in some high density foam. For the accessories it's all fairly standard stuff with adaptors and things, although the inclusion of the Assassin's Creed titles will guarantee a lot of gaming excitement even if it's your first ever GPU and makes a nice change from Dirt 3.
And here she is, positively bristling with vents and heatpipes. Whereas the reference design cooler is a single fan, two-slot affair, this is much larger with two fans, multiple heatpipes and it's two and a half slots wide. Worth noting for those of you thinking of going SLI with a smaller motherboard size.
We considered the GTX680 to be one of the finest reference coolers in a long time, but there is no denying the eye-catching splendour of the AMP!. Swathes of chrome and copper wherever you look. Hopefully the performance will be worth the audaciousness of the Zotac design.
Other than the cooler with it's huge fans and heatpipes spilling out the sides, things are normal at both input and output ends. It still only uses two 6pin PCIe power inputs, and still has the same display output options of the standard card.
Love the look of this Zotac card... one of the sexier looking GPUs I've seen so far this round.
I like the heat pipes and the orange fans on this card, performance ain't to shabby either.
Still can't wrap my head around some of the stock, stock oc, AMD and NVIDIA, amp, amp oc results tho. The comparisons just don't make sense.
Cheery Oh Tom.
Maybe with silver heatpipes... Looks a lot like a ghetto mod to me. But the temps are nice
Just read a review on another site and they said it's going to be about £300, which is confusing, but true. Thats around £100 cheaper than the 680 yet it's a faster card
£320 from Aria
http://www.aria.co.uk/Products/Compo...roductId=49839
The 670 overclocked beats the 680 Just read a review on another site and they said it's going to be about £300, which is confusing, but true. Thats around £100 cheaper than the 680 yet it's a faster card £320 from Aria http://www.aria.co.u...productId=49839 |
Today we take a look at one of the fastest factory overclocked cards around, the Zotac GTX680 AMP!
Continue Reading
