XFX Radeon 5750 XXX Review
Gaming Benchmarks
Search Reviews
Gaming Benchmarks
3D Mark Vantage
The Performance test in Vantage is the default benchmark that most people use. Of course the resolution and image quality settings leave a little to be desired, but nonetheless it will be a good test to see how the overclock fairs against the standard speeds.
There is certainly a benefit to be had with 1000 point P-Score improvement from such a relatively small overclock shows that this card could indeed be quite a go-er.
The High preset is much more representative of the average users gaming life though, running at 1680x1050 and with 2xAA it is about the settings most of you will run.
Here we can see that a good overclock is necessary to produce barely playable results and the stock settings really show the limits of the card.
Dirt 2
Dirt 2 is, as we've often mentioned, a great game for testing because the graphics engine used is well optimised and responds well to even average hardware.
The results are stark, with the overclock that gave such a good boost in 3D Mark barely making a dent in the real world and the maximum frame-rate being unchanged. As we said earlier the mark of a card isn't solely in its GPU speed, and never is this more obvious than in this graph.
Crysis Warhead
Crysis Warhead, as we're all aware, is a game far more dedicated to Physx based GPU solutions and so the immense 4GHz clock of our i7 870 is really where most of this score is coming from. The graphics aren't so amazing that the 5750 XXX is really struggling and a 30FPS average for a card priced around £125 isn't bad at all.
Modern Warfare 2
Having exhausted two very graphically intense games we'll move down to the kind of game you'd expect to be able to play on a card such as this, starting with the always popular IW COD Modern Warfare 2. It's console roots are apparent with maximum in-game settings producing a frame rate above 60FPS even on our 'stock' 5750 XXX and getting a nice boost in the minimum frame rate from the overclock.
GRiD
If ever a game absolutely is at home on a particular architecture it's the combination of GRiD and ATI. It adores ATI hardware so much we reckon you'd get 60FPS from a red hamster wheel.
So it proves here with the XFX 5750 XXX not even going below 60FPS minimum despite intentionally running at the back of a huge field around the harsh San Francisco circuit. Impressive.
Time for a conclusion.
«Prev 1 2 3 4 5 6 Next»
19-03-2010, 06:52:15
tinytomlogan
VonBlade takes a look at the XFX Radeon 5750 XXX does all the X's make a difference?
Continue Reading
