XFX GTX295 PCIe Graphics Card
Published: 10th February 2009 | Source: XFX | Price: £401.35 |
In our latest reviews we have run the i7 at stock speeds as this, for the most part, has been more than enough to ensure we did not encounter CPU limitation. However, the rules have changed with the advent of NVidia's latest Dual GPU creation from XFX. Even 2.66ghz on Intels latest CPU cannot unleash the power of the latest range of GPU solutions from both ATI and NVidia.
The current undisputed king of performance is the mighty 4870x2. It has consistently held off the GTX280, most recently the GTX285 but now the scales are balanced, 2 cores vs 2 cores, mano a mano. In a no holds barred, head to head stand off we pitch the best against the best, card against card to see who holds the winning hand in an OC3D clash of the titans. The 4870x2 served as a trumpet call for Nvidia to up there game a notch who, despite a delay in response, have finally retaliated with their own dual GPU card.
Ok, thats enough of the cliches, time to get down and dirty with our challenger (sorry), the XFX GTX295. Nvidia, as with all there previous dual GPU cards, have taken a different approach to ATI in that each GPU has its own PCB rather than having both GPU's on the same PCB. While some may argue it is two cards sandwiched together, others will state it is still a single card. Whichever your preference, there is no doubting that 'SLI on a stick' now works much better than previous incarnations, proven by the phenomenal 9800GX2. Quad SLI still has some issues that required attention so it will be interesting to see how the 295 performs with another card in Quad SLI, something we will be covering in a future review.
Here's what XFX had to say about their latest card:
KEY FEATURES
* 2nd Generation Unified Architecture
* DirectX 10 support
* Quad SLI capable
* PureVideo HD technology
* NVIDIA PhysX-ready™
* NVIDIA CUDA technology
* PCI Express 2.0
* Dual-link HDCP capable
* HDMI Certified
* OpenGL 2.1 support
Specification
Interface: Interface PCI Express 2.0
Chipset: Chipset
Manufacturer: NVIDIA®
GPU: GeForce® GTX 295
Core clock: 576MHz
Stream Processors: 480
Shader Clock: 1242 MHz
Memory Clock: 2000MHz
Memory Size: 1792MB
Memory bus: 896
Memory Type: GDDR3
RAMDAC: 400 MHz
Features: 3D API, DirectX DirectX 10, OpenGL OpenGL 2.1,
Ports: DVI 2, HDMI 1, TV-Out No, VGA No
Max Resolution: 2560 x 1600
RoHS Complian:t Yes
SLI Supported: Yes
Features: CUDA Technology, PhysX Technology
Weight: 2 lbs
Dimensions: 10.5“ X 4.36“ X 1.5“
Profile: Dual Slot
Package Contents: GX-295N-HHFF, DVI Adapter, S-Video Component Adapter, 6 Pin Y Power Cable, SPDIF Cable
Game Bundle: Far Cry 2
As the card is a vanilla version based on the Nvidia reference design, all the clock speeds are set to stock levels but no doubt XFX will be releasing a number of overclocked editions if history is anything to go by.
Let's take a look at the packaging and presentation of the graphics card...
CPF would push me towards a 4870x2
ATI then Nvidia, then ATi then Nvidia.. And the fight goes on.
Cant find the price of this specific card, not that I did a huge in depth search but:
Sapphire HD 4870X2 2GB GDDR5 £340
BFG GTX295 1792MB DDR3 £440
Zotac GTX295 1792MB DDR3 £420
EVGA GTX295 1792MB GDDR3 £433
All those prices from ebuyer. Are the 295's really worth THAT much more for so little performance boost - especially considering the only benefit of the 295 seems to be at high resolution with lots of AA?
For me if it were my bucks on the line, not that I am looking for new graphics right now, I'd say no way hosé.
Well if you are going to be running at those high resolutions, then we can expect you to have an expensive screenie and be willing to pay the £100-ish more for the higher AA capabilities.
were not taking price performance ratio...yes the cost is an issue...but you dont play down the baddest boxer in the world cos his mrs says hes crap in bed...yes for most of us mortals this will be an issue...but when it comes to manufacturers reigning top spot performance is the only issue...bragging rights are everything...still I see no reason to shift from my gx2 yet...and yes that is a price related statement...but its a beast of a card...lets see how long nvidia can hold it...because AMD/ATI are seeming to be closing the gap in many many areas
The thing is though, it is NOT the baddest boxer in the world. The x2 pimp slaps it in 3dmark`05 and 06, Its even holding its own in a physx enabled game - UT3 - quote "All the games above, even the PhysX enabled UTIII favoured the 4870x2, that was until the resolution was increased and AA applied".
More standard resolutions and the 295 looses out not by a little but by a lot, its only at 2560x1600 and 4AA that 295 seems to have a lead, and then thats not the case in Grid. And I'd be willing to bet that if you used those resolutions and that level of AA then the game would jitter and lag anyway - you know how it is, fighting away, hear a sound from behind so you spin about quickly - the game lags temorarily etc etc..
As for bragging rights? I'd chuckle if a friend say they bought this, its no performance gain really, it looses out by a big margin at resolutions the majority use.
Waste the £100 extra, many will, if it were me I'd wait for a card which blows the other out the water THEN cough up the money. Not for a trickle of extra (and I bet real world unusable) performance.
24" is quality aspiration for most imo. Whilst 20" is a solid standard.
I do think it's about time the 1024x768, and possibly even 1280x1024 were less concentrated on for runs or standards for benching tools.
Believe OC3D use a pretty good range of resolutions for their tests. The 2560 ranges are quite silly to be fair, but interesting.
*peers at w3bb0's monitor*
*drools*
*claws screen*
:D
Bear in mind, the people likely to buy the highest end kit will probably have other high end kit e.g. that 30" monitor. If you think the 4870x2 drivers have had more time to mature, its not surprising the 295x2 drivers are a little behind
Lookup how much the Dell 30" costs, I`d be half as likely to own one of those than a 295x2.
I'd not see much point in going for a cheap 30" that just upscales a 24" screen.
Quality 24" are more like the similar price for top cards.
However, both these cards are Flagship products. Products that advertise who is best. It's willy waving at the most extreme scale. At the moment that title goes to Nvidia, recently it was ATI and no doubt when the 5 series arrive ATI will reclaim that crown. This is great news for us, the consumer as competition is healthy.
Whether you 'need' these cards is pretty much irrelevant when it comes to enthusiasts. I mean who really needs 24gb of ram and a 4ghz top of the line cpu. Very few, if anyone actually needs that kind of power but it doesn't stop us all from WANTING.
I want a Maclaren F1. Do I need one? No but if I could afford one, it would be highest on my shopping list. Not so much for bragging rights (ok maybe it would be a little bit) but because 'it's the best'.
Nope. Unless I was given one perhaps.
I don't have any extreme prejudice against the ATI camp for the sake of it, for me it's all to do with confidence in the product in so much as I install it and anything else I do to it maintenance wize will be looking to improve the performance over an existing stable platform.
nVidias drivers do go through their rotations, but if the ccc were as-good, I'd have no hesitation. And to be fair I hear they've vastly improved over the last few years - needless to say, improved and being as-good are two different things.
Plastic benchmarks and claims of the likes of 4870x2 don't impress me tbh.
Time spent messing on a pc costs money too, more importantly time u can't get back for a priceless amount. Spend £150+ more for the card ? For me, if it means this priceless time is not lost - then yes.
