XFX Fatal1ty 8600 GT Professional Series
Test Setup and Notes
Search Reviews
Test Setup
The setup is:
CPU: Intel Core2Duo E6700 @ 3.33Ghz
Motherboard: XFX 650i Ultra
RAM: 1gb Mushkin XP2-5300 4-4-4-12
Sound: Creative Labs X-Fi fatal1ty FPS
HDD: OS - 160gb Hitachi Deskstar SATA II
HDD: Gaming - 2 x 40gb Hitachi Deskstars in RAID 0
Power: Silverstone Zeus 560w
Case: Silverstone TJ09
Cooling: Scythe Infinity
Please note that I am comparing this card with the numbers from a previous review on the 8600 roundup (here). The only difference in setup is the motherboard used (previously the FP-IN9 SLI),
I am using a manual run-through of the games listed, exactly the same as in previous reviews, but doing it slightly differently to get some consistant numbers. Notice that for all games I ran through at 1280 x 1024, with the same amount of AA and AF on each game. For all of the 3Dmark benchmarks I did two runs. One run was with the stock settings that the free version of the benchmark comes with and one was with 2 x AA @ 1680 x 1050.
For installation I have installed the cards as usual with the normal PCI-E power dongle (or not as required), checked that the card is seated correctly and powered on.
Note that the cards height was not an issue in my TJ09, although you may want to check the size specs as it is a little larger than a normal card @
I am using a clean install of Windows XP Professional SP2 with all the latest patches.
nVidia drivers used were 158.22
ATI drivers used were Catalysts 7.4's
Cards
XFX Fatal1ty 8600 GT Professional series Clock Speeds: 620. Memory Speeds: 1600 (800). Stream processor Clock: 1355MHz
XFX 8600 GTS "XXX" Edition Core Speed: 730. Memory Speeds: 2260 (1130). Stream Processor Clock: 1595MHz.
Foxconn 8600 GTS Core Speed: 675. Memory Speeds: 2000 (1000). Stream Processor Clock: 1450MHz
XFX 8600 GT "XXX" Edition Core Speed: 620. Memory Speeds: 1600 (800). Stream Processor Clock: 1355MHz
«Prev 1 2 3 4 5 6 7 8 Next»
01-07-2007, 15:27:18
FarFarAway
We had a scoot around the 8600 series in May, now it's the turn of XFX's impressive looking Fatal1ty Edition card
Have a look-see
01-07-2007, 15:37:24
MikeEnIke
Nice review Kemp. Impressed, it put up a nice fight.
01-07-2007, 16:09:38
Rastalovich
Excellent review as expected Kemp.
It`s a decent performer, and gives u the cooling benefits, if that`s the solution u`r after. @ ~ £111, I don`t think u can go that wrong tbh, cards in that bracket are only give or take a small sum.
The packaging does seem disappointing. Package clutter doesn`t cost the company anything at all, and promo stuff especially. Infact the XFX 7600GT 580m is packaged a whole lot better and is obviously an older card.
What impresses me most is the clocking of the Foxconn GTS card - but that detracts from the topic I guess >.<
If XFX are fishing for some impressive feedback, the backplane slot needs a bit of `tarting up`. Something as simple as XFX 8600 GT Fatal1ty in a green raised stamping on their black background would not only promote the card visually, but further seperate it from the mainstream. From the back as it stands, it looks like a regular XFX -anything- card.
Another thing, people will be put off with the likes of the 3DMark scores - that`s a shame. It`s not enough to dismiss the card imo, when it performs obviously better in `the real world`.
(oh and correct the reference to an 8700 on page 4, I got overly excited when I saw that)
01-07-2007, 16:10:18
flib
Nice review!
The clocks on that thing seem to be huge compared to stock, I'm suprised it can pull it off as much as it does being passive.
01-07-2007, 16:18:15
FarFarAway
I know, it's a pretty good job
@Rast - the foxconn OC's more as it is a stock-clocked card. People generally would rather buy the fastest out there but the small enthusiast overclocking segment would (and should) buy the cheapest and OC that
Still a nice cooler like this one gives you a great reason to buy the card
01-07-2007, 16:24:50
Ham
Nice too see a product baring his name that isnt cack or really expensive
02-07-2007, 04:52:10
PP Mguire
Idk, the keyboard is nicely priced, and you can get the mouse for $20 on Ebay. Before i broke mine i thought it was an excelent mouse.
I would have to say though that i see a flaw on page 2 Kemp. The cooler looks like a modified version of the one i have and if thats true the memory is not cooled at all.
02-07-2007, 05:07:31
PV5150
Well considering that we never see a 'heatsink off' image in the review, I don't know. But I'd like to speculate that the heatsink blades on either side of the Fatal1ty logo are there for cooling the memory.
http://upload.overclock3d.net/get.php?id=3180
Edit: Well yes it is actually cooled according to the image.
02-07-2007, 07:26:48
FarFarAway
Yep the memory is cooled, can you see any IC's bare in the pics?? No
02-07-2007, 07:48:04
Rastalovich
That`s a very simplistic hs when u see it like that.
02-07-2007, 11:58:04
Gibbs
anyone happen to know how wide this card is as am looking it to put into a Lian Li PC-V600
02-07-2007, 16:22:57
Nagaru
Nice card all thought those 2 heatpipes that connect to nothing are useless, stupid engineers who know nothing of thermodynamics.
One thing I am not sure about is this.
The 8600GT has two Dual Link DVI ports for output as well as an S-Video out. It's at this point I will remind you that no HDTV connection is included, which is a shame. Having said that, the DVI ports are both HDCP enabled so you should be good to go if you want to connect to your HDCP enabled HDTV...if it has DVI-in.
If the card has HDCP, wouldn't a simple adapter cable allow it to be fully compatible with HDMI televisions?
02-07-2007, 16:50:55
FarFarAway
Yes, but it isn't included, which was my point
02-07-2007, 17:20:27
Gibbs
Kempez could you take a few measurements
02-07-2007, 17:22:26
FarFarAway
Umm sure, which way? Has to be quick, tis going back 2moz
02-07-2007, 18:47:04
Gibbs
from within the yelow markers please
http://img526.imageshack.us/img526/5...401104lfe9.jpg
thanks
02-07-2007, 18:54:20
FarFarAway
Thats about 140mm
03-07-2007, 05:25:40
Gibbs
thanks bud
06-07-2007, 22:43:20
AmBush
Until las night i was gonna go for the XFX 8600 GT XXX but after reading the review (normaly skip to conclusion magazine or ezine but not this one)
Its left me with a dilema now I will Watercool GPU(s) in the not too distant future, once i get my feet wet.Would it be worth Going SLi on this then liquid cool eventualy OC?
Since i've been reading the forums i am gettin more tempted (its taken me 10 years to put a multimeter on my PSU)
My current setup is 2 year old being on benifit its hard to keep up but OC'ing will help.Or would i be better off spending the same £ on One card? I Have more questions but i'll limit them
07-07-2007, 05:38:49
Toxcity
As usual an awesome review MR Kemp!
And isn't that card very very pretty!
07-07-2007, 14:05:13
PP Mguire
Hah! Must be nice, considering i have a bigger one on my video card and my memory is not being cooled at all.
07-07-2007, 16:40:45
FarFarAway
Ye like I said, it's a pretty well designed cooler
08-07-2007, 04:25:51
PP Mguire
Mine is to, cept i dont have memory coolers!! *Curses at XFX for beign so good yet so bad*
09-07-2007, 09:55:13
AmBush
I'm just going round in circles i've been trying to find the answers myself http://forum.overclock3d.net/showpost.php?p=152323&postcount=19
XFX Fatal1ty 8600 GT Potential for more oc'ing with liquid
v
XFX 8600 GTS XXX Massivly oc'd already.
I'd appreciate some input i'm lookin to spend £250 on 2xSLI or One card
Cheers.
09-07-2007, 10:15:38
FarFarAway
For one thing: SLI isn't worth it, save your money and get a decent single card.
As for choice between the two - they're clocked the same, but if you're watercooling you may as well get the cheapest
09-07-2007, 10:31:03
Rastalovich
Ya for the price of 2 x 8600GT, I`d rather 1 x 8800 tbh.
But for a selfish reason, I`d like to see how the 2 x 8600 get on >.<
09-07-2007, 10:31:53
MikeEnIke
Plus, you can always throw another one in if it gets to that point
09-07-2007, 10:34:57
Jim
As others have said, SLI on mid-range cards is deffo not worth it. Just go for the best single card you can.
Only if you have an 8800GTX and a wad of cash burning a hole in your pocket, with absolutely nothing else to buy, should you consider SLI.
09-07-2007, 15:41:25
AmBush
Oki I Think ONE monster card will be the plan as MikeEnIke says always got scope to add another later.
Ya for the price of 2 x 8600GT, I`d rather 1 x 8800xx tbh.
I'd be interested too Tom's Hardware hasn't got 8600's on the list either
Cheers p33ps.
Time to hunt for 8800xx http://upload.overclock3d.net/get.php?id=3100&view=1
23-07-2007, 22:11:57
PP Mguire
Ohh just to clarify and correct one thing, the Fatal1ty DOES have the modder friendly warranty.
