XFX 9600GSO 384mb vs Sapphire HD4670 512mb
Search Reviews
Life is so much easier when things are labelled correctly don't you think? A Sweater, XL for me please. A car, I'll take a 3.0i thank you very much. A mid range graphics card....er, now I'm lost. You see, I honestly believe ATI and more to the point, NVidia, are slowly running out of numbers and letters to label their cards. So much so, in fact, that the mid range area of the GPU market is so muddled it is hard to separate the chaff from the wheat. Take the two cards up for review today - the 9600GSO and the HD4670 are both mid-range cards that don't follow suit in the general scheme of things, but instead spawn a new mid-high-mid range that only NVidia and ATI themselves can decipher. So as the dust settles at the top of the pile, a new war is waging in the bread and butter mid-range sector where both these cards are aiming to be top dog in their own department.
 XFX Logo
In the green corner may I present to you the XFX 9600GSO. The card is currently priced aggressively at £69.31. Although the 9600GSO is a new addition to the NVidia lineup, it isn't exactly new technology. The 9600GSO shares the same technology as the 8800GS, which was a slightly cut-down version of the mid/high-end favourite, 8800GT. While this may seem annoying to those who thought they were buying into new technology, it is a stroke of genius from NVidia and possibly a great bargain should it perform anywhere near that of the 8800GT, especially considering it weighs in at a paltry £69. Nvidia then it seems, are sticking to the tried and tested method of offering cut down versions of last generation (but high performing) GPU's at a knock down price. It will be intriguing to see if this was a wise move with ATI spreading their new technology across the range.
 Sapphite logo
In the red corner and costing a little under £5 less than the NVIDIA card at £64.59, we have the RV730XT, otherwise known as the HD4670 512mb version from top tier ATI partners - Sapphire. A new card based on the same 4000 architecture as the mighty 4850 and 4870 cards which have all seen off NViIDIA competition at the higher end of the market. It will be interesting to see if it can do the same with a trimmed down version. Having the same number of stream processors as the HD3870 and a similar core to the 4870 should see the HD4670 perform quite well. Especially when AA is applied to games which is unusual for a mid range card as this is an area where they tend to suffer. With an estimated price of around £60 this could out-strip the 9600 GSO as the bargain of the year should it match its low price with high performance.
Specification
So then, the scene is set and the battle lines are drawn. While the two top tier manufacturers' get rubbed down in preparation for the head-to-head benchmarking, lets take a closer look at each card.
 As per usual, ATI cards are clocked much higher than their NVIDIA counterpart. The interest for me however is whether the 512mb of memory the ATI card has will offer much of an advantage over the GSO. The Sapphire also has many more processors than the XFX card and along with an improved fabrication process, the Sapphire card looks to be a very strong contender.
Lets take a look at each of the cards in turn, starting with the XFX 9600GSO.
«Prev 1 2 3 4 5 6 7 8 9 Next»
23-09-2008, 00:15:08
Zoot
I'm just after looking at Komplett.ie and I can get the 4670 for €78 and the 9600GSO for €87. In the interest of Linux drivers I think the 9600 would be the better buy for me, if I give it a bit of time that is....
Anyway another great review btw. :)
Just curious, do you find reviewing fun or is it pretty routine after a while?
23-09-2008, 23:44:04
x-thing
Hello, first post for me in this forum, nice to meet you all!
Registered because I found this review curious, and it's not only this one about the 4670. I think that in the rush of comparing price and performance, many reviewers usually put against the HD4670 the 9600GSO, forgetting other fundamental things;
1-the cards are of totally different sizes and the 9600GSO won't fit many standard OEM cases while the 4670 will.
2-The HD4670 consumes far less power, with no 6 pin connector, so I'd not consider an aluminum heatsink mediocre when power consumption is also mediocre compared to the rival card.
Despite being similar in price or performance, I think we're comparing very different cards, for different target buyers. With the 4670 you can be sure you can upgrade almost any HTPC or any Dell or HP case, without worrying about your card intersecting something. The HD4670 is maybe the most important card of this year because after the HD2600/3600 and GF8600 fiasco, it's the first mainstream card in mainstream format in a long time (small PCB, no 6pin power) and it's most direct competitor should be the 9500GT (which is not) while the 9600GSO is better aligned with the HD3850.
In this perspective nvidia is still sadly falling short of the objectives even in the midrange and as of direct competition, I'd rather see the HD4670 leading alone for the moment.
23-09-2008, 23:57:45
Zoot
Welcome to the forum x-thing. :)
Yeah it's pretty much Red all across the board atm.
Nvidia took a right chance with the GT200 with its huge die size - it's not exactly cheap for the them to make, and thanks to their price drops you can be sure they're not selling them for much of a profit anymore.
ATi's RV770 was a much better chip in many respects, it performs great and it's a lot cheaper for the them to make (55nm V 65nm and a much smaller die).
25-09-2008, 16:52:34
w3bbo
You make some good points X-thing, welcome to the forum too!
While I agree the cards are different sizes, the performance and price are still similar which make for a valid comparison. I agree that they could be considered for different markets, SFF being one of them and as such this was also mentioned in the review. However, when someone goes shopping, especially someone not willing to spend vast amounts of cash, will surely want to see how much performance they can get for their cash, bang per buck as it were and so the cards were compared on this basis.
I criticised the use of aluminium as if they had used copper then the fan might not have spun up so fast, making for more efficient cooling properties. As you previously pointed out, buyers of SFF and media centers etc may well be considering this card. If it were me shopping for such a card, I would want a near silent cooler, which sadly the 4670 has not, due in part to the aluminium heatsink.
We couldn't really compare the 9600GSO against the 3850 as that card is previous generation so would be unfair and to be quite honest uninteresting. Apart from the fact, we do not always have every card in this and the last generation from which to choose.
26-09-2008, 22:44:38
x-thing
Yes webbo, I completely understand your reasoning; price and availability rule when it comes to the common buyer, and I totally agree here.
Not particularly this but as I said before, many other sites the put the 4670 too much on the personal with the GSO. Yes especially where I live or in the USA it is an absolute steal, however, there are other scenarios the 4670 is the way to go and maybe that could have been made clearer in the conclusions, because it's there that most people jump before reading the whole review and sometimes it does not just "come down to what screen you are looking to game on"; I couldn't use my HD3850 in my sister's 350W PSU PC, and had to swap it with a 4670 first. People seeking quad display with graphics performance will get lots of power savings and cooler systems with two of them compared to two 9600GSOs or 3850s.
The fan is loud, yes, that aluminum heatsink is Sapphire's way to spare some money,the stock cooler is much better. I have also seen a dual slot version from asus, big silent fan on top, that should be nice for HTPCs.
Anyway, let me say that your review was very precise and well made,was interesting to see the slight superiority of the 9600GSO, with the 4670 taking over @ high resolutions, probably because of the 512M of RAM vs 384 of the GSO.
P.S: Just a small question on the sapphire cooler, was it loud or very loud, because I think this is the model I am getting to replace the 3850.
27-09-2008, 09:15:38
w3bbo
Noise is subjective m8. I wouldn't say it would be 'louder' than the 3850 but due to the fans size you may notice it more because of the whine, especially when it is under load. In windows it was fairly quiet, just a slight 'hum' but as soon as you did something 3D intensive and the fan spun up it resembled a very angry hornet.
27-09-2008, 15:27:03
Rastalovich
Apparently, the ATI card draws less power under full load. Whilst at idle, the nVidia draws less.
If u turn ur pc on, play a game, then turn off - the ati draws less power.
If u have ur pc on, browse, do simple desktop stuff, leave it on, play games, then leave it on or off really - the nVidia will draw less power.
28-09-2008, 00:36:33
x-thing
That is because ATi hasn't fixed that stupid powerplay driver on the 4000 series, maybe they did it with the last catalyst 8.9.
18-10-2008, 01:32:00
deamon1311
ok folks i have enjoyed my new hd4670 greatly.
i tried out the ati overdrive utility yesterday and i will post my highest stable overclocks below.
core: original:750mhz final:860mhz
memory: original:2008mhz final:2320mhz
note: i am willing to bet others on this forum with better tools could likely put my overclocks on this card to shame.
ive found that this card is a great preformer.
ps: i tested the cards overclocks with several hours of playing oblivion and unreal tournament 3 i had no artifacts or problems.
im out for this post and i wish you guys the best of luck with you overclocking adventures!!
20-10-2008, 12:29:15
x-thing
I'd rather think you've been quite lucky with that card because more or less all review sites around have not been able to get much further of 800 MHz for the core and 2100MHz for the memory. What brand was it?
