XFX 8800GTS
Introduction, Packaging and Package
Published: 18th December 2006 | Source: XFX | Price: |
We've already taken a look at nVidia's G80 in a previous review of the 8800GTX and now it's the turn of it's little brother the 8800GTS. Heralded as the "best bang for buck" currently available with DX10 compatability, the 8800GTS looks to be a killer card at a half-reasonable price.
Today we're sizing up XFX's 8800GTS to see how it performs.
Packaging
XFX have always had striking packaging and this time is no exception with it's mascot showing on the front of the box in quite a striking way contrasted against a white background. No actual pictures of the card on the front but turn over and you have some relatively useless info along with the 8800GTS in all it's glory.
Package:
Here's what you get when you purchase this high-end card:
• S-Video > High Def Conponent Cable
• S-Video > S-Video Cable
• 2 x DVI > VGA Converters
• Quick Install Guide
• TV-out Quick Reference Guide
• XFX "Play Hard" Tips and Techniques
• X-Gear Mini-catalogue
• Driver CD
The package XFX is giving out with the 8800GTS is slightly lacking in the software department. With only a driver CD in there you feel a bit lacking when you open the box. However upon speaking the the XFX rep about this he has said that they are encouraging their retail partners to include some sort of games bundle with the cards such as Splinter Cell. This seems to not be the case now, but it was at release.
There is plenty enough on the hardware side to satisfy anyone wanting to hook this up to a TV but once again an inclusion of some sort of DVD software would have boosted the bundle.
Somewhere along the line I was wishing u`d take a screw-driver to those coolers, the pcbs look almost identical asif these guyz are working extremely close together. Like in the same building :p
I see many are already posing whether it`s better value to get a base card and do all the clocking uself. Meh.
Great review Kemp.
They're all the same as the reference boards i expect.
As for the clocking we can oc the core but not the stream processors:(
I took the 8800GTX apart in that review.
If your particularly interested I could take apart another GTS and post some pics?
And ye you can OC the core clocks/memory clocks but I haven't found a way of doing the stream processors yet
If I`m the only one looking for hardcore up-cooler shots, I wouldn`t bother, if I do some searching there bound to be something out there ;)
i use ATitool for my oc'ing and you can have it load the oc on startup and it tells the temp... i have mine running at 640/1000
havnt seen the temp go above 70*c yet cuz i got some insain air fed to my card at all times... two 80mm fans and a 120mm all blowing on it
