XFX 8800 GTS 320mb Fatal1ty Edition
Overclocking
Search Reviews
Overclocking
Overclocking on the nVidia cards was performed using Rivatuner Release 2. Overclocking on the HD 2900 XT was performed using the AMD GPU Overclocking Tool.
A test run of 3DMark06 was performed after the overclock to verify stability and also if the OC was worth the time.
Note that no hard or soft mods were performed on the card apart from setting the higher clocks.
Results
Here's what happened:
overclock graph
Here we can tell XFX really are taking the GPU to it's limits with a slightly lower overclock than we are used to seeing on an XFX card. Having said that we still managed 701MHz core and 2150MHz memory, not too shabby!
3dmark06 overclocked
The run of 3DMark06 shows that although the overclock was fairly small, it still gave us a 662 raise in 3DMarks.
Note that the fan still hardly ramped up during overclocking (I didn't enable this feature in RivaTuner). With some aftermarket cooling like a water-block I think this card could push even more...of course this would void that rather nice XFX warranty!
«Prev 1 2 3 4 5 6 7 8 9 Next»
30-09-2007, 18:29:02
FarFarAway
We take a look at a card XFX claims is the "Worlds fastest 8800GTS"
Does it really live up to the hype?
http://www.overclock3d.net/gfx/artic...180202420s.jpg
Check it out!
30-09-2007, 18:40:31
PV5150
Awesome review Kemp and a great card to boot. Loved the inclusion of the DX9 vs DX10 comparison.
30-09-2007, 18:42:23
FarFarAway
Cheers.
I'm seeing what I can do about getting a more thorough analysis of that, keep your eyes peeled folks
30-09-2007, 19:34:21
darkorb
Nice review man, im still reading it and thought i should post this.
I just won this card on bjorn3d.com, so i am totally excited for it. Would this 320mb version work with my existing 640mb in SLI?
01-10-2007, 02:38:38
FarFarAway
Not sure mate tbh, worth a try I suppose
01-10-2007, 05:15:55
Toxcity
Very good review kemp!
I am loving the DX9 and DX10 comparison, was a suprise!
It would work perfect, as long as you have the card with the smallest amount of memory in the primary slot.
That is what I found to make it work without a BSOD.
Guide
That has some more infomation!
01-10-2007, 05:32:36
Mr. Smith
I enjoyed reading that mate
I also drooled over the dx10 screenies, and was suprised to see the average dx10 (vista) frame frate higher than dx9 (xp).
I may just get vista soon
01-10-2007, 08:00:37
FarFarAway
Guide
Thankd mate and good work, reps for you
DX10 looks awesome at points although generally Bioshock looks pretty damn good anyway
01-10-2007, 10:35:44
Toxcity
Thanks dude!
Only relaying a problem I had with BSODs and SLI with two cards with different memory.
It is amazing what can make cards BSOD.. and what can make them stop.
01-10-2007, 10:59:36
Rastalovich
Not a bad price for such a decent card tbh.
Agree with the missing embossed "XFX Fat" sunken-green-print on the black rear plates. So simple and definately a missed oportunity. XFX should do it tbh, getting a bit tired of the blank black pci-slot feature myself. Looks naff with the shiney silver LL case rears especially.
The less said about the face on the sticker, the better. Be nice to have an OC3D printable sticky label to put over it Easily done with some lazer-label sheets.
Great review Kemp.
01-10-2007, 16:05:01
darkorb
enabling coolbits will stop BSoD if i get any?
01-10-2007, 16:33:34
Toxcity
Catch me on MSN, and I will explain all the details!
08-10-2007, 18:37:07
cube
A bit of a pointless card since the 320MB version is being phased out - the Fatal1ty series are also meant to represent high performance components, not mid range etc. like the 320MB 8800GTS is - it would have made more sense to do either the 640MB GTS or the GTX
08-10-2007, 19:56:32
darkorb
well there is a 8600gt fatality card if im not mistaking, and thats not high performance
09-10-2007, 07:41:04
FarFarAway
XFX and fatal1ty brand are marketed as Pro Gamers Gear. That doesn't mean high or low end, it means things gamers would want to buy. Generally easily marketable high volume products.
A bit pointless? In what way? It beats out 640MB versions easily due to massive out of the factory clocks and Ultra fast shader processors. Some games in the future may need the extra memory but look at the figures, most games out now run fine
09-10-2007, 08:05:47
Rastalovich
Think we were implying so many months ago that cards with 1G on them were pretty ambitious.
Meh guess it depends what u`r doing.
