XFX 8800 GTS 320mb Fatal1ty Edition
Test Setup and notes
To test these high-end cards I set a PC that gives as little of a bottleneck as possible. Please note I am using the numbers from a previous review on the 8800 GTS shootout.
The Test setup used for the 8800GTS Fatal1ty 320mb and the 2900XT is:
CPU: Intel Core2Duo E6700 @ 3.33Ghz
Motherboard: XFX 650i Ultra
RAM: 2gb Mushkin XP2-6400 4-4-4-12
Sound: Creative Labs X-Fi fatal1ty FPS
HDD: OS - 160gb Hitachi Deskstar SATA II
HDD: Gaming - 2 x 40gb Hitachi Deskstars in RAID 0
Power: Silverstone Zeus 560w
Case: Silverstone TJ09
Cooling: Scythe Infinity
The setup for the nVidia 8800 card roundup was:
Motherboard: abit IN9 32x max Motherboard
RAM: 2GB Mushkin XP2-6400 4-4-4-12
Games Tested:
Call of Duty 2
F.E.A.R.
Oblivion
Quake 4
Command and Conquer 3: Tiberium Wars (Sapphire HD2900XT and XFX fatal1ty 8800GTS only)
Bioshock (DX 9.0c path - XFX Fatal1ty 8800GTS Only)
I am using a manual run-through of the games listed, exactly the same as in previous reviews, but doing it slightly differently to get some consistant numbers. Notice that for all games I ran through with 4 x AA and 8 x AF @ 1920 x 1200. For all of the 3Dmark benchmarks I did two runs. One run was with the stock settings that the free version of the benchmark comes with and one was with 4 x AA @ 1920 x 1200.
For installation I have installed the card as usual with the normal PCI-E power dongle. Checked that the card is seated correctly and powered on.
I am using a clean install of Windows XP Professional SP2 with all the latest patches.
Both nVidia cards from the roundup were using the nVidia 97.92 Forceware drivers.
The 8800GTS Fatal1ty Edition card used the nVidia 173.71 Forceware drivers.
The ATI card was installed with the Catalyst Control Center 7.9's.
XFX 8800GTS 320mb "Fatal1ty" Edition. Core Speed: 650. Memory speeds: 2000 (1000). Stream processor clock: 1500MHz.
Gainward Bliss 8800GTS "Golden Sample". Core Speed: 550. Memory Speeds: 1760 (880). Stream processor clock 1200MHz.
XFX 8800GTS "XXX" Edition
. Core Speed 550. Memory speed 1800 (900). Stream processor clock 1500MHz.
Sapphire HD 2900 XT. Core Speed 740. memory speed 1650 (825). Stream processor clock 320MHz.
«Prev 1 2 3 4 5 6 7 8 9 Next»
30-09-2007, 18:29:02
FarFarAway
We take a look at a card XFX claims is the "Worlds fastest 8800GTS"
Does it really live up to the hype?
http://www.overclock3d.net/gfx/artic...180202420s.jpg
Check it out!Quote
30-09-2007, 18:40:31
PV5150
Awesome review Kemp and a great card to boot. Loved the inclusion of the DX9 vs DX10 comparison. Quote
30-09-2007, 18:42:23
FarFarAway
Cheers.
I'm seeing what I can do about getting a more thorough analysis of that, keep your eyes peeled folks Quote
30-09-2007, 19:34:21
darkorb
Nice review man, im still reading it and thought i should post this.
I just won this card on bjorn3d.com, so i am totally excited for it. Would this 320mb version work with my existing 640mb in SLI?Quote
01-10-2007, 02:38:38
FarFarAway
Not sure mate tbh, worth a try I suppose Quote
01-10-2007, 05:15:55
Toxcity
Very good review kemp!
I am loving the DX9 and DX10 comparison, was a suprise!
It would work perfect, as long as you have the card with the smallest amount of memory in the primary slot.
That is what I found to make it work without a BSOD.
Guide
That has some more infomation! Quote
01-10-2007, 05:32:36
Mr. Smith
I enjoyed reading that mate
I also drooled over the dx10 screenies, and was suprised to see the average dx10 (vista) frame frate higher than dx9 (xp).
I may just get vista soon Quote
01-10-2007, 08:00:37
FarFarAway
Guide
Thankd mate and good work, reps for you
DX10 looks awesome at points although generally Bioshock looks pretty damn good anyway Quote
01-10-2007, 10:35:44
Toxcity
Thanks dude!
Only relaying a problem I had with BSODs and SLI with two cards with different memory.
It is amazing what can make cards BSOD.. and what can make them stop.Quote
01-10-2007, 10:59:36
Rastalovich
Not a bad price for such a decent card tbh.
Agree with the missing embossed "XFX Fat" sunken-green-print on the black rear plates. So simple and definately a missed oportunity. XFX should do it tbh, getting a bit tired of the blank black pci-slot feature myself. Looks naff with the shiney silver LL case rears especially.
The less said about the face on the sticker, the better. Be nice to have an OC3D printable sticky label to put over it Easily done with some lazer-label sheets.
Great review Kemp.Quote
01-10-2007, 16:05:01
darkorb
enabling coolbits will stop BSoD if i get any?Quote
01-10-2007, 16:33:34
Toxcity
Catch me on MSN, and I will explain all the details! Quote
08-10-2007, 18:37:07
cube
A bit of a pointless card since the 320MB version is being phased out - the Fatal1ty series are also meant to represent high performance components, not mid range etc. like the 320MB 8800GTS is - it would have made more sense to do either the 640MB GTS or the GTXQuote
08-10-2007, 19:56:32
darkorb
well there is a 8600gt fatality card if im not mistaking, and thats not high performanceQuote
09-10-2007, 07:41:04
FarFarAway
XFX and fatal1ty brand are marketed as Pro Gamers Gear. That doesn't mean high or low end, it means things gamers would want to buy. Generally easily marketable high volume products.
A bit pointless? In what way? It beats out 640MB versions easily due to massive out of the factory clocks and Ultra fast shader processors. Some games in the future may need the extra memory but look at the figures, most games out now run fineQuote
09-10-2007, 08:05:47
Rastalovich
Think we were implying so many months ago that cards with 1G on them were pretty ambitious.
Meh guess it depends what u`r doing.Quote
