XFX 8800 GTS 320mb Fatal1ty Edition
Introduction, packaging, package and specification
Published: 30th September 2007 | Source: XFX | Price: ~£250 |
XFX have somewhat of a reputation to uphold in the video card market. As one of nVidia's biggest AIB's they supply some of the fastest clocked cards money can buy.
Today I am looking at a card they have teamed up with Jonathan "Fatal1ty" Wendell to make. Their "PROFESS1ONAL" series are a set of cards clocked even higher than the rest of their cards, straight out of the factory. With 320mb DDR3 onboard and clock very high, how will it match up to a 640mb card? Let's see...
Packaging
As usual with their Profess1onal series, XFX have gone for the bright red and black packaging on the box. This would definitely stand out on the shelves as it is a striking and interesting design. The flipside, of course, is that XFX insist on putting Fatal1ty's face on everything, which could be enough to put people off.
Package
XFX have put together a nice little software package for the 8800GTS Fatal1ty Edition card. In the box is Lost Planet, which although is not to my taste, is a DirectX 10 game and a fairly big release. I was a little disappointed with the lack of HDTV hardware included but then you have to bear in mind that this is a card aimed at gamers and not HTPC enthusiasts. Also an S-Video adapter is included so most people should be able to get by with this.
Included is:
* Manual and Instructions booklet
* Quick Install Guide
* S-Video guide sheet
* Driver CD
* XFX "Don't disturb me I'm gaming" door sign
* Lost Planet Full game
* 1 x S-Video to S-Video connector
* 1 x DVI to VGA connector
Not a bad bundle by anyone's books and it should please those who are wanting to buy the card anyway.
Specification
Product Name: GF 8800 GTS 650M 320MB DDR3 DUAL DVI TV
Package Contents: S-Video Cable, DVI Adaptor x 2, HDTV Component Adaptor
Main Description: GEFORCE 8800 GTS 650M 320MB / DUAL DVI
Supplemental Description: HDCP / HDTV / PCI-E / DDR3 / RoHS / Vista
UPC Number: 778656044326
Chipset: GF 8800 GTS
BUS Type: PCI-E
GPU Clock 650 MHz
Memory Bus 320 bit
Memory Type DDR3
Memory Size 320MB
Memory Speed 2.0 GHz
Shader clock 1500 MHz
Cooling Type FANSINK
TV OUT YES
VGA NO
DVI OUT YES (DUAL)
DUAL-LINK DVI YES (DUAL)
Max Supported Resolution 2560x1600
HDMI NO
RoHS YES
HDCP YES
NVIDIA-SLI READY YES
Windows Vista Ready YES
Low Profile Compatible NO
Specs are looking good, let's take a look at the card.
I enjoyed reading that mate :)
I also drooled over the dx10 screenies, and was suprised to see the average dx10 (vista) frame frate higher than dx9 (xp).
I may just get vista soon :D
DX10 looks awesome at points although generally Bioshock looks pretty damn good anyway :)
Thankd mate and good work, reps for you :)
Thanks dude! :)
Only relaying a problem I had with BSODs and SLI with two cards with different memory.
It is amazing what can make cards BSOD.. and what can make them stop.
Agree with the missing embossed "XFX Fat" sunken-green-print on the black rear plates. So simple and definately a missed oportunity. XFX should do it tbh, getting a bit tired of the blank black pci-slot feature myself. Looks naff with the shiney silver LL case rears especially.
The less said about the face on the sticker, the better. Be nice to have an OC3D printable sticky label to put over it ;) Easily done with some lazer-label sheets.
Great review Kemp.
enabling coolbits will stop BSoD if i get any?
Catch me on MSN, and I will explain all the details! ;)
A bit of a pointless card since the 320MB version is being phased out - the Fatal1ty series are also meant to represent high performance components, not mid range etc. like the 320MB 8800GTS is - it would have made more sense to do either the 640MB GTS or the GTX
XFX and fatal1ty brand are marketed as Pro Gamers Gear. That doesn't mean high or low end, it means things gamers would want to buy. Generally easily marketable high volume products.
A bit pointless? In what way? It beats out 640MB versions easily due to massive out of the factory clocks and Ultra fast shader processors. Some games in the future may need the extra memory but look at the figures, most games out now run fine
Meh guess it depends what u`r doing.
