Sapphire X1950 Pro Dual
The Card - Close up
Published: 3rd May 2007 | Source: Sapphire | Price: |
I have to admit my first thoughts of the X1950 Pro dual were...well...more laughs than thoughts. The card is HUGE. I mean it's massive. After the initial shock died down I went about the business of getting a closer look.
The card certainly looks the part. With a nice large 80mm fan in the middle and a large finned and heatpiped cooler. On the back you can see the tensioners for the two GPU's holding the heatsink firmly in place. One thing you notice as well is that the card only takes up one slot with a single slot backplate. This is a strange decision with such a large cooler to bear the load of.
Update
The news from Sapphire is that this card is a review sample and the retail card will have a double PCI-e backplate andmore importantly two lots of DVI headers for 4 monitor output. This is fantastic news and really gives some value to the card making it a very attractive proposition for those with large multi-monitor setups.
Update
Two Dual Link DVI ports adorn the rear of the card as well as the S-Video out that includes ATi's excellent AVIVO technology.
Additional cooling has been added by Sapphire to cool the power regulation circuitry. Nice to see that Sapphire make sure everything is running as it should.
Here we see the dual PCI-e 6-pin power connectors for this power-hungry card. The fins for those fat heatpipes are sat right above this and you can see 2 of the 4 heatpipes on the right.
Sapphire have added some branding to the cooler along the aluminium plate affixed to the GPU's. Once again two of the heatpipes are showing in the picture. Sapphire have added a backplate to each of the two X1950's to really fix that cooler securely onto the card. This is good for peace of mind.
The card has a crossfire connector onboard. This gives it the potential to have a "quad crossfire" system with four X1950 Pro cores working together. This is not yet available, but it would be a rather exciting prospect!
Once you take the cooler off the whole thing makes a little more sense and also makes the card look pretty well laid out. Each GPU has a ring of Samsung 16x 1.4ns GDDR3 memory chips. The PCI-e bridge chip sits in the middle of the two GPU's connecting them up. There sure is a lot of hardware to fit onto one PCB, pretty impressive stuff.
The RV570 sitting proud on the PCB and also the PLX 8532 PCI-e bridge chip that lets the GPU's talk to each other.
Samsung 1.4ns GDDR3 memory chips - K4J52324QE. Each card has access to 512mb of memory, making 1gb total.
The ATI Rage Theatre chip doesn't need additional cooling and sits just outside the cooler near the rear IO plate. This chip brings us the excellent AVIVO features that the high-end and HTPC ATI cards feature. It's good to see ATI haven't skimped on adding the extra features on this rather insane card.
The Cooler
The cooler on the X1950 Pro Dual was actually pretty quiet for such a beasty cooler. At load it is audible but I did not hear the fan spin up to maximum at any point during the game or benchmark testing. This is excellent and an improvement on the stock X1950 pro coolers.
Temperature
Unfortunately I did not get any scientific readings of temperature this time around, although the GPU was idling at 34°C and loading up under 3DMark06 at 58°C. This is pretty impressive for a dual GPU card.
Now let's get it running shall we?
Here you can see the rather large sized Sapphire X1950 Pro Dual. It is almost motherboard sized. In fact in some aspects it surpasses that as we will see later...
The Cooler
Temperature
For an ATI card I am impressed with the performance!
I am not an ATI fan but that it pretty.
Nice review!
Nice review!
Dunno about pretty
Pretty huge maybe?
Pretty huge maybe?
Pretty nasty point drop at high res in 3Dmark tbh
Ye which was strange as gaming it didn't do too badly. 3DMark I always take with a pinch of salt but it is a bit disappointing
UPDATE:
Sapphire have said that the retail version comes with 3DMark06 and more importantly 4 DVI outputs for a 4 monitor setup.
Pretty cool.
Pretty cool.
Good review, seems like a cool product, just a little late in the game. Hate to nit pick but on page 3 under Test Setup and Notes it says "To test these high-end nVidia cards I set a PC that gives as little of a bottleneck as possible." Again sorry to be annoying.
Oops
Originally Posted by name='Kempez'
UPDATE:
Sapphire have said that the retail version comes with 3DMark06 and more importantly 4 DVI outputs for a 4 monitor setup. Pretty cool. |
And 4 monitors on one card, thats pretty damn good!
But who uses 4 monitors!? :eh:
Originally Posted by name='Toxcity'
But who uses 4 monitors!? :eh: |
Originally Posted by name='XMS'
Someone with 4 eyes?
The review is decent, as always.
Personally, I think the product is weak. It is dx9, overpriced (almost as much as a GTS but fails to perform as well, again, it is not dx10 either) stupidly large and... Almost pointless. IMO.
Look forward to seeing the HD2900XT
Would u think again if they have an inside inclin that Dx10 might not be with us til Q4.2008 ?
(not a fact, just speculation)
Still pricey imo, I`d still lean the 8800 way if I`m looking to spend around $350.
Wouldn't touch it with the 8800GTS 320mb beating it in benchmarks and having DX10. The only thing nVidia has to do to really put the grind into ATI is make SLI usable with 2 or more monitors. The dual GPU thing just doesn't do it, ATI needs to come out with DX10 GPU's, and make the cards smaller not bigger. If I were ATI and wanted to come out swinging against nVidia, that would be priority #2--- a smaller video card. Priority #1 would be making the GPU less power hungry while still making faster/powerful cores. With the AMD merger, I don't know whats keeping this from happening because they're pretty much giving up on a market they once ruled but are repeatedly losing sight of.
TJS
TJS
link
