Sapphire 5970 Toxic Review
Unigine
Published: 5th August 2010 | Source: Sapphire | Price: around £800 |
Unigine Heaven Benchmark
There isn't much we haven't already said about Unigine, but once again if anything can push a card to the absolute limit, this is it. More eye-candy than Miss World. With zero anti-aliasing the Toxic gets very close to the 100FPS mark that seemed impossible when Unigine was first released. Our overclock doesn't actually seem to make a difference to the results, barring a little higher at the minimum level.
With 8x anti-aliasing applied the Toxic actually compares better than it does in the above graph. Comfortably beating the stock Ares and not that far behind the overclocked Ares, made even more impressive when you consider that the Toxic has a little less CPU power behind it, and that the overclock isn't making any worthwhile difference in this test.
By the way, I see the award images have changed? (atleast for the performance award?) I like it, looks nice
So the CPU will account for most of it, and the tiny extra theoretical grunt of the Ares gives us the few extra. If you look back at the Ares XF results you'll see that Crysis is pants no matter how much hardware you have. So really take it with a pinch of salt.
A. Completely rip off the Arctic Accelero Xtreme
B. Use an Arctic Accelero Xtreme.
'cos from where I am sitting it has to be one or the other.
It's not just OC3D. Every website is "Crysis this, Crysis that". Seriously, the game is old hat now (and I'm not saying that at your or to you, just saying it in general).
Do the manufacturers (in this case Sapphire) suggest that you use Crysis?
The cooler is an AC unit.
Also I like to see bench's for Crysis as I find it very easy to compare real performance, I use it like a control of sort, to gauge GPU real world performance, much more useful than synthetic benchies!
Am I reading the Crysis bench properly? How comes the Stock out performs the overclock @ Maximum for the toxic? Also I like to see bench's for Crysis as I find it very easy to compare real performance, I use it like a control of sort, to gauge GPU real world performance, much more useful than synthetic benchies! |
Sometime the results can be a bit strange, just the way it is dude, maybe crysis didnt like the overclock. Without spending hours researching every result we'll never know. |
*stop making your replies bold*
This is just a suggestion I noticed some of the websites and magazines don’t put the maximum FPS they say it doesn’t reflect the true performance of the graphic card because most important in game play is the minimum and average FPS which actually shows you if you can play the game between 30FPS and 60FPS which is considered (very playable) and also the maximum FPS behaviour is very strange when overclocking the GPU so why don’t you scrap the maximum from your benchmarks to avoid these kinds of issues I know the maximum FPS shows the muscles of the GPU but it’s not really true performance. *stop making your replies bold* |
PS - stop bolding your replies.
But the Toxic DID arrive before the Ares. You can see the date on this review is April 22nd; over 2 months before the arrival of the Ares.
*LINK REMOVED*
"The biggest compliment we can pay, and it is a big one, is that if this had arrived before Ares we'd have looked at that differently" But the Toxic DID arrive before the Ares. You can see the date on this[/url] review is April 22nd; over 2 months before the arrival of the Ares. |
sorry about my ignorance
a normal 5970 is basicly 2 5870 chips underclocked to 5850 speeds
where was the ares, toxic and so on are full on 5870 chips
Continue Reading
