Sapphire 5970 Toxic Review
Introduction and Technical Specs
Published: 5th August 2010 | Source: Sapphire | Price: around £800 |
A little while ago we took at look at the Asus Ares and discovered that whilst it was absolutely a thing of immense power and desirability, it was also fiercely expensive. So what do you do if you want a product that has phenomenal power, a certain exclusivity but wont require you to sell a kidney to obtain one?
Sapphire have always been one of the premiere ATI partners and have been producing premium versions of each generation of ATI GPUs. Anyone who has been around the hardware scene for a while will know how highly the Toxic variants are thought of, and so when we discovered that Sapphire were going to bring out a Toxic version of the already excellent 5970, we couldn't wait to get our hands on one.
The HD5970, for those of you who need a little memory jog, is ATIs twin GPU behemoth and at the time of release was the fastest single card available. It did however have one small drawback. To get the card to fit within the ATX specifications and ensure that the reference cooler could handle the heat of two GPUs whilst still being only a dual-slot solution, ATI had to keep the core speeds quite low.
Sapphire have dispensed with the standard cooler and so does it allow for greater clockspeeds and finally unleash the performance the 5970 has promised?
Technical Specifications
| Specifications | |
| Output | 2 x Dual-Link DVI 1 x Mini-DisplayPort |
| GPU | 900 MHz Core Clock 40 nm Process Technology 3200 x Stream Processors |
| Memory | 4096 MB Size 512(2x256) -bit GDDR5 4800 MHz Effective |
| Dimension | 310x118x61 mm Size. |
| Software | Driver CD |
Absolutely. If you'll cast your mind back to the 5970 speeds you will notice that Sapphire have managed to get a 175 MHz increase in core speed and around 200 MHz faster on the memory. An absolute quantum leap forward in speeds compared to the standard design.
Time to take a look at the card in all its glory.
By the way, I see the award images have changed? (atleast for the performance award?) I like it, looks nice
So the CPU will account for most of it, and the tiny extra theoretical grunt of the Ares gives us the few extra. If you look back at the Ares XF results you'll see that Crysis is pants no matter how much hardware you have. So really take it with a pinch of salt.
A. Completely rip off the Arctic Accelero Xtreme
B. Use an Arctic Accelero Xtreme.
'cos from where I am sitting it has to be one or the other.
It's not just OC3D. Every website is "Crysis this, Crysis that". Seriously, the game is old hat now (and I'm not saying that at your or to you, just saying it in general).
Do the manufacturers (in this case Sapphire) suggest that you use Crysis?
The cooler is an AC unit.
Also I like to see bench's for Crysis as I find it very easy to compare real performance, I use it like a control of sort, to gauge GPU real world performance, much more useful than synthetic benchies!
Am I reading the Crysis bench properly? How comes the Stock out performs the overclock @ Maximum for the toxic? Also I like to see bench's for Crysis as I find it very easy to compare real performance, I use it like a control of sort, to gauge GPU real world performance, much more useful than synthetic benchies! |
Sometime the results can be a bit strange, just the way it is dude, maybe crysis didnt like the overclock. Without spending hours researching every result we'll never know. |
*stop making your replies bold*
This is just a suggestion I noticed some of the websites and magazines don’t put the maximum FPS they say it doesn’t reflect the true performance of the graphic card because most important in game play is the minimum and average FPS which actually shows you if you can play the game between 30FPS and 60FPS which is considered (very playable) and also the maximum FPS behaviour is very strange when overclocking the GPU so why don’t you scrap the maximum from your benchmarks to avoid these kinds of issues I know the maximum FPS shows the muscles of the GPU but it’s not really true performance. *stop making your replies bold* |
PS - stop bolding your replies.
But the Toxic DID arrive before the Ares. You can see the date on this review is April 22nd; over 2 months before the arrival of the Ares.
*LINK REMOVED*
"The biggest compliment we can pay, and it is a big one, is that if this had arrived before Ares we'd have looked at that differently" But the Toxic DID arrive before the Ares. You can see the date on this[/url] review is April 22nd; over 2 months before the arrival of the Ares. |
sorry about my ignorance
a normal 5970 is basicly 2 5870 chips underclocked to 5850 speeds
where was the ares, toxic and so on are full on 5870 chips
Continue Reading
