Powercolor X1650 Pro Review
X1650 Pro - Close in: Bundle and Cooling
Published: 24th August 2006 | Source: Powercolor | Price: |
ATI have not gone all out and given their product line a total revamp. Instead they have done an SKU 'refresh'. This means essentially the same technology, but faster and usually smaller.
The X1650 is on an 80nm wafer and the theory is that it should run cooler than it's predecessor. This can only be a good thing as the X1600 was not a chip that got into the enthusiasts hearts for being easy to cool.
Lets check out the specs for the card:
Technical Specification
Graphics Processor - VPU Specs Connectors
VPU RADEON® X1650
S-Video
VPU-Core-Clock 600MHz
DVI X2
BUS-Type PCI-e x 16
Fabrication Process 80 nm
Pixel Shader Unit 12
Vertex Pipelines 5
Graphics Card Memory Technology
Graphic Memory 256
AVIVOTM Yes
Graphic Memory Speed 1400MHz CrossFireTM Ready Yes
Graphic Memory Type DDR3 HDTV Yes
Graphic Memory-BIT 128 h.264 support Yes
SMARTSHADERTM HD Yes
SMOOTHVISIONTM HD Yes
HYPER ZTM HD Yes
VIDEOSHADERTM HD Yes
RAMDAC 400 MHz DACs
Optimized for DirectX© 9.0c
OpenGL© 2.0
Shader Model 3.0
With 12Pixel Shaders and 5 Vertex pipelines, this card should play pretty well.
Lets take a look:
We can also see the ATI Rage Theatre chip on the left of the card. This enables ATI AVIVO technology on the X1650. AVIVO means better image quality and some nifty features such as on-GPU re-encoding. ATI include the AVIVO software free and it works very well on the X1XXX series.
Let's get the clothes off the chip
Software
Driver Catalyst Version 6.8 Software Bundle
Cables, Adapters & Other Accessories Manuals & Documents
HDTV Cable Quick-Installation Guide
DVI to VGA Adapter Yes Documentation in CD
S-Video to AV Adapter Yes Manual
S-Video Cable
Composite Cable
Power Cable
I did not get the power adaptor through in my bundle, but this should be in the retail version.
The bundle is pretty decent and all the connecters are there that you would need to fully utilise the features on the card. Perhaps another DVI-VGA cable could have been included, but this defeats the object of the dual DVI in the first place in my opinion.
Powercolor have included CyberQuest software Suit with the card which is a great starter DVD set. Overall the package isn't too bad and as Powercolor usually price their cards very competitively, this makes the bundle look better.
Cooling
The cooling on the X1650 does not look very substantial at all. With a smallish aluminium heatsink and a fairly large fan this solution looks inadequate. Unfortunately the temperature reading on the card in the drivers I have has not been enabled, so I was unable to get the temperatures.
Originally Posted by name='Hyper'
As usual a good review kemp, it seems they will be in the competition range of the Nvidia 7600.
The reason I ask is that the testings done on a clocked system, is that indicative of the people who would get this? Just wondering as you did all the testing on a clocked system?
Could we see some benchies on a stock and non stock system (like the custom pc magazine) for those of us in phear of clocking?
I am going to use the same PC for all my tests from now on so this was a base for future comparison
Originally Posted by name='Kempez'
I actually forgot I had my CPU clocked up during the tests. Regardless the C2D would play the games fast anyway. Unfortunately my test rig has been sold so I could not use that for the tests.
That setup would be VGA-limited in all games anyway, even a stock Allendale can push a lower-midrange card to its limits.
The X1650pro will be a great alternative to Nvidia's solutions at its level. It has an amazing price/performance ratio: 66€ is even less than what the 7300GTs clocked at 500/1400 are selling for!
Originally Posted by Vaerilis
Nice review!
That setup would be VGA-limited in all games anyway, even a stock Allendale can push a lower-midrange card to its limits. The X1650pro will be a great alternative to Nvidia's solutions at its level. It has an amazing price/performance ratio: 66€ is even less than what the 7300GTs clocked at 500/1400 are selling for! |
How does it do when we subject it to the Overclock3D bench suite?
Find out here
