NEC MultiSync WGX2 20" TFT Review
The Screen Up Close and Inputs
Search Reviews
Review <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 30/01/07
Author: Matt Kemp
Source: NEC
NEC Multisync 20WGX² Close Up
The 20WGX² is a very attractive monitor close up. With a stylish silver bezel and keys set below the display it would look good on your desk.
nec 20wgx2 monitor
nec 20" 20wgx2
As you can see it's a bit of a chunky monitor as regards the profile. Not as elegant and slim as some of the competition. However this doesn't massively affect the area it takes up too much.
nec multisync 20" 20gx2
The monitor has a screen that is almost glass-like. It is very reflective and when off with a light shining on it it is almost a mirrored surface. This could put off some people, although the only time it bothered me was when I let some sun shine on it by mistake, and not many monitors stand up to that.
nec 20" 20wgx2
nec multisync 20" 20wgx2
The stand is a little low for my liking and lacks height adjustment which is a bit of a minus point. Many will find this is ok though as they have a monitor stand integrated into their desk or perhaps like their screen lower than I do.
There is good tilt on the screen and 360° swivel adjustment which is excellent - great for a LAN perhaps when you want to show your friend how dead they were after you fragged them.
Inputs/Connectivity
Let's take a look at the inputs and connectivity on the monitor.
nec multisync 20" 20wgx2  nec 20" 20wgx2
The DVI and VGA connections are situated on the bottom of the screen below the buttons. This makes for easy access. The USB hub has two connectors on the bottom of the monitor and an additional two on the side. This is excellent for those of you who like your USB devices and webcams, headphones, microphone's etc would be easy to plug in.
NEC 20" 20wgx2  nec 20" wgx2
The monitor has a power switch on the rear in addition to the main power switch on the front. I assume this is to make sure that the monitor is power off totally, rather than in standby mode.
Controls
The controls on the 20WGX² are in a neat little attached part of the monitor below the display. This is a "love it or loathe it" solution and personally I think it adds to the stylish look of the monitor.
nec 20" 20wgx2 controls
The On Screen Display is made easier to move around with the small dial-like button on the panel here. There is also a button that quickly adjusts the Dynamic Visual Mode (DVM). This mode makes a huge difference as we will see later on.
All in all this is an attractive and stylish monitor that would look great sitting on your desk.
The controls are great and the adjustment is pretty good although no height adjustment gives it a "must do better" in my book.
«Prev 1 2 3 4 5 Next»
14-01-2007, 06:32:42
PV5150
It appears that all is not well with the inheritor of the intellectual property for the Unix operating system. What implications, if any, will this have on Open Source/Linux/Unix? Feel free to air your comments below...
Link
14-01-2007, 08:13:54
equk
Hopefully they won't dissapear, I thought Bill Gates gave them some money to take linux to court about stuff a while ago (or was that sun?)
Guess they've used that up tho and it seems most people are opting for free or open source linux/unix systems which I guess is not helping them that much.
