HIS Radeon HD 5870 1GB GDDR5 PCIe Graphics card
Benchmarks 3
Published: 4th October 2009 | Source: HIS | Price: £310.49 |
Crysis is without doubt one of the most visually stunning and hardware-challenging games to date. By using CrysisBench - a tool developed independently of Crysis - we performed a total of 5 timedemo benchmarks using a GPU-intensive pre-recorded demo. To ensure the most accurate results, the highest and lowest benchmark scores were then removed and an average calculated from the remaining three.
Oblivion from Bethseda is now an 'old' game by today's standards, but is still one of the most visually taxing games out there. The benchmark was run in the wilderness with all settings set to the maximum possible. Bloom was used in preference to HDR. The test was run five times with the average FPS then being deduced.
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning "world", "earth" or "living" in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results Analysis
For the first time, I was able to run Crysis at maximum resolution which still allowed a playable frame rate. This is even more astonishing when you consider that the maximum allowed anti-aliasing and anisotropic filters were added.The frame rates were close to double that of the GTX285 which is no mean feat considering the GTX285 is still classed as one of the best graphics cards on the market today. Oblivion showed a massive hike in frame rates too and while things were a little closer in Far Cry 2, the HIS HD5870 still put the GTX285 firmly in it's place.
Let's move on to the conclusion...
Holy hell. That's one mega GPU. My only concern is that DX10 GPUs aren't vital because of the whole X360 port laziness of devs.
So DX11? Really? Give it a year and I might invest.
In order to feed the GPU enough power, the HD85870
Its meant to be HD5870, init?
Great review, tho i would have liked to see the comparison against a 295 aswell as its in the middle of the 2 price wise.
Looks like the gtx285 is still the smart money at the moment, considering price/performance-you-really-need. Just have to wait for the price drops
Small grammatical error in the conclusion:
Should be 'price is high' / 'card is expensive'The Mediocre
- The price is expensive for a single core GPU
Awesome review w3bbo but I was looking forward to an actual comparison against the 4890/70 just for good measure.
Unfortunately we don't have a huge stockpile of GPU's to re-use as once they are reviewed they usually go onto pastures new. It was only by chance that I still had the MSI GTX285 laying around which was the nearest card performance wise with which to compare.
I couldn't use the results from previous reviews as I have a totally new test rig to reflect the ever changing market and I have also tweaked the testing procedure to include more AA/AF, especially at 2560x1600 (8xAA/16xAF
) as this setting certainly separates the men from the boys!
Some awesome raw performance going on their, great review.
Bit unsure as to why they have the mounting bracket outside the shroud on the rear.
Being as the 1G version of the 285 wouldn't suffer in comparison to the 2G regarding framerate benches - isn't it strange how the cost-per-frame emphasis suddenly disappears when it suits us. ASUS GTX285 can be found for a biscuit under £230.
Tis currently a great card. £310 ? Gotta be around £295 atleast when it hits the online stores.
Cheers Rasta.
The extra memory of the 2GB version helps when at the highest res however, as the 5870 has proved, you don't need 2GB if the core is capable enough.
The only thing I can assume regarding the bracket is that it helps with keeping the card cool while the shroud affords some protection to the rear of the card.
U'd be surprized. In games yeah the memory is very beneficial to the performance, the likes of GTA4 and.. .. have a meter that shows how much ur using. With 1G on a card I can't play GTA4 at max cos.. well there aint enough, even for a 20" screen. But it'd still do a bench run, the graphic requirements ofc are preallocated to the card's memory b4 u execute. It's not a case that the thing will run until it runs out of memory, like ur pc's memory will allow.
It's almost like u change the settings ingame - if it's permitted, u have enough graphic memory - if it won't allow it, u don't.
Edit: Nevermind.
Continue Reading
