Gigabyte Radeon HD 5870 1GB Crossfire
Synthetic Benchmarks & Gaming
Search Reviews
Futuremark 3DMark Vantage
3DMark Vantage is an updated and more demanding evolution over the package that it succeeded. Our tests cover the "Performance" setting of the benchmark. The application will output three scores. The first two are CPU and GPU scores, which are formed from various tests that will focus on either of the two (or both). On the basis of those scores, a final "Overall" score is then outputted with a "P" prefix beforehand to denote that the "Performance" setting was applied.
The results are quite interesting, showing the HD 4890 crossfire setup sitting in between a single HD 5870 and the HD 5870 Crossfire score. At any rate, the previous generation isn't struggling to hold it's own. It should be mentioned however that the end result of a synthetic benchmark does not always translate to similar outcomes in real games, so on that bomb shell let's have a play with...
Crysis Warhead
Crysis Warhead is without a doubt one hard nut to crack, especially at higher resolutions and a dash of Anti Aliasing and Anisotrophic Filtering. Typically, this game is heavy on both CPU and GPU however the limitation at high resolutions skews the dependancy towards the latter. Depending on how well the drivers are optimised, Multi GPU scaling could vary greatly. But anyway, given the game's "tough" characteristics, we were eager to find out the end result.
Wow. Dare I say it? Has Crysis Warhead been defeated? Thanks to superb crossfire scaling, there was not even so much as a stutter even in denser scenery with plenty of explosions. Quite notably, the HD 4890 CrossfireX setup performs about as fast as a single HD 5870 and two of the latter offers considerable increases on top of that.
Far Cry 2
Far Cry 2, a slightly older hit but based on a fairly demanding engine also has a fair level of GPU dependancy at least particularly so at higher resolutions. This particular game features a fabulous benchmarking tool, which loops an intensive Far Cry 2 scene and gatherers minimum, maximum and average framerates accordingly. This allows for a more accurate comparison from one test item to another. As mentioned, we have set all Quality Settings to the highest possible within the tool.
Once again, CrossfireX scaling appears to be very reasonable. Far Cry 2 however doesn't appear to require it's horsepower in this particular scenario. Perhaps it may be of interest for 2560x1600 users?
Microsoft Flight Simulator X
Microsoft Flight Simulator X is part of a handful of games that are heavily CPU reliant. If you thought that this was bad, at initial release this game did not have multicore cpu support. I need not say anymore on that front, but with this in mind, the results that followed were not too surprising.
So if you're a Flight Simmer, do yourself a favour and opt for a single card solution and spend some of your savings on overclocking that Core i7 of yours to 4.0GHz and beyond
Call of Duty 4
Call of Duty 4 is one of the older games within our testing. Once again, all quality settings are set as high as possible and Dual Graphics Card support has been checked in game. Our particular CoD4 test is not terribly strenuous but the performance scaling is quite clear.
So it would seem that two HD 5870's in CrossfireX aren't exactly justifiable for CoD4 alone,
«Prev 1 2 3 4 5 Next»
24-10-2009, 04:08:44
tinytomlogan
How good would 5870 Crossfire be? OC3D finally answer the questions you all are asking. By Mul.
Continue Reading
24-10-2009, 04:36:29
Rastalovich
Some really good figures going on there. The scaling does indeed look pretty impressive.
Good review.
Does xfire suffer the same casualty as sli in so much as if there's "a profile" for a game, the performance is that much better ?
lmao @ MSFX, one probable exception where a 16 core dual zeon setup with 16g will do u better than a smart gfxcard.
It's perhaps tiring review-wize to have to pre-qualify each game with "old..", "a bit older..". With a bunch of games coming (if schedules hold up) in Q1'10 that support Dx11, it might be worth thinking of consolidating the range of games used by OC3D as benchmarkers. Worth holding onto 1/2 Dx9 ? Maybe. Hold onto 1/2 Dx10 ? Probably. And I would imagine the earlier Dx11 releases would be asked to have bench markers built into them.
Great stuff.
24-10-2009, 04:44:55
tinytomlogan
When the DX11 games come through you can expect to see a new batch of reviews Rast and the games we use for benches change also. I for one am very interested in what Dirt2 for example plays like in DX10 vs DX11 mode. We shall see.
24-10-2009, 04:54:31
sammytomjohn
yes tom! dirt2 was on my mind also as soon as you mentioned dx11!
24-10-2009, 11:26:56
zak4994
Epic review dude.
Am loving that design on the card.
600fps in CoD4?
Who needs that much?
24-10-2009, 13:36:28
VonBlade
5870 CF? *puts on Clarkson voice* ... POWAAAAAAHHHHHHH.
Yipes that is just stupendously powerful.
I definitely think that you need to find games that are harder on the graphics. Or perhaps even the whole system. COD4 hitting 600 makes that bench utterly worthless now. Might as well bench Quake 2
Dirt (original) is heavy on systems, so I imagine Dirt2 will be too. Maybe swap Grid for Dirt2, or even NFS Shift.
Crysis and Far Cry 2 still get it done in FPS terms. Can't think of much in the immediate future that's close. Apart from Crysis2 obviously.
CoH is still heavy for RTS' although Dawn of War II can potentially push a system harder.
Mirrors Edge can be hefty with decent settings, even if it is old.
I've not tried Flashpoint 2 or the new update for Stalker, but I imagine they'll be pretty hefty too.
I certainly think the time to retire Grid, Quake and COD4 has come.
24-10-2009, 22:03:00
WelshD1K
£606 ....... need i say more?
05-11-2009, 10:04:32
Maxrunner
I dont get those medium fps for cod4, not in the multiplayer......are those singleplayer tests? There's not way im getting 170fps medium on multiplayer with everything maxed out, and im using an i7920 at 4ghz and 9.10 catalyst drivers....
The medium i currently have is 125fps/130fps multiplayer.
11-02-2010, 14:25:48
yaniv1512
is it good for Cad and 3d applications ?
where can i find benchmark for the hd5780 in Cad and 3d applications?
