Gigabyte GTX580 Super Overclock Review
Published: 20th October 2011 | Source: Gigabyte | Price: £419 |
The GTX580 is still, many months after it's release, the absolute single-GPU king.
Indeed the performance is so spectacular that if you're in the market for some hardcore performance then three of these will out-perform any quad-GPU setups such as GTX590s in SLI or Crossfire HD6990s.
So with this in mind we were excited to get the Gigabyte Super Overclock version of the GTX580 in the office. These are cherry-picked FM110 cores making sure that you get only the very best chips nVidia can produce on your card. The benefits of this are multiple. Not only does it ensure that you get a chip that will overclock like a demon, but also one that doesn't require a nuclear power plant strapped to it to do so. As if that isn't enough it also comes with Gigabytes first foray into the world of triple-fan coolers and they've gone the whole hog with a vapour-chamber as well as the massive heatpipe and fin arrangement we're used to.
You all know what the GTX580 is about by now, so we shall crack on.
As you can see out of the box it appears to be a fairly standard GTX580. Then you note those clock-speeds and get a feel that something special is going on with the Gigabyte GTX580 SOC. As is often the case though the specifications don't tell the full story. So let's grab a look at the card shall we.
| Chipset | GeForce GTX 580 |
| Core Clock | 855 MHz |
| Shader Clock | 1710 MHz |
| Memory Clock | 4100 MHz |
| Process Technology | 40 nm |
| Memory Size | 1536 MB |
| Memory Bus | 384 bit |
| Card Bus | PCI-E 2.0 |
| Memory Type | GDDR5 |
| DirectX | 11 |
| OpenGL | 4.1 |
| Digital max resolution | 2560 x 1600 |
| Analog max resolution | 2048 x 1536 |
| Multi-view | 2 |
Actually two costs 946£. Gotta love the prizes in Norway
Gigabyte need to scrap the blue PCB though it looks nasty to me, black PCB FTW
Loved the witcher scene
One to look at in todays review is the 8xAA here. I'd go out on a limb and say that the reference 580 can-not be faster than either an oc'd 580 or indeed this card. (I'll bow to anyone who can explain how the same tech running slower can produce a faster result however)
I've noticed it in something like the 6970 reviews onwards. The base cards in many graphs being faster than the 'technically' faster card. This, not only is "wrong", but shows that something is wrong with the system being used for testing.
I'll harp on about it again, but I *think* it's your Windows 7 setups. Of course I can be wrong, but that's where I'd be looking.
Good write-up tho.
(where's my tissues)
i can only dream of the scores (FPSs) i would get on my rig with one of these bad boys in it.
(too many plans for the new build)
also folding the same WU with my matrix (at stock), i get the same ppd as you were getting with it OCed ? weird, and when i turned up the volts and the clock to what you have in your review i was getting around 20.7 - 21.1k ppd with it.... BUT it was hotter and much too loud.
6970cfx is an awesome setup mate, why would you even think about replacing them, unless they are too loud and hot. My min framerates are generally quite good, but on heaven the lowest I got was 5fps, which was at the beginning when the benchmark was starting so I'm not bothered. |
I'm french from Dijon.
Here my bench score:
http://img714.imageshack.us/img714/3...nigine2011.png
My CPU is overcloked :
Intel Core I3 530 2,93 Ghz to 3,9 Ghz
Free voltage and C6 State ON (1,8 to 3,9 Ghz)
Memory :
G.Skills Pi series 2000 Mhz cas 6 (2 x 2Go)
My GTX 480 is overclocked :
OC / STOCK
-GPU= 814 / 700 Mhz
-Shader= 1628 / 1401 Mhz
-Memory= 4250 / 3696 Mhz
-Voltage= 1,138 / 1,038 V
Hi everyone , i show my benchmark score to compare with others ! I'm french from Dijon. Here my bench score: http://img714.imageshack.us/img714/3...nigine2011.png |
A nice result you got there. It seems Unigine heaven doesn't like the Gigabyte GTX 580 SOC. Would you care to do a Crysis 2 Benchmark with the same settings as TTL, just so we can see what results you get
.If you want me to do a different bench , please tell me witch one
- Rage
- Dead Island
- Deus EX Revolution
- Street Fighter 4
- DIRT 3
Booooooobies!
Hung like a donkey."
Made me lol.
Continue Reading
