Gainward Bliss 7950 GX2
Close up - Gainward 7950 GX2
Published: 25th September 2006 | Source: Gainward | Price: |
Author: Matthew Kemp (kempez)
Hardware Acquired: Gainward
The card itself
The 7950 GX2 is unlike any card we've tested before in that it has two coolers on it. With two PCB's and two coolers this card is dual slot and "Dual Core". I use parenthesis as this is two physical cores on two PCB's with a "bridge" connecter between them. nVidia have gone this way, rather than the unified shader pipelines that ATI have started doing in their top-line cards.
Gainward seem to be using the reference cooler for their implementation of the 7950. This is similar to the design we saw on the XFX 7900GT which was a decent cooler in its own right. Will this cooler be enough to keep the card cool and quite? We'll see later on.
The card has dual DVI out...with a "but". If you are running in SLI mode (i.e. full performance mode with dual GPU's enabled): you cannot run dual monitors. The card will either run in Dual display mode or dual GPU mode. Not a bonus for those who wants big performance with more than one monitor.
Specification
As taken from Gainward's Site:
* Barcode: 471846200-7920
* GPU: NVIDIA GeForce 7950GX2
* GPU Clockspeed: 500 MHz
* Memory: 1024MB 1,4ns DDR3
* Memory Clockspeed: 1200 MHz
* Pixels per clock (peak) : 48
* Bandwidth: 76,8 GB/s
* Ramdac: 400 MHz
* Bus: PCI-Express
* Cooling: Fan (Two-slot)
* Video-Features: Component, S-Video & Composite Out
* Connectivity: Dvi + Dvi + Video-Out
The Cooler
The cooler looks to be the same ilk that the 7900GT was bred from. With a smallish size fan and two GPU's on one card, you would certainly think it would run very loud. To my surprise it doesn't, and is pretty efficient. Though not as quiet as the cooler on the 7900GTX, the cooler is barely audible in the case under full load. The card does kick out some heat into the case, but the back of the PCB stays pretty cool, unlike that of the X1950XTX.
Read on...
