ASUS EN9800GT 512mb PCI-E
Published: 26th September 2008 | Source: ASUS | Price: £95 |
It is plainly obvious that the 9800GT is little more than the 8800GT we had known and loved. However, times change, technology advances and while ATI have made some significant progress, NVidia have continued to churn out cards based on last generation technology. The 9800GT is one such example.
That isn't to say the 9800GT is a bad card as it's quite clearly a capable piece of hardware. It is stylish, silent and powerful enough to play all but Crysis at high settings with AA and AF applied which, weighing in at under £100, is an great achievement.
Previously, the 8800GT had little competition from ATI and the NVidia card ruled supreme as the mid-range card of choice. This year there is a new kid in town and ATI have pulled out all the stops to release a formidable mid-range card that simply blows the 9800GT (or 8800GT depending on your preference) out of the water with regards to raw performance. While NVidia have been resting on their laurels, ATI have developed a card that not only outperforms the NVidia offering but also has a better Price/Performance ratio in the majority of games -bucking the trend that the more you pay the less ratio you get. So with that said, why would anyone buy the 9800GT?
The 9800GT is TRI SLI capable and also has slightly updated OpenGL support (2.1). As its name suggests the EN9800GT is HybridPower™ and Hybrid SLI® compatible should you be lucky enough to own a motherboard supporting these features (780a chipset). These are perhaps the only worthwhile improvements to the 8800GT. However, why anyone would want to TRI SLI 3 9800GT's when for the same price they could have a single 280GTX that costs less, and on most occassions, would outperform the three cards is beyond me.
Before reviewing this card, my one hope for the 9800GT was for it to be cheap. It needed to be cheap if it was going to generate sales and be competitive so while £95 is hardly expensive, there are better options that give much more bang per buck. Therefore, I think we have shown that while the ASUS EN9800GT is a very attractive, cool and silent running card, it ultimately fails to deliver the goods when compared with the current competition.
The Good
- Silent
- Blue PCB
- Solid capacitors for long life
- SLI capable
The Mediocre
- Performance
- Price
- No included game
The Bad
- So 'last year'
Thanks to ASUS for providing the EN 9800GT 'Hybridpower' and HD4850 for this review.
Discuss in our forums.
Good review. It does indeed look like a 8800GT with a gpu switch over. However I would draw exception to the comparison of it with a 4850. In my mind, the 4850 is to compete with the likes of the 260 from an nVidia pov, hence u can use the comment of "so last year" cos, well, it is. Immediately seeing the 4850 being held against it, I was quite supprized that it held up as close as it did in some respects. It`s counterpart, the 3850 (imo) may well have produced a different picture. Likewize the 260/4850. It`s a tough call cos on the one hand a company is producing a range whereas the other is introduce 2, mainly with slight manufacturing differences.
They are however closer matched cost per frame than the other variations may be, which is where u probably could consider them to be competitors for that region.
The look of this ASUS range of cooling is growing on me. I did think it looked fugly when I seen it first, and don`t have a particular liking of that direction of cooler on a gfxcard - even tho it is a solid method, I`d prefer to blow across and hopefully out of the case rather than swirling around inside hoping for a good exhaust fan. It`s hard to have that blowing across method without a dual slot approach tho.
Great read.
Great read.
I think the 4850 is designed to compete with the 9800GTX+ which it matches more closely. The 1GB 4850 is way above this price point. I agree with Rast, the cooling should be across and out of the case. I think the card is for those who want more than the 9600GT without stepping up £50 to the 9800GTX range. It also offers those with more sense to look for an 8800GT with almost all of the features (oh no I lose hybrid SLI, that I don't have support for) for a massively reduced price.
A really good review as ever guys.
The 9800GT is perhaps out there on its own with regard to comparisons but comparing it to say a 9600GT or a 9800GTX would be quite predictable in its outcome. You could say that the outcome in the 9800GT vs 4850 was predictable but they are 2 cards from different competitors (NVidia vs ATI) while using the same manufacturer (Asus). I attempted to emphasize more towards the cost per frame, which the 9800gt dosn't fair too badly to say it is based on last years tech, it's just the 4850 is such a damn good card.
It is very difficult to say which card is competeting against which.
4850 vs 9800GTX+
4870 vs GTX260?
4870x2 vs GTX280?
or should it be:
4850 vs GTX260 (single vs single)
4870 vs GTX280 (single vs single)
4870x2 vs 280GX2(??) - 2 core vs 2 core?
Obviously price also needs to be taken into account which makes comparisons even more difficult - do we compare on price, performance, or price per frame.
Difficult one I'm sure you can imagine, especially when cards are released with no specific entry point in the market.
Thx for the constructive comments guys.
4850 vs 9800GTX+
4870 vs GTX260?
4870x2 vs GTX280?
or should it be:
Its a good review, I reckon its hard to know what Nvidia are doing with the 9800GT in terms of competition. On the one hand, the 4850 beats it hands down so you should go for that, but the price is higher, and if price is of on object, why not go the whole hog and buy a tri sli 280GTX?
I think the 9800GT is great if you are looking for a GFX below £100, and probably below £90 in a couple of weeks, as it obviously out performs all but the most heavily overclocked 9600GTs.
At the price point I would go for it, but for £20 more I would go for the 4850. It depends on what your maximum budget is and where the fanboy in you lives. Camp red or green people?
It`s tough to decide these days imo.
^^ this would be my line of thinking u see. Including x2 vS x2. x2 vS a single, even tho they may cost the same, is wrong. Possibly like comparing a QX9770 and 3x Q9450.
BUT. nVidia make it doubly difficult as there are 9400/9500, 9600, 9800GS/GT/GTX/GTX+ - 9800 is also *usually* a consolidating card. (hard to say usually)
I haven`t seen a GTX200 equiv of a "general purpose multimedia emphasis" card, like the 9400/9500 would be - perhaps they wont bother.
Costing, tbh, I don`t look at in regards to them - but really I should. But imo, there are 3 camps, those who want the best card regardless of the cost (looking at the tech 1st), those on a budget (they have £100/£200 - what`s the best card they can get for it), and those who don`t mind x2/xFire/SLI/etc.
Imo also, all 3 of those camps are currently being satisfied from both ATI & nVidia. (cept fanbois ofc
Originally Posted by name='webbo'
4850 vs GTX260 (single vs single) 4870 vs GTX280 (single vs single) 4870x2 vs 280GX2(??) - 2 core vs 2 core? |
)Bit off topic, but how does dual 280GTX sli stack up against 4870x2 xf (i.e. 2 x 4870x2s). I heard the 4870x2s don't scale that well.
I reckon at the minute the pricing is a little high and there are too many out on the market, perhaps by next week Nvidia will release a 9750GTS FTW XXX edition so I'll keep my mouth shut.
Very nicely written review as usual mate.
It's an 'OK' card but as you said, nothing special. Nvidia are being a little 'special' at the moment and releasing stupid amounts of cards for not much reason. See the enhanced 260 for a reference to what I mean
those speeds arent stock, i have that exact same card and the stock speeds for me are
Core 600Mhz
Memory 900Mhz
2000mhz on the memory IS NOT possible, i tried it and it artifacted to the EXTREME and nearly FRIED my card.
I think your lying on this review
Core 600Mhz
Memory 900Mhz
Every card is different. Also, this thread is old...2008.
I think he is forgetting that the mem would have been 1000 (and then doubled for the rated 2000) so he would never have even got the slider to 2000
Also each card can have different clocks depending on the Manufacturer. 1post fail, probs wont be back.
lol true. I was thinking along those lines, but gave him the benefit of the doubt.
Lol
Quick rant: These cards suck in SLI, they are single PCI slot cards but the cooler takes up two slots and on most board the cooler cant get any cool air into the cooler when its mounted side by side a second card, as the back of the second card blocks the air flow into the first card. Sot he fan spins up and turns your PC into a noise box.
lol well that was random
http://www.overclock3d.net/gfx/artic...235203144s.jpg
Check out the review
