ASUS 7970 Matrix Platinum
3D Mark
Published: 22nd October 2012 | Source: ASUS | Price: £400 |
You have to look a little way down the graph to see our earlier HD7970 tests, which are the VTX and PowerColor for stock and overclock respectively. Of course we don't expect the stock reference card to match up to the stock ASUS thanks to that factory overclock, and the PowerColor was overclocked to around the same level as the ASUS is out the box. In overclocked trim we're looking for it to handily best the Gigabyte Windforce HD7970.
3D Mark Vantage
An inauspicious start for the beast from ASUS. The Matrix Platinum doesn't actually benefit from our extra overclock and when you compare it to the PCS. In fact the PCS just shades it in the P score and it's only in the Extreme preset that the Matrix manages to squeak out a lead.
3D Mark 11
The more shader intensive tests of 3D Mark 11 continue the above result, with the Matrix Platinum not making the most of the clock speeds available, only matching the PowerColor and being beaten handily by the Gigabyte Windforce.
(Except for NZXT, that was pretty funny!)ASUS could have at least sent a cherry picked review sample, so they wouldn't look as bad.
By the way, Tom, is it planned for the future to get the graphs in HTML5 instead of Flash (or some sort of compromise). I went on this on a mobile device and none of the numbers would show.
tom was swearing and that doesnt happen often
I really get the sense that they are using the Republic of Gamers branding on products that aren't really that premium. If they continue to dilute the brand it will become worthless. I also don't think the lights on the side of the card are a good idea, makes it look like a cheap afterthought to distract from the cards main fault: Performance.
the platinums ARE cherry picked...hence the "Platinum"
different version becasue they are all upside-down giddy with the results.
comparo to GTX and gains over the reference cards, you'd thought the 2nd
coming was in this card. dribble... just dribble.. cost to performance ratio is
so lope-sided.
"....11% performance improvement over the regular HD 7970 and a 3% boost
over the HD 7970 GHz and MSI HD 7970 Lightning." for 35-40% more cost to
the Lightning?
but nobody else is barking about the low frequency clocking ability. edged by the
PowerColor at more cost?
should have been stomped a mud-hole in the competitions butt on this purchase.
but instead "edged-out" by its competitor..
ASUS good for you, but i think this is not a great card from the stables of ROG
performance line..
another spot-on point was the RBG lighting and the control. Corsair Link was
getting similar flack on the "effect" and gave "ownership" to the end-user instead
of locking them out. same aurguement, "oohh it changes under load.." obvious
reply, "MEH".
just my opinion...
airdeano
if my money tree didnt die, id buy another and send it to tom to see if the results be similar
thats why i think this one was a dud....it happens.....
if my money tree didnt die, id buy another and send it to tom to see if the results be similar |
I hope they send him one that performs to rectify the situation, otherwise they will suffer imho.
I agree. I seriously doubt ASUS are stupid enough to brand a card for overclocking and then not cherry pick the chip that goes on it, especially when they'd be sending samples to reviewers such as TTL.
I hope they send him one that performs to rectify the situation, otherwise they will suffer imho. ![]() |
puzzled looks. but reading other reviews, it sounds pretty on par with
what Tom's already said as far as performance. they just "gussied" the print
up for specatular effects. not saying speaks as loud..
airdeano
My trust in Tom's reviews surpasses anything else on youtube. They're just the most detailed and honest videos I've seen on youtube. (to me if Tom says it's bad - it's bad, end of)
Off to google now to see what people write about this card.
Obviously this card isn't all they say it is
Regards.
C.
Theres only 24 hours in a single day so sadly not. If I retest this why shouldnt I retest all the other 7970's or even 680's because they have new drivers out too!
Or
Mars, as one Marian day = 58 days and 15 hrs Sol days
Or do what said
Regards.
C.
We finally get our hands on the top-line HD7970 from ASUS, the Matrix Platinum. Has it been worth the lengthy wait?
Continue Reading
