8800GTS shootout - XFX 8800GTS XXX vs Gainward 8800GTS "Golden Sample"
Game Benchmarks - CS:Source and Call of Duty 2
Published: 5th March 2007 | Source: XFX | Price: |
Counter Strike: Source is a hugely popular online FPS game based on the Source engine by Valve. This will show what a typical gamer will play on their PC and is a great indication of real-world gaming performance as the engine is so scalable.
Call of Duty 2 is a fairly recent game that uses a lot of DirectX 9.0c features, including real time shadows, amazing smoke effects and some nice looking HDR effects. This makes the game very taxing at these high resolutions. I played a fully patched up version of the game. Once again I played through the game with a two minute gaming session including explosions, smoke and also lots of snow.
Let's see how the cards fared here:
Somewhere along the line I was wishing u`d take a screw-driver to those coolers, the pcbs look almost identical asif these guyz are working extremely close together. Like in the same building :p
I see many are already posing whether it`s better value to get a base card and do all the clocking uself. Meh.
Great review Kemp.
They're all the same as the reference boards i expect.
As for the clocking we can oc the core but not the stream processors:(
I took the 8800GTX apart in that review.
If your particularly interested I could take apart another GTS and post some pics?
And ye you can OC the core clocks/memory clocks but I haven't found a way of doing the stream processors yet
If I`m the only one looking for hardcore up-cooler shots, I wouldn`t bother, if I do some searching there bound to be something out there ;)
i use ATitool for my oc'ing and you can have it load the oc on startup and it tells the temp... i have mine running at 640/1000
havnt seen the temp go above 70*c yet cuz i got some insain air fed to my card at all times... two 80mm fans and a 120mm all blowing on it
