Zotac Z68-ITX WiFi Review
PC Mark
PC Mark Vantage
With the various synthetics out of the way it's time to look at how the system performs in tasks more akin to those it'll undergo. Stripped of the 'single-element' aspects of synthetic testing the Z68-ITX WiFi performs much closer to where our vast experience would have pegged it. The reduction in memory speed has a cumulative effect upon ever action and, when coupled to the slightly reduced CPU speed, the overclocked score reflects this. Defaulting the memory to 1333MHz definitely hinders the stock result which is fairly poor by any yardstick.
PC Mark 7
The much newer PC Mark 7 is far tighter in its testing and takes much greater advantage of the parallel computing possibilities of modern processors. Showing how the Zotac isn't easy to pin down the stock result suddenly leaps ahead of the competition and even overclocked it's not a mile behind the nearly-as-small Gene-Z.
«Prev 1 2 3 4 5 6 7 8 9 Next»
08-07-2011, 07:32:52
tinytomlogan
Today we're taking a look at the latest ITX board from Zotac, based around the Z68 chipset. Is it a pocket powerhouse?
Continue ReadingQuote
08-07-2011, 07:55:42
sheroo
If you look at all the recent SB itx boards from Asus & Gigabyte, they also have the socket too close to the pci-e slot. But those are H61 & H67 boards that won't overclock. I'm eagerly awaiting the upcoming Z68 board from Gigabyte, hopefully they'll move the socket over so that you can get decent tower cooler on there. The Thermalright axp 140 seems to be the best choice for these boards at the moment - but the tolerances are very small....
The Prolimatech Samuel 17 is also a good choice.Quote
08-07-2011, 09:37:34
Rastalovich
http://www.xcase.co.uk/PCI-Express-16X-Riser-Card-Slim-Case-p/riser-xlps005.htm
£12. Would have been good for testing purposes.
In fairness to the manufacturers, they'd not envisage the sense in buying an itx mobo and sticking a tower on it. You'd ideally be looking at the smallest case to fit the thing in with your low power cpu and possibly a 1u/2u type cooler.
For benching the thing, naturally you'll go with the best cooler you have at hand and clock the crap out of it the best you can.
These itx mobos are too expensive imo.Quote
08-07-2011, 09:45:53
SieB
Exactly what I was thinking, you can get a full ATX one for the same price and seen as these Itx are half the size and use less PCB etc they should definietly be cheaper, by at least £40.Quote
08-07-2011, 09:53:40
dugdiamond
IMO they are pointless for the likes of the power-users of this forum
but it is nice to know the developments of certain manufacturers
if it looks tacky and doesn't overclock very well, i ain't interested - lolQuote
08-07-2011, 15:10:50
sheroo
I have been following the development of these itx boards for a few years now, waiting to build a small powerful rig. Zotac build alot of these itx boards but I think that their history has been somewhat spotted. I remember the old 9300 based boards that were billed as the ultimate itx board, but they wouldn't go to sleep properly. I personally wouldn't buy a Zotac board and have been waiting for the SB itx boards to mature. For my money I would buy the Asus P8H67-I Deluxe, it has just about everything - but you can't overclock it... I hope Gigabyte hit a homerun with their Z68 offering...Quote
08-07-2011, 15:17:03
tinytomlogan
Im also waiting for the Gigabyte Z68 varient as the H55 version was awesome!Quote
08-07-2011, 20:57:39
badtaylorx
sorry zotac,,,im not impressed... 4.5Ghz is just barley over the 4450Mhz i can squeeze out of my mini itx amd boardQuote
