Zotac H55-ITX Review
Published: 7th April 2010 | Source: Zotac | Price: £109.99 |
Introduction - "The Ultimate LGA1156 Mini-ITX Platform Unleashed"
Does size really matter? Well contrary to popular belief, manufacturers have successfully disproved this theory as over the last 18 months there has been a rising popularity for Mini ITX machines. With a footprint of just 17cm either side and a growing availability of quality chassis and motherboards we have never been this close to pint sized performance machines. Since last year, Zotac has been the ring leader of Mini ITX motherboards, including the critically acclaimed ION-ITX and performance oriented LGA775 GeForce 9300-ITX boards. Having already established their winning formula, they have moved on to produce a true successor to their Intel Core 2 Duo/Quad compliant solution... Meet the Zotac H55-ITX.
For a board of it's size you will be surprised to see what Zotac have been able to implement. When one considers that just a couple of years ago the Micro ITX market was mostly littered with embedded VIA C7 or entry level Intel/AMD platforms, it's clear that the times have really changed.
Specifications
| Processor Support | Intel LGA1156 Pentium/Core i3/Core i5/Core i7 Processors |
| Chipset | Intel H55 |
| Memory | 2 x DIMM, Max. 8GB DDR3-1600/1333/1066/800 |
| Expansion Slots | 1 x PCIe 2.0 x16 |
| VGA | Multi-VGA output support: HDMI, DVI-D, RGB Supports HDMI with max. resolution 1920 x 1200@60Hz Supports DVI with max. resolution 1920 x 1200@60Hz Supports VGA with max. resolution 2048 x 1536@75Hz |
| Multi-GPU Support | None |
| Storage | Intel H55 Chipset |
| LAN | Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel Controller. |
| Wireless LAN | Atheros 802.11n 300Mbps Wireless LAN Controller (Mini PCIe) |
| Audio | Realtek® ALC892 8-Channel High Definition Audio CODEC |
| USB | Intel H55 Chipset - 14 x USB 2.0 ports (10 x Rear, 4 x Internal) |
Yowzzza! Onboard this little wonder you will find no less than 10 rear USB ports, 6 x SATA II, e-SATA, 300Mbps 802.11n WiFi and full PCI-Express 2.0 16x support. With the exception of USB 3.0/SATA 6.0Gbps or Multi-GPU, the Zotac H55-ITX is as feature rich as any other Intel Core i3/i5/i7 motherboard on the market. Now don't go incontinent on us just yet as the real surprises lie in the photographs that follow.
With the GMAHD from the CPU, will it handle basic media duties like bluray as its 9300 predessecor would?
Other known issues are lack of turbo boost support on first production batch and waking from S3 problems with most PCI-E video cards. So far all these issues remain unfixed.
Originally Posted by name='Diablo'
Really nice looking board. I love the mini itx form factor, but am always stumped by fitting a graphics chip as the powersuplies aren't built to take them. This one looks very good for a media PC, or for a mini gaming box.
With the GMAHD from the CPU, will it handle basic media duties like bluray as its 9300 predessecor would? |
I've found the Core i3/i5's Integrated GMA to be a considerable step up from predecessors such as the GMA950. Performance wise, it is most certainly up there with the GeForce 9300 and Radeon HD 4200 and should not really struggle with HD Video.
If I were going to do an HTPC build (not on the cards right now thanks to my debit cards just melting) that's certainly good news.
How ever saying that alone the MB looks like another winner for zotac and could be a future purchase for my self. (once i have some money ROTFLMAO)
The review how ever doesn't realy float my boat and just looks like bloat ware in words.
I had no idea that the onboard GPU was so good for L4D, i was expecting like 10fps when I seen it at first. What cooler were you using, stock?
This had crossed my mind after completing the review and I strongly apologise for the oversight on my part. Today, I have taken our previously reviewed Biostar TH55XE Motherboard and ran the same tests once more. Due to time constraints I have not tested the Biostar at 3.30GHz but at least we now have a fresh "stock for stock" comparison without recycling previous results.
The results are also in keeping with the previous results and I maintain that the Zotac H55-ITX performs on par with it's fellow Micro ATX and ATX competition.
Many thanks for the feedback.
@ peterstoba - Yes, the i3 GPU really isn't bad at all. It's not the smoothest L4D experience but it was certainly playable. I would be interested to hear how you'd rather arrange the components on the board though?
Now looking though those results sort of put me in two minds lol. As tbh there isnt that much of a performance gains over the biostar and the old duel core again isn't a vast mind blowing performance boost.
With the price just dropped on the old Zotac C2d to a stellar £99 i think if you had a value for money sticker it would go to to the C2d right at this moment in time. AS we know the only reason for the price drop would be to shift the old stock ready for this new breed to take over its place.
One thing with Micro / Mini ATX you don't need the latest and greatest to be able to run anything under the TV or mini gaming system or even via arcades and juke boxes (for my case).
Do u know what the estimated Wifi range is does the new Duel aerial really give that much speed it would be good to see if it did or not. Because this estimated wifi speed has all ways been incorrect and misleading.
However have a read through the whole review again and looking at the pics of the bored personally i like the lay out its nearly perfect except i would have the wifi turned around facing the other way so that the antenna wires didn't go in-between the CPU and other components giving less interference and also stopping the chance of snagging against the CPU HFC. I think the CPU is a little close to the PCI express but a good use of Heat pipe technology would get around this problem. All so some thing ive just spotted would be i would change the antenna so that instead of being placed up and down i would have them side by side as most mini / micro atx form factors are flat and this would give better dispersal for the wifi and help with range.
All so something missing from the review which would be good would be temp readings. How does it play encased in the small mini / micro atx form factor case. Does it get warm. This would be good to know as these type systems can be used behind TV's (which do get warm all ready) , in manufacturing’s systems (again which do get warn all ready) and in some very wired places. I think this sort of attention to detail in the review would put this sort of review a step above the rest and giving real informative information that would need to be considered when using systems like this. I know from my past builds Heat has always been a problem and getting around the heat problem has sometimes been a headache.
Any way over all thank you for the review and the extra work you have put in.
Originally Posted by name='mayhem'
However have a read through the whole review again and looking at the pics of the bored personally i like the lay out its nearly perfect except i would have the wifi turned around facing the other way so that the antenna wires didn't go in-between the CPU and other components giving less interference and also stopping the chance of snagging against the CPU HFC. |
I think the CPU is a little close to the PCI express but a good use of Heat pipe technology would get around this problem. |
All so some thing ive just spotted would be i would change the antenna so that instead of being placed up and down i would have them side by side as most mini / micro atx form factors are flat and this would give better dispersal for the wifi and help with range. |
We were not provided with any range information with regards to the Atheros 802.11n WiFi module. The testbed was however connected to our 802.11g network throughout the testing and didn't exhibit any unstable behaviour. There was no way of testing it's 300mbps capability, however the adapter most certainly held a consistent 54mbps throughout testing.
I too would agree that the previous Zotac GeForce 9300-ITX remains to be a fantastic motherboard if you are less fussed about using an up to date platform. I've had one for nearly a year now and when combined with a Core 2 Duo E8400, it has offered fairly competitive performance.
Continue Reading
