The Computer Council - Clocked Gamer Quad
3D/Rendering Results
Published: 7th July 2008 | Source: TCC | Price: £999.00 |
Respect to TCC, nice rig with a great, sensible spec. It shocks me how some companys fool nubs with the stupid sales tricks by throwing in "extreme dx10 gaming with sli" with poorer cards such as a pair 8600's when a much better single card solution is a mere £30~£40 more. Good call on the psu aswell, I'd be horrified to buy a high end rig with a cheapy psu in it.
Cheers for the read
I agree with what you said about the website as well, it just lacks the right feel.
This is indeed the first in what will hopefully be a fairly long line of system reviews. We've got some gaming notebook reviews coming up soon, so look out for those.
But as always, we're not gonna slacken off on the cutting edge hardware reviews
Seems we have found another good contact.
Originally Posted by name='ionicle'
looks like a good system, personally, i wouldnt give up the fun of building my own for a prebuilt
I might buy prebuilt if it was cheaper than building it, had good components and was still just as clockable. (prob never going to happen tho)
I'm also a bit bemused at the benchmark results?
Is it the same spec just not overclocked?
If so, it just really proves that overclocking gains performance which is the whole basis/point of overclocking?
Gaming laptop reviews could be interesting
Originally Posted by name='equk'
I'm also a bit bemused at the benchmark results? Is it the same spec just not overclocked? If so, it just really proves that overclocking gains performance which is the whole basis/point of overclocking? |
Originally Posted by review
Being the first PC system review conducted here at Overclock3D, we unfortunately do not have any results from previous systems to compare the Clocked Gamer Quad against. However, for the benefit of comparison we have constructed a similar spec'd non-overclocked machine to give an idea of just how much faster the Clocked Gamer Quad is to an "off-the-shelf" PC. |
It was a t0ss-up between benchmarking it against nothing which would be totally pointless, or benchmarking against a stock clocked machine and at least giving a small amount of readers the opportunity to see what advantage overclocking has.
Just shows what a nice overclock really does.
Tis good to see the time and effort put into each PC built by TCC.. Good job guys!
The specs of the rig - you already addressed the 4gb issue so hats off, use the ReaperX they rock. The £15 cooler really isn't acceptable in my eyes on a £1K machine; a TRUE should be sitting pretty on that quad. The gpu; having owned two X2's I can safely say they are not gamers cards at all. They give erratic, sluggish performance and when I swapped out the X2 for my 88GT there was hardly any difference in performance. For this reason I believe TCC should use a 98GTX (even a GTS, both are cheaper and better than the X2) and OC it. The CPU overclock is pretty unspectacular BUT I'm willing to let that slide on the basis it is a pre built machine and TCC offer a warranty etc.
Jim - I'm a little shocked in the OC section you 'pushed' to 3.4 on the same voltage and threw the towel in. 1.55v is more than safe for 24/7 usage for years, I'd liked to have seen a voltage increase and a real attempt at pushing for more mhz. This is even more important on this setup as the X2 is involved as it simply laps up cpu power, with every 100mhz it's performance increases (from my own observations and researching around the net).
On the whole the system offers a great pre built system better than most other pre built systems, none of the components are bad but there are better alternatives in the same price category, e.g. even if the X2 was one of the cheaper ones at £240 the 98GTX can be found for £190, saving £50. This can be reinvested into the machine to offset the 4gb reaperX upgrade and the TRUE (as I see it there is the £50 saving on the gpu plus the money for the AF7 and the existing ram). With these changes the quad gamer would be just that, more of a gamers machine, definitely superior to competitors offerings. Actually, I’m going to go a little further and say an e8400/e8500 should be offered as an alternative, they overclock higher than the q6600 and with the lower tdp the air cooler can adequately handle the bigger OC’s. They also yield higher frame rates and sm2/sm3 scores than their quad brethren.
Just a few thoughts, I’m at work, this is rushed so consider this my disclaimer against any mistake/oversight
Overall a good job
Side note: I'd be happy to review any pre built system.
Originally Posted by name='Mr. Smith'
I'm going to be a little critical here because, frankly, it's in my nature
![]() The specs of the rig - you already addressed the 4gb issue so hats off, use the ReaperX they rock. The £15 cooler really isn't acceptable in my eyes on a £1K machine; a TRUE should be sitting pretty on that quad. The gpu; having owned two X2's I can safely say they are not gamers cards at all. They give erratic, sluggish performance and when I swapped out the X2 for my 88GT there was hardly any difference in performance. For this reason I believe TCC should use a 98GTX (even a GTS, both are cheaper and better than the X2) and OC it. The CPU overclock is pretty unspectacular BUT I'm willing to let that slide on the basis it is a pre built machine and TCC offer a warranty etc. |
True on the cooler, but in all honesty it does the job nicely. Everybody rates this particular cooler, and rightly so.
Jim - I'm a little shocked in the OC section you 'pushed' to 3.4 on the same voltage and threw the towel in. 1.55v is more than safe for 24/7 usage for years, I'd liked to have seen a voltage increase and a real attempt at pushing for more mhz. This is even more important on this setup as the X2 is involved as it simply laps up cpu power, with every 100mhz it's performance increases (from my own observations and researching around the net). |
Fair enough on the OC but I still think my point is valid. I imagine someone buying this kind of machine will look into OC'in...
I gtg... work, work, work!
6.4's?! I used the 8.1/8.2/8.3's... It isn't a gamers card. It's for benching imo
I`m imagining a customer for TCC & this gaming quad not necessarily being an `enthusiast`, but some1 who would either like to be an enthusiast, or wants to be in-touch with enthusiast stuff - but has no time to actually be hands-on or something.
Let`s face it, £1k.. we here, in the majority would buy our own dfferent kit individually, install it differently, and have cash for pizza and coke afterwards.
But if u don`t have the time ? Or if the time it takes a fringe enthusiast to spend on this is more valuable to them than the overhead ? Or really if u want to buy something from a a pos (point of sale) and have the service that goes along with it ..
Other companies do these "gaming" pcs for around £1k, it`d be interesting to have a row of comparisons.
Originally Posted by name='nunzio'
Good review.. but i do hate that case.
i can see why water cooling may be an issue (Transit may cause a leak)
Originally Posted by name='Hassan'
Petty it isn't water cooled.
i can see why water cooling may be an issue (Transit may cause a leak) |
also,
Interestingly, TCC only sell their systems online, meaning that there are no salesperson pushes to 'sign on the dotted line' when viewing the systems.
I think you should of pushed on this point a bit more, and not left it at "no pushy salesmen". Very few people would choose an online only company over one with a shopfront.
I really cant help but feel that the first page was written by "the computer council". Sorry.
Originally Posted by name='AdamR79'
The review (page 1 in particular) read more like a sales pitch for the company than an independent unbiased review.
also, I think you should of pushed on this point a bit more, and not left it at "no pushy salesmen". Very few people would choose an online only company over one with a shopfront. I really cant help but feel that the first page was written by "the computer council". Sorry. |
anyway entitled to your opinion
We do base a huge amount of our business on excellent service, which is why I think OC3D decided to highlight this here, since afterall - this is a huge factor of any significant purchase.
There are definate plans in place to give the site a facelift, and hopefully integrate a whole new ordering system with much better options for customer's to configure their own PC. It'll be even easier to navigate around and find exactly what you're after - with a much wider choice.
Originally Posted by name='Pat123'
I would try and make the site a little more 'attractive' though, but in all fairness it works well and it is extremely easy to navigate.
We have now addressed this issue with the launch of a new website and ordering system. Feel free to have a nosey.
http://www.overclock3d.net/gfx/artic...121022368l.jpg
Clocked Gamer Quad Review
