P45 Showdown - Asus P5Q Deluxe vs MSI P45 Diamond
P45 Diamond - Features & BIOS
Published: 27th May 2008 | Source: Overclock3D | Price: TBA |
Features
One of the major attractions of an Asus board is the vast array of features they have, some of which you may find useful, others seem to be more inclined to sell the board rather than to be made use of depending on your main intentions. MSI seem keen to push DrMOS, which holds a trio of functions.
Green Power
Similar in task to the ASUS EPU chip, the MSI variant claims an efficiency rating of 93.1% giving -6w loss compared to legacy mosfets. This figure is lower than the Asus equivalent 96%+ rating, but those of us non-politically correct overclockers tend to care little about how 'green' our boards are and are much more interested in how cool and stable the power delivery system is.
XpressCool
Because of the above GreenPower, both variants of this serve to run the mosfets cooler due to this higher efficiency with the MSI, reporting a 16c drop in temps due to the new design over the older legacy design.
Rapidboost
Again MSI and Asus have taken similar directions with power delivery, but MSI are calling their variant RapidBoost. With a higher power density in the VR, the potential for overvoltage is increased. Along with a dedicated chip that switches the power load in response to processing conditions, this makes for a very efficient performance enhancer.
OC Jumper & Hi-C Cap
The two little green OC jumpers (above left) allow you to instantly overclock the FSB to 5 different levels: 200 (default), 266, 333 and 400mhz, depending on their orientation which, as it is hardware set, will provide greater stability according to MSI rather than just BIOS settings alone.
They are, however, in a very awkward position and will be difficult to use with even a double slot card above, never mind a CrossfireX solution, so I can't help feeling these might not be made use of too often. Above right we see the Hi-C Cap (capacitors). Due to the higher heat resistance, MSI inform us that high overvoltage and therefore high overclocks should be possible, and due to the reduced heat these types of capacitors should also be more durable, lasting 1000hrs @ 85c according to MSI.
Circu-Pipe Liquid
Rather than air cool the Northbridge, MSI have given the user the option to use a watercooling solution - testament to the fact that the P45 chipset is most likely just as hot as its predecessor, the P35. The Circu-Pipe waterblock is innovative in that it uses a 2 in / 2 out design.
Flipping the board over we see the backplate design, which is always welcome. This also signifies that both the CircuPipe waterblock covering the Northbridge and the left most heatsink covering the mosfets are screw down variants. Again, MSI opted for pushpins on the remaining motherboard heatsinks.
I couldn't resist taking a closer peek at the waterblock itself and I was shocked to see that the inlet/outlets were tiny. Reducing down from the most commonly used 1/2" tubing to what appears to be less than 5mm inside diameter will massively restrict flow and therefore provide a less than ideal cooling solution. That said, the heat dissipation from water exceeds that of air, so if you plan on having a separate loop for the NB, then this block should provide the cooling necessary with its relatively tall, albeit widely spaced, fins.
I am unsure whether the mid-plate is copper or Aluminum, and one can only hope that it is the former as mixing metals in a waterloop is seen as a big No-No in the watercooling fraternity. Maybe in later revisions MSI engineers would do well to take a few ideas from current aftermarket chipset waterblocks, as I feel any serious watercooler will most likely replace this block with their own choice. The block is not even of a solid design, being 'welded' to the baseplate, which will further decrease cooling capacity. The heatpipes are then threaded between the midplate and baseplate to assist with the cooling of the Southbridge and mosfets. I do wish manufacturers would get the design right the first time rather than making what appears to be a hash of it and charging us for the privilege of removing it to attach our own preferred waterblocks. It is, however, creditable that MSI have acknowledged the widespread and increased use of watercooling in today’s enthusiast market, and the design is not much worse than that of the Asus ROG SE waterblocks. Although it is of a poor design, it is better than air cooling and will give the watercooler the option of watercooling the NB without having to void the warranty by ripping off the heatsink assembly.
BIOS
Jumping straight in at the deep end and into the 'Cell' section (which to you and me is the overclocking section), we see the layout is vastly different from the Asus BIOS. I was puzzled at first as to how to change the more common settings such as Vcore since they were greyed out. They are changed via the + and - keys and cannot be directly typed in nor will a drop down list be available for you to choose your selection. There are, however, a fair amount of settings available, and once you spend some time getting to grips with the BIOS, it becomes pretty straight forward.
Once more the voltage options will glow angrily should you exceed the recommended settings, but personally I feel that the red warnings are a little on the conservative side as 1.5v on a Q6600 is hardly going to kill it anytime soon (but don't quote me on that!). All the memory options you could wish for are also in there should you wish to get the absolute maximum performance out of your DDR3, as are numerous dividers. I feel this is a good time to point out that if you don't set the jumpers on the motherboard to the correct position (i.e removed) you will have a hard time getting any where past 250FSB as I found out to my displeasure. MSI claims that hardware jumpers will give more stability to an overclock, but personally I found it to be a very big inconvenience when trying to test out the overclocking on this board, which I shall explain in more detail after I take you through our testing setup and procedures...
Stellar review as always Jim. The ASUS P5Q appears to have the goods where it counts although the MSI P45 Diamond is well laid out - bar the colour scheme.
Well done
Well done
good review
gotta love the mass of extra's you get with the msi
but i've worked with msi's before, they're great stable boards, at stock...or when overclocked, its just so frustrating if you want to overclock, hense why i left my proccy stock when i had my P975x platinum...lol
gotta love the ease of overclocking with asus
Great review Rich
Not sure about the conclusion although I agree about the overclocking. If the MSI board is a good price then with the extra's it's a definate contender
This board could be the new price performance king according to the early prices some shops got listed, espacially with the 2 x 8 Xfire implented this could be a great replacement for my current P5K Deluxe, tempting
Good review. Does anyone know if the mid-range P45 boards will support x8 + x8 XFire or if it's just on the high-end ones? I'm glad P45 is coming out soon, hopefully be able to combine it with a good PCI-e 2.0 card once all the new ones come out and settle down in price.
Good to know, leaves me with some options open if I ever decide to go dual-card and get a bigger monitor
Seems like sckt775 is going out on a high- even once intel stop making new proccys for it, it will still probably be a competitor for the next couple of years at least.
Seems like sckt775 is going out on a high- even once intel stop making new proccys for it, it will still probably be a competitor for the next couple of years at least.Great review! Really interesting read!
There's a slight mistake on one of the graphs on page 8, with the numbers, and also a reference to a picture of the asus mobo early on in the review, but it hardly matters as the review was concise and thorough. Thanks
Well done ![]() |
. Yeah the MSI is very well laid out apart from the jumpers. Both are very neat and tidy boards. Regarding the colour scheme, I guess it depends on if you like a 'pink slot' or a yellow one (for your memory)
.Quote:
Originally Posted by name='ionicle'
good review
![]() gotta love the mass of extra's you get with the msi but i've worked with msi's before, they're great stable boards, at stock...or when overclocked, its just so frustrating if you want to overclock, hense why i left my proccy stock when i had my P975x platinum...lol gotta love the ease of overclocking with asus |
Originally Posted by name='Kempez'
Great review Rich
![]() Not sure about the conclusion although I agree about the overclocking. If the MSI board is a good price then with the extra's it's a definate contender ![]() |
Yeah the MSI would have to come in at a good price for me to consider it and as stated in the review I would personally consider buying a separate block for the northbridge if watercooling (which will add to the cost).
Great review
. I dunno about the overclocking issues with the MSI though, my P35 based MSI OC'ed just as easy if not easier than my P5B Deluxe WiFi/AP. The jumpers can be a bit finnicky though, I will say that.
. I dunno about the overclocking issues with the MSI though, my P35 based MSI OC'ed just as easy if not easier than my P5B Deluxe WiFi/AP. The jumpers can be a bit finnicky though, I will say that.Quote:
Originally Posted by name='webbo'
HAHA! To be fair Jim did alot of editing to the review and smartening it up so it's only fair he gets some credit for it (Cheers Jim!) as I was up until 2a.m getting the main bulk of it done the day before I was due to go on holiday so Jim came to my rescue!
Originally Posted by name='WC Annihilus'
He wasn't the only one >.>
Cheers for the help WC
Cheers Nick! The main issue I had was not the difficulty in the bios itself, despite it being a little unfamiliar and an odd layout. It was the fact that when a bad overclock was set a CMOS reset was required. While hardly a big deal it was a pain to go through and set everything up again rather than just change the bad overclocked settings. It just felt as though the Asus had a wider margin for error and was more forgiving than the MSI.
Originally Posted by name='NickS'
Great review
. I dunno about the overclocking issues with the MSI though, my P35 based MSI OC'ed just as easy if not easier than my P5B Deluxe WiFi/AP. The jumpers can be a bit finnicky though, I will say that. |
so is it worth buying for an upgrade from an asus p5k-e wifi?
Yes.
Nice review, cudos to you Webbo. I was lost with this MSI P45 Diamond and have made a little headway by paying attention to your settings from the bios pic from the overclock you did to the P45 Diamond. Beforehand I could not make heads of tails with it. Wish I had seen your review 1st, but oh well I'm here now, I've developed patience after working with the EVGA 790i after 6 RMA's got a refund 'which I am still waiting on' got an Asus Striker II NSE 790i and I am very pleased, easy to work with.
Dahhh! so why get the MSI, wanted to try ATI based board and the DFI UT X48TR3 came 2 doa so Newegg gave me a refund and I bought the P45 Diamond.
You are right its a pain to clear C-mos and have to reset everything, found out you can turn it off 3-4 times waiting 10 second after shut down to power back up MB automatically picks up bad OC and you can keep your previous settings. I don't know which is the bigger headache.
Thanks for the review "GREAT WORK" webbo, jim and wc.
Thank you for the comments. It's always good to get some positive feedback aswell as the negative for reviews.
http://www.overclock3d.net/gfx/artic...130043211l.jpg
Asus P5Q Deluxe vs MSI P45 Diamond Review by Webbo
