P45 Showdown - Asus P5Q Deluxe vs MSI P45 Diamond
P5Q Deluxe - Packaging & Contents
Search Reviews
Asus P5Q Deluxe
The P5Q Deluxe, as with all Asus boards lately, arrives extremely well packaged. The box itself is a very fetching metallic blue affair, detailing the various features the P45 board has to offer. On the front of the box, the main features advertised are the EPU-6 Engine, DDR2-1200, and FSB 1600 support along with Asus' Express Gate, all of which I will cover later in the review. The feature list is further advertised both inside the flip up lid and on the rear of the package, which also goes on to give a full run down of the specification.
Asus P5Q Deluxe Box Open Asus P5Q Deluxe Box Back
Here we see the board itself. Asus have begun to use blue metal covers on the copper coloured aluminium heatsinks which are then attached to the copper heatpipe assembly. I'm not completely sold on the colour scheme, but no one can accuse the board of looking bland. A plus point for watercoolers is that the heatsink assembly is part screw-down (mosfet area) and part push-pin style. However, I fail to see why Asus didn't use the screw down fixings to hold down the NB/SB assembly and not just the mosfet area.
 Asus P5Q Deluxe Board Top   Asus P5Q Deluxe Contents
Solid Japanese capacitors are used throughout (despite Gigabytes recent claims) which should make for a very durable board, and with a wealth of connectivity ports you shouldn't be left wanting for anything. Onto the accessories we find that although the offering is sparse, everything you need to get up and running is included. Of notable interest are the Q-shield (a 'cushioned' I/O backplate), Q-connectors that are now making a regular appearence and the optional mosfet cooling fan, again, now a regular among Asus accessories.
Asus P5Q Deluxe CPU Area Asus P5Q Deluxe Backplate
Asus P5Q Deluxe Northbridge Asus P5Q Deluxe Southbridge
Above left we see the CPU and mosfet area. Count them Ferrite chokes guys! There are 14 to be exact (plus another 2 for the memory) making this motherboard a 16 Phase power design, which should allow for extremely clean power delivery to the CPU and memory and hence allowing for the highest possible overclocks. Advertising a power efficiency reading of 96%+,  the 16 phase VRM design should also keep the temps down on the MOSFETs and send the tree huggers back to terminal 5.
Above right, we see that backplates are also attached to the rear of the board around the mosfet area to allow high tension (and therby great contact/cooling) around that area. Below left is the oversized Northbridge P45 cooler. It is clear by this design the P45 chipset is still going to need some serious cooling. Once more the actual fin design appears to be a copper coloured aluminium type metal rather than pure copper and is emblazoned with the blue Asus insignia. Following on with the same theme is the southbridge below left, also attached via heatpipe. As previously stated the NB and SB areas are both held down by traditional push pins rather than screws but even so the heatsinks feel solid enough. We shall see how well they perform later in the review.
Asus P5Q Deluxe I/O Ports Asus P5Q Deluxe PCIe
Connectivity is an area where Asus have always shined and the P5Q Deluxe does not disappoint. With 6 USB ports (expandable to 10), eSATA, Firewire, Dual Gigabit ethernet ports, S/PDIF and a mouse/keyboard PS2 port, everything is there that you should need for a modern day multimedia PC. Above right we see the various expansion slots of the board, featuring 3 x PCIe x16, 2 x PCIe x1, and 2 standard PCI ports. The blue and top black PCIe x16 ports are the main interfaces used for a CrossfireX setup. When CrossfireX is detected, the ports drop down to PCIe x8 and the bottom most slot then becomes PCIe x4. We shall see how PCIe x8 performs when we test it with our Quadfire dual 3870x2 setup. Also worthy of note is the onboard power and reset switches allowing the board to be powered on and reset without the use of case buttons. This feature is usually only seen on ROG motherboards, so it is nice to see them being incorporated across the range.
That pretty much rounds up the P5Q Deluxe's physical attributes, so let me indulge you with a brief run down of the motherboard's feature set...
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
27-05-2008, 08:16:41
Jim
"With Intels latest chipset about to be officially launched we have managed to grab two P45 samples and pitch them against one another to see who is top dog."
http://www.overclock3d.net/gfx/artic...130043211l.jpg
Asus P5Q Deluxe vs MSI P45 Diamond Review by Webbo
27-05-2008, 09:11:35
PV5150
Stellar review as always Jim. The ASUS P5Q appears to have the goods where it counts although the MSI P45 Diamond is well laid out - bar the colour scheme.
Well done
27-05-2008, 10:32:12
ionicle
good review
gotta love the mass of extra's you get with the msi
but i've worked with msi's before, they're great stable boards, at stock...or when overclocked, its just so frustrating if you want to overclock, hense why i left my proccy stock when i had my P975x platinum...lol
gotta love the ease of overclocking with asus
27-05-2008, 14:21:42
FarFarAway
Great review Rich
Not sure about the conclusion although I agree about the overclocking. If the MSI board is a good price then with the extra's it's a definate contender
29-05-2008, 09:29:35
CERO
This board could be the new price performance king according to the early prices some shops got listed, espacially with the 2 x 8 Xfire implented this could be a great replacement for my current P5K Deluxe, tempting
29-05-2008, 10:25:52
Kerotan
Good review. Does anyone know if the mid-range P45 boards will support x8 + x8 XFire or if it's just on the high-end ones? I'm glad P45 is coming out soon, hopefully be able to combine it with a good PCI-e 2.0 card once all the new ones come out and settle down in price.
29-05-2008, 10:27:12
CERO
All P45 based chipsets will support x8 + x8 :up:, just like the X38 and X48
29-05-2008, 10:33:43
Kerotan
Good to know, leaves me with some options open if I ever decide to go dual-card and get a bigger monitor Seems like sckt775 is going out on a high- even once intel stop making new proccys for it, it will still probably be a competitor for the next couple of years at least.
31-05-2008, 04:47:21
Yeungster
Great review! Really interesting read!
There's a slight mistake on one of the graphs on page 8, with the numbers, and also a reference to a picture of the asus mobo early on in the review, but it hardly matters as the review was concise and thorough. Thanks
01-06-2008, 04:30:55
w3bbo
Well done
Glad to see you can't see the difference between Jim's and my own work. Yeah the MSI is very well laid out apart from the jumpers. Both are very neat and tidy boards. Regarding the colour scheme, I guess it depends on if you like a 'pink slot' or a yellow one (for your memory).
Originally Posted by name='ionicle'
good review
Yup the Asus was the 'easier' overclocker by far but I believe the MSI could be pushed further with more time fiddling with the subsettings, as could the Asus so both boards are respectable in that department.
Originally Posted by name='Kempez'
Great review Rich
HAHA! To be fair Jim did alot of editing to the review and smartening it up so it's only fair he gets some credit for it (Cheers Jim!) as I was up until 2a.m getting the main bulk of it done the day before I was due to go on holiday so Jim came to my rescue!
Yeah the MSI would have to come in at a good price for me to consider it and as stated in the review I would personally consider buying a separate block for the northbridge if watercooling (which will add to the cost).
I was surprised how well the 8x8 performed tbh. I honestly thought it would throttle the 3870x2's with them having 2 GPU's each but they were fine. I doubt anyone specifically looking for a xfire board will go for P45 but the option is there for upgrading your GPU grunt if P45 is gonna be your next board.
01-06-2008, 11:20:46
NickS
Great review . I dunno about the overclocking issues with the MSI though, my P35 based MSI OC'ed just as easy if not easier than my P5B Deluxe WiFi/AP. The jumpers can be a bit finnicky though, I will say that.
01-06-2008, 14:40:19
WC Annihilus
He wasn't the only one >.>
01-06-2008, 17:30:46
Jim
Ye props to WC for "the final cut"
01-06-2008, 17:48:11
w3bbo
Cheers for the help WC
Cheers Nick! The main issue I had was not the difficulty in the bios itself, despite it being a little unfamiliar and an odd layout. It was the fact that when a bad overclock was set a CMOS reset was required. While hardly a big deal it was a pain to go through and set everything up again rather than just change the bad overclocked settings. It just felt as though the Asus had a wider margin for error and was more forgiving than the MSI.
05-06-2008, 15:18:18
darkone
so is it worth buying for an upgrade from an asus p5k-e wifi?
05-06-2008, 17:18:06
w3bbo
Yes.
27-08-2008, 01:44:47
yahyaue
Nice review, cudos to you Webbo. I was lost with this MSI P45 Diamond and have made a little headway by paying attention to your settings from the bios pic from the overclock you did to the P45 Diamond. Beforehand I could not make heads of tails with it. Wish I had seen your review 1st, but oh well I'm here now, I've developed patience after working with the EVGA 790i after 6 RMA's got a refund 'which I am still waiting on' got an Asus Striker II NSE 790i and I am very pleased, easy to work with.
Dahhh! so why get the MSI, wanted to try ATI based board and the DFI UT X48TR3 came 2 doa so Newegg gave me a refund and I bought the P45 Diamond.
You are right its a pain to clear C-mos and have to reset everything, found out you can turn it off 3-4 times waiting 10 second after shut down to power back up MB automatically picks up bad OC and you can keep your previous settings. I don't know which is the bigger headache.
Thanks for the review "GREAT WORK" webbo, jim and wc.
27-08-2008, 13:09:43
w3bbo
Thank you for the comments. It's always good to get some positive feedback aswell as the negative for reviews.
