P45 Showdown - Asus P5Q Deluxe vs MSI P45 Diamond
3D/Rendering Results
Search Reviews
Cinebench 10 is a benchmarking tool based on the powerful 3D software Cinema 4D. The suite uses complex renders to guage the performance of the entire PC system in both single-core and multi-core modes. Testing was performed a total of 5 times with the highest and lowest results being omitted and an average created from the remaining 3 results.
Cinebench 1x
Cinebench 4x
Cinebench Open GL
3DMark is a popular synthetic gaming benchmark used by many gamers and overclockers to gauge the performance of their PC's. All 3DMark runs were performed a total of 5 times with the highest and lowest results being removed and an average calculated from the remaining 3 results. Also included are the CrossfireX results to give an indication of how 8x PCIe lanes perform.
3d05
3d06
CrossfireX Enabled
3d05 Crossfire X
3d06 CorssfireX
Results Observations
As expected, the CPU is bottlenecking the GPUs in 3DMark05, with hardly any difference between single and dual card setups. 3DMark06 shows a bigger gap due to the higher resolution, a gap that would no doubt widen if the resolution was increased further. It's clear to see that those with a bigger screen will benefit more from a dual card setup than those on a smaller resolution. One point of interest was that the P5Q Deluxe seems to take the advantage in 3D applications. This could be down to the tighter memory timings.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
27-05-2008, 08:16:41
Jim
"With Intels latest chipset about to be officially launched we have managed to grab two P45 samples and pitch them against one another to see who is top dog."
http://www.overclock3d.net/gfx/artic...130043211l.jpg
Asus P5Q Deluxe vs MSI P45 Diamond Review by Webbo
27-05-2008, 09:11:35
PV5150
Stellar review as always Jim. The ASUS P5Q appears to have the goods where it counts although the MSI P45 Diamond is well laid out - bar the colour scheme.
Well done
27-05-2008, 10:32:12
ionicle
good review
gotta love the mass of extra's you get with the msi
but i've worked with msi's before, they're great stable boards, at stock...or when overclocked, its just so frustrating if you want to overclock, hense why i left my proccy stock when i had my P975x platinum...lol
gotta love the ease of overclocking with asus
27-05-2008, 14:21:42
FarFarAway
Great review Rich
Not sure about the conclusion although I agree about the overclocking. If the MSI board is a good price then with the extra's it's a definate contender
29-05-2008, 09:29:35
CERO
This board could be the new price performance king according to the early prices some shops got listed, espacially with the 2 x 8 Xfire implented this could be a great replacement for my current P5K Deluxe, tempting
29-05-2008, 10:25:52
Kerotan
Good review. Does anyone know if the mid-range P45 boards will support x8 + x8 XFire or if it's just on the high-end ones? I'm glad P45 is coming out soon, hopefully be able to combine it with a good PCI-e 2.0 card once all the new ones come out and settle down in price.
29-05-2008, 10:27:12
CERO
All P45 based chipsets will support x8 + x8 :up:, just like the X38 and X48
29-05-2008, 10:33:43
Kerotan
Good to know, leaves me with some options open if I ever decide to go dual-card and get a bigger monitor Seems like sckt775 is going out on a high- even once intel stop making new proccys for it, it will still probably be a competitor for the next couple of years at least.
31-05-2008, 04:47:21
Yeungster
Great review! Really interesting read!
There's a slight mistake on one of the graphs on page 8, with the numbers, and also a reference to a picture of the asus mobo early on in the review, but it hardly matters as the review was concise and thorough. Thanks
01-06-2008, 04:30:55
w3bbo
Well done
Glad to see you can't see the difference between Jim's and my own work. Yeah the MSI is very well laid out apart from the jumpers. Both are very neat and tidy boards. Regarding the colour scheme, I guess it depends on if you like a 'pink slot' or a yellow one (for your memory).
Originally Posted by name='ionicle'
good review
Yup the Asus was the 'easier' overclocker by far but I believe the MSI could be pushed further with more time fiddling with the subsettings, as could the Asus so both boards are respectable in that department.
Originally Posted by name='Kempez'
Great review Rich
HAHA! To be fair Jim did alot of editing to the review and smartening it up so it's only fair he gets some credit for it (Cheers Jim!) as I was up until 2a.m getting the main bulk of it done the day before I was due to go on holiday so Jim came to my rescue!
Yeah the MSI would have to come in at a good price for me to consider it and as stated in the review I would personally consider buying a separate block for the northbridge if watercooling (which will add to the cost).
I was surprised how well the 8x8 performed tbh. I honestly thought it would throttle the 3870x2's with them having 2 GPU's each but they were fine. I doubt anyone specifically looking for a xfire board will go for P45 but the option is there for upgrading your GPU grunt if P45 is gonna be your next board.
01-06-2008, 11:20:46
NickS
Great review . I dunno about the overclocking issues with the MSI though, my P35 based MSI OC'ed just as easy if not easier than my P5B Deluxe WiFi/AP. The jumpers can be a bit finnicky though, I will say that.
01-06-2008, 14:40:19
WC Annihilus
He wasn't the only one >.>
01-06-2008, 17:30:46
Jim
Ye props to WC for "the final cut"
01-06-2008, 17:48:11
w3bbo
Cheers for the help WC
Cheers Nick! The main issue I had was not the difficulty in the bios itself, despite it being a little unfamiliar and an odd layout. It was the fact that when a bad overclock was set a CMOS reset was required. While hardly a big deal it was a pain to go through and set everything up again rather than just change the bad overclocked settings. It just felt as though the Asus had a wider margin for error and was more forgiving than the MSI.
05-06-2008, 15:18:18
darkone
so is it worth buying for an upgrade from an asus p5k-e wifi?
05-06-2008, 17:18:06
w3bbo
Yes.
27-08-2008, 01:44:47
yahyaue
Nice review, cudos to you Webbo. I was lost with this MSI P45 Diamond and have made a little headway by paying attention to your settings from the bios pic from the overclock you did to the P45 Diamond. Beforehand I could not make heads of tails with it. Wish I had seen your review 1st, but oh well I'm here now, I've developed patience after working with the EVGA 790i after 6 RMA's got a refund 'which I am still waiting on' got an Asus Striker II NSE 790i and I am very pleased, easy to work with.
Dahhh! so why get the MSI, wanted to try ATI based board and the DFI UT X48TR3 came 2 doa so Newegg gave me a refund and I bought the P45 Diamond.
You are right its a pain to clear C-mos and have to reset everything, found out you can turn it off 3-4 times waiting 10 second after shut down to power back up MB automatically picks up bad OC and you can keep your previous settings. I don't know which is the bigger headache.
Thanks for the review "GREAT WORK" webbo, jim and wc.
27-08-2008, 13:09:43
w3bbo
Thank you for the comments. It's always good to get some positive feedback aswell as the negative for reviews.
