MSI P7N SLI Platinum 750i based motherboard
Synthetic CPU & Memory Results
Published: 18th February 2008 | Source: MSI | Price: £118 |
SiSoftware Sandra (the System Analyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on Software and Hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining 3.
Result Observations
The MSI P7N SLI Platinum is middle in the performance terms for the CPU tests, but tends to fall down a little on the memory benchmarks. The board does perform fairly similar to the XFX 780i based board we reviewed previously.
Nice review mate and a decent board to boot!
Now all that MSI need to do is remove Zippy, Bungle and George from the "board colour scheme" team, and they'll have a perfect board
Seriously tho...surprisingly decent OC results from an Nvidia chipset.
Yes, i mean thats better than the 780i boards which are a 'better' chipset..
That is some serious overclocking results.. I mean it beat the others by quite a chunk! Also the 0% CPU utilization was quite impressive.
Great review.
I`m still feeling these 780 boards are `good` without being great.
Some excel with something in 1 area and lose something in another, all very minimally. But appear solid.
Like to see an SLI vS CF of the `best` of the 780i`s vS the `best` 35/38. From a gaming pov, be pretty interesting. All the same stuff cept the gfxcards, that perhaps are close as single cards maybe.
With the prices tho, I don`t think u can turn ur nose up at them.
if they combined that boards performance and features with the DFi black and green colour scheme, you'd be onto a winner
performs sweet though
Dam good looking (oc wise...) board tbh. May invest in one for the bench rig.
Very nice review Matt....bargain!!
Absolutely...
Why not test 35/38 against 780i with the same gfx card (single) to keep things simple... i think i know which ill put my money on.
Originally Posted by name='teknokid'
Absolutely...
Why not test 35/38 against 780i with the same gfx card (single) to keep things simple... i think i know which ill put my money on. |
Edit: And 10...
Aye that's what I did
It's a great board with awesome overclocking, muchas surprising!
Wow, very surprising indeed. MSI loves to boast their boards on paper and break them on the bench table up until lately. Very pleased with them. Plus, a great review, Kempez
I take it I'm the only one who LIKES the boards looks & color scheme? Maybe because I'm used to my P35 Neo2-Fr's and it's the same scheme.
Originally Posted by name='Rastalovich'
Great review.
I`m still feeling these 780 boards are `good` without being great. Some excel with something in 1 area and lose something in another, all very minimally. But appear solid. Like to see an SLI vS CF of the `best` of the 780i`s vS the `best` 35/38. From a gaming pov, be pretty interesting. All the same stuff cept the gfxcards, that perhaps are close as single cards maybe. With the prices tho, I don`t think u can turn ur nose up at them. |
I was refering to this...
CF vs SLI would be interesting although I don't have a lot of faith in either solution due to ongoing software and hardware quality/issues
http://img85.imageshack.us/img85/3766/testmc6.jpg
Specs:
MSI P7N SLI PLAT
Intel Q6600
8800GT
PSU
2x2GB 800
Problem is , it only detects 2cores... bios doesnt even have any option..... Any users got this problem?
Freshly installed XP and Vista.... both same
I think it this board is compatible but wont work with Q6600.....
Specs:
MSI P7N SLI PLAT
Intel Q6600
8800GT
PSU
2x2GB 800
Hey Kempez, when testing a quad, how much vDroop did you encounter?
From what I recall it droops about 0.02v, but that's from memory
Dang that's not bad, at ALL.
Hi guys a have a few question about the board where you able to achieve that oce with 4gb of ram? does the thermalright ultra extreme fit on the board?
and does it support tri sli?
No it was 2GB of RAM but that wouldn't matter as you can unlink it
I would expect the Thermalright to fit, yes
I do not believe it supports Tri SLI
Thank you for the response Kempez and nice review seems like a great board I
might get one with two 8800gt the second slot not being 16x wont hamper performance too much right? and was the oce you achieved stable for gaming?
I'm not too sure about the second x16 slot as the 8 series have got to the point where I think they saturate 8x bandwidth
The OC was stable for 1 hour Prime95 on all four cores
Anyone tried to OC this with a 1333MHz FSB CPU yet? I'll be trying it with an E8400 next week.
Just ordered the board and a q6600 and will receive today. BUT there is a problem of which many have encountered. One is the fact that many people with q6600 can only see two cores with this board, will a bio's update fix that? Also I have read that this board has a mean "FSB HOLE" anything around 1333Mhz to 1400Mhz from what I know of, which will keep me from getting my overclock I want to achieve (3.6Ghz maybe a little higher if doable)
. If anyone has encountered this hole or have had any q6600 problem's with this board please inform me because right now I am thinking of an RMA and I haven't even recieved it yet. After I get it and test it anything I learn I will try to inform any who are wandering.
By the way nice review, did each core check out at 3.8Ghz in CPU-z, because many ppl haven't been able to pass 1333MHz FSB. If so, how did you get it to work?
Thank You
. If anyone has encountered this hole or have had any q6600 problem's with this board please inform me because right now I am thinking of an RMA and I haven't even recieved it yet. After I get it and test it anything I learn I will try to inform any who are wandering.By the way nice review, did each core check out at 3.8Ghz in CPU-z, because many ppl haven't been able to pass 1333MHz FSB. If so, how did you get it to work?
Thank You
Yep I got all Core's there in CPU-Z
Didn't find an FSB hole either.
I did tend to use the VTT voltage a fair bit as Quad's thrive on those volts
Didn't find an FSB hole either.I did tend to use the VTT voltage a fair bit as Quad's thrive on those volts
thank you, got my board it was DOA I believe, no post, checked all hardware and it all checks out (played with the q6600 for a while on a MSI P35 board 3.6ghz overclock was nice 5310 on 3dmark06 cpu score).
All I could go by was that the board would display a red led on the bottom and blue led right above it. Don't know what that means but no video display on the screen, video card checked out though. Any ideas
Sorry, cant help you there
and does it support tri sli? |
(seems to be a very common problem on every manufacturers boards now days, not exactly a tough QC problem so go figure). On that note the heatsink seems pretty cheap so I may look at replacing the array with some other sinks. Couple of the Thermalright HR-05 SLI's on the north and south bridges, they're HR-09 type 3 on the mosfets, and a Thermaltake Extreme Spirit II on the 200 chip between the PCI-E's for some color
But only if I can get it to clock better than my xfx 680i LT (I sure hope it does because right now the best I can get is 3.3g stable with a G0 stepped chip 1.25vid).will let everyone know my results in a few days when I have time to play with it.
How did you manage to get the FSB to 470?
I have tried OCing my E8400, but the best I've managed is 3.6GHz stable using:
400MHz FSB (1600MHz in BIOS)
9x Multiplier
CPU @ 1.24V (+0.0350V in BIOS)
NB @ 1.32V (+ 2 steps in BIOS)
I'm getting CPU temp of 23-25 idle, 33 under load. Cores are between 33-39 under load.
I managed to raise FSB to 1667, giving 3.75GHz, which booted into Windows, but kept locking up fairly regularly. Temps were one degree higher.
Any advice? I have almost no experience overclocking, sorry - but I've heard the processor is capable of 4.4GHz+ :-)
9x Multiplier
Try using the VTT voltage, upping that a bit helps
Can't remember the whole BIOS
Yeah, I wondered about that. It's default at the minute (1.2 I think?). What do you recommend I up it by, one or two steps in the BIOS? Or to a specific amount, say +0.1V etc?
Thanks for the quick reply (and fantastic review, big factor in me choosing the board)!
Keep it on topic guys, those posts have been moved to a new thread in the overclocking section
Kempez could u tell me ur bios settings to get past 1333fsb, because my windows wont boot over that number, so i think maybe something needs being disabled or enabled in bios (p7n platinum q6600)
hi guys i have a question for u....
i bought this mobo and i wanted to buy an Cooler Master Sphere cooler ...but i do not know if will fit beacause of the zalman cooler onto the chipset ....
should i'll try another cooler like Cooler Master GeminII s?or the Sphere
i like a lot the Sphere but i do not know if will fit...thx
ps:sorry for my bad english
config:
case:antec nine hundred
power_s:780w sli ready
mobo:msi P7N SLI Platinum
cpu:intel q9450
mem:Mushkin quad pack 4x 2GB
gpu:leadtek 9800gtx+
hdd:2x500 seagate sata2
config:
cpu:intel q9450
Link
