MSI P7N SLI Platinum 750i based motherboard
IO and BIOS
Search Reviews
Input/Ouput Panel
IO on the P7N SLI Platinum is a very well specced and nicely balanced affair. We have:
* 1 x PS/2 Keyboard port
* 1 x PS/2 Mouse port
* 1 x Firewire port
* 1 x Optical digital in
* 2 x e-SATA ports
* CMOS reset button
* 4 x USB 2.0 ports
* Gigabit LAN port
* Analogue 7.1 Sound ports
io panel
This is a decent selection of oputputs for this level of board and you should be fine connecting most of the things you need to.
BIOS
MSI have gone with an American Megatrends Incorporated BIOS for the P7N SLI Platinum. This has a slightly different feel than the Phoenix Award BIOS we most commonly see on boards but it's not necessarily a bad thing.
main menu
All of the overclocking features are in the "Cell" Menu. Here we can see the following adjustments:
OptionAvailable Range
CPU Multiplier
x6 - x50
FSB Frequency
400-2500 (keyable 1mhz steps, quad pumped)
PCI-E Frequency
100-150mhz (1mhz steps)
RAM Frequency400-1400mhz (Keyable - 1mhz steps)
cell menu  cell menu
cell menu
cell menu
Aside from the top end of the RAM frequency being slightly low for an enthusiasts board, the adjustments are all of the one's you'll normally see here. The RAM timings are pretty solid allowing (in my opinion) just the right amount of options and not getting too detailed.
The BIOS isn't as extensive as the one you'll see on, say a DFI Lanparty LT X38 T2R but it does it's job as you will see later on in the review.
CPU Voltage
STOCK 1.3v-1.6875v (0.0500v steps)
CPU FSB VTT
1.2v-1.7v (0.1v steps)
Memory Voltage1.8v-3.1v (0.25v steps)
NorthBridge Voltage1.3v-1.75v
SouthBridge Core Voltage
1.5v-1.95v
bios voltages  bios shots
BIOS shots  BIOS shots voltage
BIOS shots voltage
The range of voltage adjustments is again smaller than on other boards, but the amount you can adjust the voltages is more than adequate.
Overall, the BIOS on the MSI P7N SLI Platinum is excellent and does what you need for overclocking, just don't expect pages upon pages of options.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
18-02-2008, 06:21:30
FarFarAway
Check out MSI's P7N, will it live up to expectations?
Link
18-02-2008, 06:28:41
Jim
Nice review mate and a decent board to boot!
Now all that MSI need to do is remove Zippy, Bungle and George from the "board colour scheme" team, and they'll have a perfect board
Seriously tho...surprisingly decent OC results from an Nvidia chipset.
18-02-2008, 06:40:32
Luigi
Yes, i mean thats better than the 780i boards which are a 'better' chipset..
18-02-2008, 08:58:56
Bungral
That is some serious overclocking results.. I mean it beat the others by quite a chunk! Also the 0% CPU utilization was quite impressive.
18-02-2008, 09:16:08
Rastalovich
Great review.
I`m still feeling these 780 boards are `good` without being great.
Some excel with something in 1 area and lose something in another, all very minimally. But appear solid.
Like to see an SLI vS CF of the `best` of the 780i`s vS the `best` 35/38. From a gaming pov, be pretty interesting. All the same stuff cept the gfxcards, that perhaps are close as single cards maybe.
With the prices tho, I don`t think u can turn ur nose up at them.
18-02-2008, 09:19:01
ionicle
if they combined that boards performance and features with the DFi black and green colour scheme, you'd be onto a winner
performs sweet though
18-02-2008, 09:36:39
Ham
Dam good looking (oc wise...) board tbh. May invest in one for the bench rig.
18-02-2008, 09:39:54
Mullet
Very nice review Matt....bargain!!
18-02-2008, 09:43:05
Luigi
Absolutely...
Why not test 35/38 against 780i with the same gfx card (single) to keep things simple... i think i know which ill put my money on.
18-02-2008, 09:57:59
Ham
Originally Posted by name='teknokid'
Absolutely...
You mean exactly like what he's done on page 9?
Edit: And 10...
18-02-2008, 10:08:25
FarFarAway
Aye that's what I did
It's a great board with awesome overclocking, muchas surprising!
18-02-2008, 11:17:34
NickS
Wow, very surprising indeed. MSI loves to boast their boards on paper and break them on the bench table up until lately. Very pleased with them. Plus, a great review, Kempez
I take it I'm the only one who LIKES the boards looks & color scheme? Maybe because I'm used to my P35 Neo2-Fr's and it's the same scheme.
18-02-2008, 11:39:17
Luigi
Originally Posted by name='Rastalovich'
Great review.
I was refering to this...
18-02-2008, 11:54:59
FarFarAway
Yep I was impressed, especially at that cracking price!
Pretty much lol
I would love to have time to set up a Crossfire VS SLI review but I am snowed in with more reviews than time to do them at the moment....and more pretty interesting and exciting ones waiting to be done.
CF vs SLI would be interesting although I don't have a lot of faith in either solution due to ongoing software and hardware quality/issues
25-02-2008, 15:45:07
Linson
http://img85.imageshack.us/img85/3766/testmc6.jpg
Specs:
MSI P7N SLI PLAT
Intel Q6600
8800GT
PSU
2x2GB 800
Problem is , it only detects 2cores... bios doesnt even have any option..... Any users got this problem?
Freshly installed XP and Vista.... both same
I think it this board is compatible but wont work with Q6600.....
25-02-2008, 19:44:19
NickS
Hey Kempez, when testing a quad, how much vDroop did you encounter?
26-02-2008, 04:37:22
FarFarAway
From what I recall it droops about 0.02v, but that's from memory
27-02-2008, 08:57:27
NickS
Dang that's not bad, at ALL.
28-02-2008, 15:48:46
mehdi19
Hi guys a have a few question about the board where you able to achieve that oce with 4gb of ram? does the thermalright ultra extreme fit on the board?
and does it support tri sli?
28-02-2008, 16:22:11
FarFarAway
No it was 2GB of RAM but that wouldn't matter as you can unlink it
I would expect the Thermalright to fit, yes
I do not believe it supports Tri SLI
28-02-2008, 17:19:12
mehdi19
Thank you for the response Kempez and nice review seems like a great board I
might get one with two 8800gt the second slot not being 16x wont hamper performance too much right? and was the oce you achieved stable for gaming?
28-02-2008, 17:56:11
FarFarAway
I'm not too sure about the second x16 slot as the 8 series have got to the point where I think they saturate 8x bandwidth
The OC was stable for 1 hour Prime95 on all four cores
06-03-2008, 20:49:15
Nebulous
Anyone tried to OC this with a 1333MHz FSB CPU yet? I'll be trying it with an E8400 next week.
07-03-2008, 09:07:40
Darksector88
Just ordered the board and a q6600 and will receive today. BUT there is a problem of which many have encountered. One is the fact that many people with q6600 can only see two cores with this board, will a bio's update fix that? Also I have read that this board has a mean "FSB HOLE" anything around 1333Mhz to 1400Mhz from what I know of, which will keep me from getting my overclock I want to achieve (3.6Ghz maybe a little higher if doable) . If anyone has encountered this hole or have had any q6600 problem's with this board please inform me because right now I am thinking of an RMA and I haven't even recieved it yet. After I get it and test it anything I learn I will try to inform any who are wandering.
By the way nice review, did each core check out at 3.8Ghz in CPU-z, because many ppl haven't been able to pass 1333MHz FSB. If so, how did you get it to work?
Thank You
07-03-2008, 13:23:02
FarFarAway
Yep I got all Core's there in CPU-Z Didn't find an FSB hole either.
I did tend to use the VTT voltage a fair bit as Quad's thrive on those volts
08-03-2008, 13:28:32
Darksector88
thank you, got my board it was DOA I believe, no post, checked all hardware and it all checks out (played with the q6600 for a while on a MSI P35 board 3.6ghz overclock was nice 5310 on 3dmark06 cpu score).
All I could go by was that the board would display a red led on the bottom and blue led right above it. Don't know what that means but no video display on the screen, video card checked out though. Any ideas
08-03-2008, 13:30:15
Luigi
Sorry, cant help you there
12-03-2008, 19:53:55
Icerider
Just got the board in from the egg. You will have to VERY carefully bend that curving top heatpipe about 1 or 2 cm toward the first pci slot to fit, it's not even enough that you notice but it does work with my TRUE with about 1 cm clearance after the bend. I do advise you pull the heatsink/heatpipe array off and replace the dope with some AC Ceramic. My southbridge wasn't making ANY contact (seems to be a very common problem on every manufacturers boards now days, not exactly a tough QC problem so go figure). On that note the heatsink seems pretty cheap so I may look at replacing the array with some other sinks. Couple of the Thermalright HR-05 SLI's on the north and south bridges, they're HR-09 type 3 on the mosfets, and a Thermaltake Extreme Spirit II on the 200 chip between the PCI-E's for some color But only if I can get it to clock better than my xfx 680i LT (I sure hope it does because right now the best I can get is 3.3g stable with a G0 stepped chip 1.25vid).
will let everyone know my results in a few days when I have time to play with it.
25-03-2008, 17:22:44
Rezzie
How did you manage to get the FSB to 470?
I have tried OCing my E8400, but the best I've managed is 3.6GHz stable using:
400MHz FSB (1600MHz in BIOS)
9x Multiplier
CPU @ 1.24V (+0.0350V in BIOS)
NB @ 1.32V (+ 2 steps in BIOS)
I'm getting CPU temp of 23-25 idle, 33 under load. Cores are between 33-39 under load.
I managed to raise FSB to 1667, giving 3.75GHz, which booted into Windows, but kept locking up fairly regularly. Temps were one degree higher.
Any advice? I have almost no experience overclocking, sorry - but I've heard the processor is capable of 4.4GHz+ :-)
25-03-2008, 17:41:15
FarFarAway
Try using the VTT voltage, upping that a bit helps
Can't remember the whole BIOS
25-03-2008, 17:45:43
Rezzie
Yeah, I wondered about that. It's default at the minute (1.2 I think?). What do you recommend I up it by, one or two steps in the BIOS? Or to a specific amount, say +0.1V etc?
Thanks for the quick reply (and fantastic review, big factor in me choosing the board)!
26-03-2008, 07:48:45
FarFarAway
Keep it on topic guys, those posts have been moved to a new thread in the overclocking section
26-03-2008, 07:52:34
mbinzu
Kempez could u tell me ur bios settings to get past 1333fsb, because my windows wont boot over that number, so i think maybe something needs being disabled or enabled in bios (p7n platinum q6600)
07-09-2008, 17:33:02
alexbebe
hi guys i have a question for u....
i bought this mobo and i wanted to buy an Cooler Master Sphere cooler ...but i do not know if will fit beacause of the zalman cooler onto the chipset ....
should i'll try another cooler like Cooler Master GeminII s?or the Sphere
i like a lot the Sphere but i do not know if will fit...thx
ps:sorry for my bad english
config:
case:antec nine hundred
power_s:780w sli ready
mobo:msi P7N SLI Platinum
cpu:intel q9450
mem:Mushkin quad pack 4x 2GB
gpu:leadtek 9800gtx+
hdd:2x500 seagate sata2
