MSI P55-GD80 Motherboard
Search Reviews
When I first cast eyes on the MSI P55-GD80 I was astounded by the very attractive design. So much so I found it hard to believe it had arrived from the MSI stable. The design bods have worked wonders with the aesthetics of the board which is easily one of the best looking pieces of hardware on the market today. The matching blue heatsinks and peripheral slots are very fetching and with no odd purple or yellow (or indeed pink and green!) slots anywhere on the mainboard, I congratulate MSI on a job well done.
The packaging too, while not on a par with the best out there is certainly very good. I would like to have seen black/blue cabling included instead of the bog standard MSI red but I guess they have surplus stock to shift from the parts bin. What I was impressed with was the amount of included accessories.
The motherboard layout is nigh on perfect with no issues encountered at anytime during the setup. The amount of ports and connectivity is such that even if you do not wish to use this motherboard as the basis for an overclocking monster, you will be happy with the amount of expandability it offers.
The good news does not stop there though. The board has some very good overclocking ability. Achieving 4.5Ghz is no mean feat and while I will confess, this is the only board I have tried this CPU with, the overclocking seemed to be very predictable. The board gives you those little hints when it is starting to run out of steam and this makes overclocking so much more fun and much less frustrating. The recovery from overclocking was such that it only added to the pleasure of using such a well refined motherboard. Even if you are not well versed in the dark art of overclocking, MSI have made the process so much easier thanks to the OC Genie and Base clock +/- buttons on board.
My only criticism of the motherboard is the OC Genie. While it is fantastic in automatically overclocking the components, it prevents some of the more detailed options of the BIOS being available, mainly the memory divider which caused issues as it would not allow our test kit to be run at it's stock 2000MHz rather relying on the SPD settings of the memory kit. However, a quick email to MSI support confirmed that they are already aware of the issue and that the technical boffins are busy working on a new BIOS release to rectify the problem, such is the excellent motherboard support from MSI.
The board has started to appear around the £180 mark which may appear a little excessive but when you consider mid range X58 motherboards are above this price point, £178.24 (available from Novatech) is not such a bad price at all for a flagship product. I would have liked it to be a touch closer to £150 which is much more reasonable but as with most PC components, prices just seem to creep up and up and MSI cannot be held solely responsible for that.
MSI have long been known for making good motherboards but have rarely made that extra step by making an amazing motherboard. This time I think I am justified into saying that they have taken that extra step and done just that. What MSI have produced is a motherboard capable of exceeding any preconceptions and indeed exceeding anyones expectations. I certainly didn't expect to see such a well rounded product as with most products, it takes a while for the chipset to mature before we start to see some of the best motherboards on the market. However, I feel MSI have shot straight out of the blocks and are racing toward the finish line before other manufacturers have even tied their laces.
Excellent work MSI!
The Good
- Baseclock buttons
- OC Genie (Auto overclock)
- DrMOS
- Aesthetics
- Accessories
- Overclocking potential
- On board temp and phase readouts
The Mediocre
- OC Genie restrictions (memory multi)
- No colour coded accessories
- Packaging is better but dated compared to other high end products
The Bad
- Nothing
Thanks to MSI for providing the MSI P55-GD80 for todays review. Discuss in our forums
21-09-2009, 01:49:24
Jim
"P55 Motherboards are starting to appear and for our first review of a retail board we have MSI's flagship motherboard, the extreme performance P55-GD80. See how it performs inside" - by w3bbo
http://www.overclock3d.net/gfx/artic...141914946s.jpg
21-09-2009, 02:35:28
PeterStoba
I'll say it before, and I'll say it again. This is one of the best looking boards I've seen!
That's a nice clock from it too.
21-09-2009, 05:37:05
Rastalovich
It's a good mobo with a good review.
£178 is something for the 'con' section for me tbh.
For some reason, since i7, it appears the standard is to have the level of mobos at around £30-50 more expensive than they probably should be.
This could however be the result of 775 mobos just not going away. And if they're at "reasonable" prices, it tends to suggest the manufacturers feel they can "get away with charging" that much more as it's "new technology".
I personally think this is bllx however when the jump between the 2 isn't great.
21-09-2009, 07:26:20
tonpal
I think Rastalovich has a good point. For £180 you can pick up a mid range X58 board that might not have as many bells and whistles as the P55-GD80 but does have the advantage of 32 PCI-E connectors. Granted for it to make a difference you would need to be running Crosfire/SLI with a 24 inch monitor but the sort of people who this board targets it is quite reasonable to expect they may be running this sort of hardware.
21-09-2009, 12:09:22
w3bbo
I agreee to a certain extent about the price and mentioned in the review that the board should be priced around £20-30 cheaper. However, this is new technology, albeit slightly inferior in certain sectors to older X58 chipsets and because of that the price is inflated accordingly. I couldn't really put the price as a 'con' as it is pretty much inline with what other manufacturers are charging for a flagship P55 motherboard.
The jump between the two technologies is indeed nothing to shout from the rooftops about but the performance difference is there. How much you value that extra performance will depend alot on how much of an investment you see a PC as.
As always guys I appreciate constructive criticism and feedback, these are afterall - reviews for YOU!
21-09-2009, 12:25:19
VonBlade
Only really the same thing I always moan about W3bbo. Solitary performance figures are nice, but a comparison with a same speed X58 i7 system would be lovely.
Would triple-channel make that much difference with it's superior bandwidth?
Given the tiny price difference between this mobo and a 860 and a P6T and a 920D0 which is the better buy?
All those kind of things. Especially important when it's a new generation of hardware and so most people would be buying the bulk of a new system.
Even, because it's equal in dual-channelness to the AMD Phenom IIs, a AMD comparison.
I'm just a comparison whore. I love to know what the best system would be for the same money. Most online comparisons are strange things like a stock i5 vs a i7 975E vs a X2 250. Let's equal the clocks, equal the RAM and run the battery of tests. That way it's clear which is the best for general use, gaming use, productivity etc.
But, as per usual, a fantastic review. Truly droolworthy looking mobo. About the only mobo that comes close in looks is the Asus Maximus III.
22-09-2009, 05:31:38
Rastalovich
Memory I've always considered as much of a muchness between ddr2/ddr3 triple and dual.
Benchmarking u get the obvious champions. And if ur using the types of creative apps constantly in the day, like for work or something, u'll notice the difference I'd imagine.
Last mobo I got for gaming, which in fairness I had the means to get whatever 775 that was out there, I went ddr2.
