MSI 870A Fuzion Power Edition EXCLUSIVE Review
CPU Performance
Search Reviews
CPU Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
CPU Arithmetic
The CPU arithmetic test ascertains the processor's capabilities in terms of numerical operations. Two subtests named Dhrystone and Whetstone are carried out respectively. This is not a measure of latency and thus higher is better.
We commence on a good note, identifying all platforms performing nigh on identically. The gains exhibited by the overclocked 1090T are in line with what would be expected of a 4.0GHz AMD K10.
CPU Multimedia
The CPU Multimedia Test focuses on CPU based operations that may occur during multimedia based tasks. The magnitude of the score depends on the processor's ability to handle Integer, Float and Double data types
A similar story unfolds with the CPU Multimedia test. No surprises here!
CPU Queen
CPU Queen is based on branch prediction and the misprediction penalties that are involved.
The delights of branch prediction have nothing on these systems. All of these scores are higher than average. Meanwhile the 870A Power Edition hangs on tightly to the other two motherboards, despite being based on a chipset that's one generation senior.
CPU Photoworxx
PhotoWorxx as the name may suggest tests processors by means of invoking functions that are common to Photo Manipulation including Fill, Flip, Crop, Rotate, Difference and Colour to B&W conversion.
Strangely, the Photoworxx benchmark revealed a slightly inferior stock 3.20GHz score for the MSI. This is more than likely within the error margin of this particular benchmark and we wouldn't particularly expect the board to be the cause.
CPU ZLib
This is an integer based benchmark that will test the CPU and Memory by means of the CPU ZLib compression library.
Next we'll be taking a look at rendering based and system wide benchmarks
«Prev 1 2 3 4 5 6 7 8 Next»
24-09-2010, 06:12:43
tinytomlogan
Any ideas what makes it so special? Read on...
Continue Reading
24-09-2010, 07:28:41
silenthill
MSI have really got a winner with this M/B, for that price I'm thinking of buying one and building a AMD system to play around with.
24-09-2010, 08:50:09
SnW
And for how long did that OC genie work ?
great looking board....
24-09-2010, 08:57:06
El Gappo
When he pressed the OC genie button it automatically opened up an msn chat with me
Cheers for the heads up tom, board looks mental.
24-09-2010, 09:03:52
lemel
"The 870A Fuzion is akin to engines such as VW Group's 1.4TSI Petrol. Upon face value, it is a bog standard 4 cylinder engine with not a lot going for it. However, with its Turbo Charger + Super Charger combo setup, it pushes out peak performance (~175bhp) similar to many 2.0 engines." -That is the engine i have in my Seat Leon!! Love it! If this board is the same...it really rules! ;-)
24-09-2010, 09:03:56
SnW
Aaaa it opened up the fridge here i was wondering when he was going to close it again
I have the MSI P55-GD65 and the OC genie button works like Poo
24-09-2010, 09:39:00
AlienALX
It's days like this that remind me what utter rip off merchants Intel are.
Fantastic as ever guys, and a special thanks to Mul for absolutely kicking the s**t out of it.
Fabulous stuff.
24-09-2010, 11:57:16
SiN
Dude, I didn't know you were on here! It's D3FiN3 SiN/firestormcomputers from OCN .
24-09-2010, 12:18:54
tinytomlogan
All the cool kids are here
24-09-2010, 12:21:43
nepas
Annnnnd another one comes over
24-09-2010, 13:04:45
AMDFTW
they are cool now they are hear
24-09-2010, 14:29:47
Todd
Lovable beast!
24-09-2010, 14:35:58
SnW
Aaaa i love you , you just called me a "kid" i feel 10years younger now
24-09-2010, 14:59:13
Delusion77
I guess this board really surprised you guys
25-09-2010, 00:01:57
SiN
Mr. El Gappo is an AMD legend.
And yes, I am now a cool kid .
25-09-2010, 08:31:53
murphy7801
This going to be great for cheap builds
25-09-2010, 08:42:18
SnW
Well not really.. its nice you can use NvidiA/Ati in it
25-09-2010, 10:53:58
sunjoo
for a board that has the lucid hydra chip its cheap
28-09-2010, 17:44:19
El Gappo
LOL Hey Sin!
TTl your cpu-z sig is looking much healthier now
29-09-2010, 11:53:30
Zeals
What's the best heat sink for this if i want to fill all memory slots, the RAM is 35mm tall.
Also can I run 2x460 SLI on this motherboard?
29-09-2010, 11:59:32
AlienALX
Originally Posted by Mul View Post
2 x PCIe 2.0 x16 (16x/16x Dual CrossfireX, SLI, ATi + nVidia)
2 x PCIe 1x
1 x PCI
The Noctua NH14 will clear regular ram. It only has issues with Dominator ram.
29-09-2010, 12:07:54
tinytomlogan
Incorrect it only has issues with oversized ram. If the taller heatsink like on the domGT's can be removed your fine.
29-09-2010, 12:11:19
AlienALX
Ah OK. Well I was right about the 'regular' ram bit.
I wasn't aware that loads of companies made oversized tbh. I know Gskill do that Ripjaw stuff.
30-09-2010, 02:35:56
Zeals
Forgive me if this is a stupid question, but if i get a ATI and Nvidia graphics card, does the Lucid chip allow me to use Phyx?
30-09-2010, 03:48:31
AlienALX
Yes. Infact, you can use an Nvidia card for Physx with *any* motherboard and any ATI card.
You do need to run a Physx mod/hack (mod is a nicer word) but yes, you can.
You might need to run that mod for this board, I don't know. Usually Nvidia disables Physx when it sees an ATI card present. And the way it does this is the driver looks at the Device manager and then at the DEV_ID for the graphics cards. If it sees the ATI DEV number (1002 as the vendor code) then it simply disables the Physx function. However, this is easy to get around using GenL Physx Mod 1.04ff.
Google is your friend
30-09-2010, 03:57:43
tinytomlogan
With Lucid set up right then yes you will be able to go into the Nvid driver panel and set it to PhysX
