Intel Core i7 930 Review
Overclock and Undervolt
Search Reviews
Over and Undervolting
"Huh?" we can hear you crying. Undervolting? We will come to that in a moment. Firstly the reason you're all here.
Overclocking
As we said in the introduction the 930 is more of an evolution of the 920 that the revolutionary 32nm low-end processor we're waiting for. Consider it more like an Stepping 920. Firstly the processor at stock.
As previously mentioned we have an extra multiplier which should enable us to hit a good overclock. One of the main benefits of this latest evolution of the mainstream i7 is that Intel have had a while to really iron all those bugs out and produce a very consistent chip. Hopefully this will mean that you'll all get these results and no longer will we be seeking out that elusive batch that clocked so well.
Our results saw 4.2GHz at 1.34v. Absolutely amazing numbers and, as you can see from the screenshot below, totally rock solid. 920 owners would dream of 4.2GHz at 1.34v. This got us to thinking....
Undervolting
So often at OC3D we push things in one direction and try and get all we can out of it. Understandable considering we're Overclock3D.net after all. However the 930 performs so well at reasonable voltages when overclocked, and the default voltage is so low, how low could we get the core voltage and still maintain stock stability?
Starting at 1.05 volts on the core we see it's still completely happy to run at stock.
Dropping down to 1.0v we have the same result. Except this time our jaw is also dropping along with the voltage. Please pay close attention to the CPU temperatures.
Finally 0.95v and still the 930 happily runs at 2.8GHz. Words don't do this justice. Sub 1v for a quad-core hyper-threading 2.8GHz chip under load and still stable is insanity. For the majority of us we all like "moar powerrrrr" but if your use is such, say for example an office environment or an part of an HTPC setup, then so much horsepower but with minimal power draw and a vastly lower thermal profile is Manna from Heaven. Who needs mobile CPUs anyway?
The perfect balance?
Of course we couldn't leave it there. What if we could meet in the middle and find the balance between the i7 930s ability to barely need any core volts, but also overclock easily?
It took a lot of testing but we finally found the sweet spot. 1.112v on the core and 3.8GHz. I think you'll agree that this is outstanding.
Intel Core i7 930 Review   Intel Core i7 930   Review
Does this incredible stability also come with increased performance in testing?
«Prev 1 2 3 4 5 6 7 Next»
16-04-2010, 05:39:01
tinytomlogan
With intel recently releasing the i7 930 we thought it was time to see if it is up to the standards that the 920 had previously set.
Continue Reading
16-04-2010, 09:41:04
alexhull24
On paper, totally uninteresting, but in practice, amazing!
Why is it happier with such lower voltages if the process is the same size? I don't know a lot about the intricacies of CPU production, but I'm interested to know what was actually changed, as going by the spec sheet doesn't yield much information.
A CPU like this should be good for many years, despite intel inevitably changing socket design in the not too distant future.
16-04-2010, 10:43:47
Runebeard
That's just staggering! So glad I'm getting one of these! Maybe I'll see if I can match your "sweet spot"...
16-04-2010, 11:56:24
a8875624
Will the 32nm chips be out this summer then? I imagine they will be able to break 4GHz at lower voltages?
The 3.8GHz@ 1.11v is ridiculous, but in terms of speed alone, it does not seem to offer that much advantage over the slightly cheaper 920 (£40 on scan.co.uk)
17-04-2010, 08:39:05
Steve-O-
WOW! 3.8 at 1.11v... It was a good thing I wasn't drinking anything. And with that low of voltage temps must be amazing! (I skipped to the conclusion Sorry)
17-04-2010, 14:39:53
ppuff
They charge more for the 930 over there? By me its the same price as 920. $199 U.S.
17-04-2010, 17:00:21
a8875624
This is why I hate living here!!!!! The 920 hasn't even dropped to anywhere near that!! - its £180-190
17-04-2010, 17:38:50
ppuff
If I was to get online it would be $280 for either one, just so happens a brick and mortar near me has insane prices on Intel CPU's.
19-04-2010, 15:49:00
mudkip
Lol @
''Our results saw 4.2GHz at 1.34v. Absolutely amazing numbers and, as you can see from the screenshot below, totally rock solid. 920 owners would dream of 4.2GHz at 1.34v. ''
''It took a lot of testing but we finally found the sweet spot. 1.112v on the core and 3.8GHz. I think you'll agree that this is outstanding.''
This is my i7 920 D0 4,2Ghz @ 1.264v :
http://i44.tinypic.com/348kphs.jpg
3,8Ghz @ 1.10v
http://i31.tinypic.com/xbl740.png
LinX + OCCT 8+ hours rock solid.
I think 930 owners would dream of this
19-04-2010, 17:40:37
tinytomlogan
Cingrats dude, we were talking about the majority of CPU's not the cpus we know that run better in certain baches
16-05-2010, 20:52:54
Shirosky102
I wish u guys have a toturial oc'ing i7 930 4.2ghz. For stable 24/7 gaming use .
16-05-2010, 21:32:45
I Hunta x
Not every chip will get 4.2ghz and the settings for each chip with be different for prety much any speed, with a quick google you should be able to find a guide to overclocking i7's if your not sure on what to do.
19-05-2010, 04:50:20
hadesan
Thanks for the information (detailed CPUZ shots) and comparison for the 920 i7s vs the 930
23-06-2010, 19:17:45
xxxxxl
I tried undervolting and i got 0.92v at stock cpu speeds.
As i'm new here, i can't post the image up.
@Mudkip did you try undervolting too? since your 920 is of a good batch, i foresee a super low voltage.
23-06-2010, 19:39:13
F-alienware
Use photobucket. Saves on server space here too
24-06-2010, 04:52:13
xxxxxl
24-06-2010, 05:14:52
Runebeard
Nice xxxxxl! You must be getting some really low temps to go along with that!
24-06-2010, 05:17:59
xxxxxl
I'm getting average 45 degrees(and its quite stable) after setting fan speed to super silent.
At full fan speed, lowest i noticed was 39.(I didn't keep at full fan speed for very long as there was no need to).
24-06-2010, 12:07:40
xxxxxl
Just want to share this with everybody.
http://img534.imageshack.us/img534/6...0624234626.png
Notice the 930 power.
A Core i7-720QM at twice the speed. If only i could put this onto a laptop!
24-06-2010, 19:11:49
Diablo
Nice voltage, the 930 seems to be a lot more frugal. I hate to think how much power my 920 gulps down at 1.325V. What heatsink are you using?
24-06-2010, 19:39:29
xxxxxl
Hyper 212+
13-07-2010, 14:41:23
Bob Sand
Hi,
I'm v. impressed with the undervolting and the results you achieved. Is it possible to share all the settings you used?
I have a new i7 930 and I'm just starting to tinker. I would like a cool running and v.stable 3.8 as a max target. Your work might help me speed up my process and allow me to do it within safer parameters.
Thanks in advance.
Bob
13-07-2010, 15:27:46
tinytomlogan
You wont be able to under volt and still get an overclock dude. Its one way or the other sadly. Another thing you need to realise is cpu's and motherboards can all act very differently so settings for one may not work for another.
13-07-2010, 17:09:29
Bob Sand
"It took a lot of testing but we finally found the sweet spot. 1.112v on the core and 3.8GHz. I think you'll agree that this is outstanding."
Overclocking is basically a method of finding the optimum balance to achieve stability for a desired performance level for your particular chip and setup. We are dealing with ranges of multiple settings (and as a result too many permutations if you include the hardware variations!) and I want to get in the right range of settings to save my system unnecessary wear. Using the lowest voltage to achieve solid stability at 3.8 is my goal.
I was hoping to get an answer from the author to find out how he reached that low voltage and high performance....
13-07-2010, 17:27:19
tinytomlogan
It was me who tested that CPU fella.
13-07-2010, 18:14:33
Bob Sand
Are the relevant settings available for sharing?
13-07-2010, 18:17:48
Diablo
TTL is saying that it varies from chip to chip and mobo to mobo.
13-07-2010, 18:26:44
tinytomlogan
You really need to read some guides and work out what YOUR chip can do fella, its simple but you just have to put the time in.
This thread is for overclocking, you can do everything but the volts though dude. All the info is on the forums for you to try. If you get stuck start a thread with what you need help with.
http://forum.overclock3d.net/showthread.php?33255-Noob-Overclocking-i7-930-with-P6T-Deluxe-V2-and-Noctua-NH-D14
13-07-2010, 18:48:56
Bob Sand
Every moron knows that. Thanks anyway.
I asked a simple question and he can say if he has the data or not. It is up to me what I choose to do with the data if anything. He can just answer the question.
I was not looking for more internet advice on guides to overclocking. I can Google with the best of them if I need something. I was taken with the performance he alluded to in his article and wanted to read all the details if they were available. The answer I guess is NO.
13-07-2010, 18:57:17
tinytomlogan
It is no as the testing was done a long time ago and I did not keep details that specific, if what you require is not in the review I do not have a record now.
However you do not need them as its VERY simple to work on your own kit to find out what yours is possible of.
Just set your cpu to its VID voltage and then overclock as normal without voltage increases. Its very simple if you actually try it.
13-07-2010, 19:06:14
Bob Sand
Thanks
13-07-2010, 22:43:16
xxxxxl
FYI, if you just want to do pure undervolting, other settings will be left on auto.
It is possible to do some overclocking while undervolting as the manufacturers normally set needlessly high voltages automatically.
Even while overclocking, most of the settings can be left as default.
You might want to disable the spectrum ones though.
14-07-2010, 03:56:41
Diablo
There is no need to be rude. If you know these things fair enough, but if you were expecting to be able to buy any chip and magic up these results then I was simply saying that your expectations may need tempering. If you don't want other people to help, don't put this information on a public thread. If it is on a forum, expect people trying to be helpful to answer.
14-07-2010, 04:42:34
tinytomlogan
AUTO is completely the wrong thing. The board will overvolt to try and compensate for the clock. You MUST set the voltages so they stay where you want, ie: the cpu's VID
15-07-2010, 13:33:53
Bob Sand
removed.
15-07-2010, 14:33:21
Runebeard
Whoa boy! There's no need to arch your back! You give the air of someone who clearly understands overclocking well, yet rather than experimenting what your chip can do, simply wanted to recreate the test results which were likely performed with different hardware from yours.
As Tom said it is very simple to see what your processor can do and requires no facetious comments concerning another member's post when they are simply trying to aid in the issue as all good members will.
You talk about being respectful yourself, yet the aggressiveness and rudeness of some of your reponses isn't really warranted and will only serve to embitter people towards your plight.
I suggest in future a little bit of patience should be utilised, as it is not always easy to understand what a person is asking first time around and can lead to subsequent confusion and in this case strife.
15-07-2010, 14:38:24
tinytomlogan
I removed the post and have PM'd. But I agree entirely, we are all a big family here and will help, but all the questions were already answered, just maybe not in the way he was expecting.
15-07-2010, 15:41:09
Diablo
In the interest of having a friendly forum, I'm hoping this can slide (I've read his post). I'm not in this to make enemies.
