Intel Core i5-2405S Review
Sandra and wPrime
SiSoft Sandra
Sandra has always been great at managing to separate the component being tested from the rest of the system, and so it proves once again as it puts the i5-2405S through its paces. Although in this case paces is implying a level of performance that just isn't there. Perhaps putting it through its walking frame is closer to the mark.
wPrime
Since we've been running wPrime tests we've often considered moving the 32M section of the test to a different graph because modern CPUs can do it so quickly it's tough to see the sliver of blue. The i5-2405S has no such problems, giving some of the (if not the) slowest times we've seen yet. 14 seconds to do the 32M test is quite slow, taking a minute and a half longer than a stock clocked 2500K is treacle-like.
«Prev 1 2 3 4 5 6 7 8 Next»
31-08-2011, 06:02:33
tinytomlogan
The latest in a long line of SandyBridge processors is the low power Core i5-2405S. We put it to the test.
Continue ReadingQuote
31-08-2011, 06:17:02
SieB
Seems pretty pointless to release this when it offers nothing but a lower TDP and who would buy this when you can get the 2500k for the same money which you can also overclock
Even if you don't go for the 2500k the non K 2500 is still cheaper and faster than the 2405S.Quote
31-08-2011, 07:24:06
sheroo
There's also the i5 2500T as well which is only 45W, but that's even more expensive than the 2500K.Quote
31-08-2011, 20:45:59
badtaylorx
ok amd here is you chance.....hell i'll even write the slogan for you......."AMD's 980 BE--FASTER THAN THE LATEST I5!!!!!!!!!"Quote
01-09-2011, 20:01:03
Speed
I think it is aimed more at system builders than anything, lower TDP means less cooling, cheaper parts etc. They would buy in bulk and OEM which would result in cheaper prices than the 2500. Which I'm guessing why PC World was mentioned in the conclusion. Not everyone overclocks but you make a valid point.Quote
02-09-2011, 05:04:08
Ya93sin
Would it not make a better HTPC solution?
But then the 2500K isn't a hot chip, and you get a fair bit more for the money. What would be interesting is if you can passively cool these things and get something truly silent.Quote
02-09-2011, 16:04:29
shyguy094
I think low end AMD is more suitable for HTPCs. I got an mATX board that would do the same thing as an i3-2100 or i5-2405S rig can do. The Athlons are like $40 right now. It would be interesting to see if it's possible to passively cool the i5-2405S. That would be an advantage that the 2400S has. 45W to 65W CPUs can probably be cooled w/o a fan. My cousin's Dell Dimension 1100 was (Celeron D @ 2.53GHz).Quote
02-09-2011, 17:25:04
Speed
The onboard GPU though is very efficent, so that is another advantage unless you are talking about AMD APUs. I'm running a small form factor system on a 2100 @ 2560x1600 with no issues. I've also just built a HTPC for someone around the same CPU, they are ideally suited for HTPC applications. Maybe not as cheap as the AMD solutions, but they generally perform better in my experience. Obviously if you don't need the extra HP, then the AMD solution is fine.Quote
02-09-2011, 19:18:45
shyguy094
You're right. AMD's APUs are great for a HTPC solution. I overclocked my HD4250 to 900MHz (880G chipset) and topped out at (an inconsistent) 40 FPS in BC2 on low settings. When the i3-2100 was 30% more than it is now, it had no real place in the market. It was too expensive for the "budget / HTPC people" and lacked 2 cores and an unlocked multiplier for the mainstream enthusiast. When I built my rig, I think the i3 was over $160 or $170. Pricecanada.com only has the NCIX bundle, so I can't check it now (pricecanada has pricing history). At the same time, the Phenom II X4 955 was about $125. AM3+ boards weren't available at the time (it was like early April), so I got a budget AM3 board.Quote
