Intel Core i5-2405S Review
CPU Benchmarks
Since we tested the other CPUs in the graph, AIDA64 has undergone some serious tweaks under the hood and so the zLib and AES results can't be compared and should be taken as standalone results. However the CPU Queen and PhotoWorxx results are, and the low clock-speed of the i5-2405S is clearly evident as it just about keeps up with the old i5-2300.
Memory Benchmarks
The memory tests clearly show a bit of a hole in the write speeds, either in stock or overclocked trim. Otherwise it's about where you'd expect it to be. Those read speeds are a little cause for concern, especially considering some very rapid Kingston Genesis RAM.
«Prev 1 2 3 4 5 6 7 8 Next»
31-08-2011, 06:02:33
The latest in a long line of SandyBridge processors is the low power Core i5-2405S. We put it to the test.
Continue ReadingQuote
31-08-2011, 06:17:02
Seems pretty pointless to release this when it offers nothing but a lower TDP and who would buy this when you can get the 2500k for the same money which you can also overclock
Even if you don't go for the 2500k the non K 2500 is still cheaper and faster than the 2405S.Quote
31-08-2011, 07:24:06
There's also the i5 2500T as well which is only 45W, but that's even more expensive than the 2500K.Quote
