Gigabyte Z77X-UP7 Review
PC Mark
Published: 11th October 2012 | Source: Gigabyte | Price: £310 |
PC Mark Vantage
The results of PC Mark Vantage, whilst good, are not quite at the same dizzying heights we've seen so far. The Memory score is the best we've seen, but the productivity result is somewhat lacking and that's dragging the overall score downwards.
PC Mark 7
We go a little back and forth with PC Mark 7. The stock result is the highest stock result we've achieved, and only with the overclock in place does the result not quite have the same extreme score we've seen from other high end motherboards. It's a very close run thing though, and you wont be disappointed in either scenario.
but its the lead singer thats gett'n his duck sick!!!
I thought about what you said about leaving the cpu on auto ect, gave it some thought and i knew mine was on "offset" mode. i have the p67 sabertooth with a 2600k @ 4.5ghz .done via the "oc tuner" in bios. 103 frequency and 43 multiplyer i think. the voltage on cpuz shows it moves from 1.15 up to 1.36. is this okay? temps are 68 ish while running prime for 1hour with the h70.
Thanks
welcome to the forum.
great question, but you have it buried in a review that prolly wont get answered.
you get a better response making a new thread in the Mainboard & CPU discussion
group. or using the search function where you will find many other similar questions and
answers. there are many enthusiasts there that can give you a prompt response.
and when you make you question, you'll wanna include mobo make, chip, RAM
GPU and power supply.
airdeano
I'm pleased to see that it got rave reviews here at
Overclock3D.
Finally Gigabyte have reintroduced a "7 series" motherboard. Does the UP7 live up to its lofty predecessors...
Continue Reading
