Gigabyte Z77X-UP4 TH Review
PC Mark
Published: 20th August 2012 | Source: Gigabyte | Price: £150 |
PC Mark Vantage
PC Mark Vantage gives a bit of cause for concern. We see the same middling memory results that we saw in AIDA64, and the Gigabyte Z77X-UP4 TH ends up with one of most disappointing gaming scores we've seen. Curiously when compared to the rest of the models on test we see the actual PC Mark result being just a shade behind the better motherboards we've benchmarked. Maybe the Catalyst 12.6 drivers don't perform as well here as the 12.3s.
PC Mark 7
The ship steadies with the latest version of PC Mark. The UP4 is there or thereabouts when at stock, and the overclocked score reflects the slightly lessened clockspeed we were able to obtain.
and for the £££££'s this fairs well
I am seriously considering buying this board; however, I am little concerned about the height of the heat sinks that surround the CPU socket.
I have bought a Thermalright Archon SB-E and due its’ 155mm length, it will overhang / foul the very top heat sink.
The clearance from between the base of the cooler to the first fin is 42.55mm. Does anyone know the height of the top two heat sinks on the board?
Does the Thermalright Silver Arrow SB-E used in the review overhang the heat sinks (length 147mm)? If so, I might be in the clear because the Silver Arrow SB-E has a height of 40.87mm.
Any reply would be very much appreciated!
Today we have the latest Gigabyte Z77X UP4 TH on our test bench. How does it perform?
Continue Reading
