Gigabyte Z77X-UP4 TH Review
SiSoft Sandra
Published: 20th August 2012 | Source: Gigabyte | Price: £150 |
SiSoft Sandra
Sandra is always good at making the absolute most out of the clockspeed and processor you have installed. Indeed it's almost capable of separating the CPU from the rest of the components. The UP4 puts up a good showing both in the stock speed tests, and the overclocked tests.
Processor Arithmetic
Processor MultiMedia
and for the £££££'s this fairs well
I am seriously considering buying this board; however, I am little concerned about the height of the heat sinks that surround the CPU socket.
I have bought a Thermalright Archon SB-E and due its’ 155mm length, it will overhang / foul the very top heat sink.
The clearance from between the base of the cooler to the first fin is 42.55mm. Does anyone know the height of the top two heat sinks on the board?
Does the Thermalright Silver Arrow SB-E used in the review overhang the heat sinks (length 147mm)? If so, I might be in the clear because the Silver Arrow SB-E has a height of 40.87mm.
Any reply would be very much appreciated!
Today we have the latest Gigabyte Z77X UP4 TH on our test bench. How does it perform?
Continue Reading
